Truck shut off while idling
Discussion in '1st Gen. Tacomas (1995-2004)' started by killzone90, Jan 26, 2011.
  1. Jan 26, 2011 at 9:08 AM
    killzone90
    killzone90 [OP] Well-Known Member
    Ethan
    Fairdale,ky
    96 tacoma
    Ok i work at toyota and idk really on this one.Only one i can think of was idle air or somthing like that.I drove it to my work 15 miles away and it never had a problem.stoped at a light and it started idling rough then shut off.I restarted it,gave it gas and it ran perfect.Idk becuase i drove it home and its still runing perfect.
  2. Jan 26, 2011 at 9:09 AM
    CraigTRD
    CraigTRD Canadian in the South
    Craig
    London, Ontario, Canada
    Tacoma
    6" FabTech Lift, Custom rear leaf packs, RedLine gas hood props :D, Hockey Stick Canadian Flag Mod. 2012 Front
    Bad gas?
  3. Jan 26, 2011 at 9:11 AM
    twistax
    twistax Toyota Freak
    Carlsbad NM
    2017 Tacoma 4x4 Off-Road
    CaliRaised ditch mounts & Side Projecting pods
    Possible fuel filter clog also.
  4. Jan 26, 2011 at 9:17 AM
    killzone90
    Ethan
    Fairdale,ky
    96 tacoma
    I was also think maybe bad gas or filter but wasnt for sure.Or maybe a cloged fuel line ive seen that happen befor
  5. Jan 26, 2011 at 9:25 AM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    You work at Toyota?.. as mechanic?.. Why are you asking us these questions. At my dealer they have like 20+ Techs. Ask the other tech's there that DEAL with that shit everyday for possibly 1-30 years of experience...?......... :rolleyes:
  6. Jan 26, 2011 at 9:34 AM
    killzone90
    Ethan
    Fairdale,ky
    96 tacoma
    Im not at work today and im pretty sure i know its the gas and they said when i called one probly gas and yea just becuase were mechanics dont mean we no everything.Newer cars are a little easier and even with bad gas they tell u.Im pretty sure its gas jw what other ppl thought.If i was at the shop the first thing i would have pulled a fuel pressure test and see what it says then looked at gas but cant do that at my house becuase all the race cars are in my garage.
  7. Jan 26, 2011 at 10:01 AM
    twistax
    Carlsbad NM
    True, after years of putting gas in the tank, there might be gunk and chunks that may have been sucked up, check the flow of the fuel when/if you remove your fuel filter (from both sides). If its flowing smoothly then it may be time for a filter change.
    That use to happen on my 85' Toyota pickup ;)
  8. Jan 26, 2011 at 10:05 AM
    killzone90
    Ethan
    Fairdale,ky
    96 tacoma
    yea my fuel pressure gauge is at work so cant do it at home but tom when i get in the shop im goin to pull a fuel pressure test.
  9. Jan 27, 2011 at 7:57 AM
    SargeSlapnuts
    SargeSlapnuts SargeSlapnuts 보고용의!!!!
    Nick
    alpharetta, GA
    2004 TRD 4x4 converted PreRunner SR5 lifted l
    255/85-16 tires, front push bar w/9000lb winch, driver and passenger windows tinted to match factory rear tint, quick at home spray on bedliner, hid's, lifted with 3"toytec rear lift kit and ome front lift, locked with powertrax, and a cb radio in place of ash tray, fog light mod, diff breather mod, greasable shackles, Home made Baja Rack, "extra" bright reverse lights. also converted to 4x4 safari snorkel
    one thing i have ran into with these trucks is that they tend to have a heart attack every once in a while. my truck has had all of three heart attacks. just cut off one day on a trail then started up fine, my abs had a heart attack on a dry road the other day under light braking, and threw check engine light a two months ago then went off and nothing since. you truck shutting of is odd i have noticed at red lights the stall converter make the truck vibrate.
