Truck-side trailer wiring issues; all pointers would be appreciated
Discussion in '3rd Gen. Tacomas (2016-2023)' started by skoop92, Sep 29, 2020.
  1. Sep 29, 2020 at 6:09 PM
    skoop92
    skoop92 [OP] Member
    K.
    2017 Inferno DCLB TRD Offroad
    Hey y'all, :wave:let me preface that by saying, yes, I did use the search function, and yes I did read through many threads, and no I was unable to find, except for one, a thread that listed a similar issue.
    BUT! I wanted to see if I could pick the brains of you fine TW people who have been around a lot longer than me. So, any help would be greatly appreciated.
    Anywho, this is on a '17 TRD OR w/ factory towing package. I noticed on my trailer that my brake lights and turn signals were not working and the right light would occasionally just not work, "Okay Kaleb, check your grounds." went through each light made sure each ground had a good connection, checking with a DMM. The brake and turn signals still were not working so I started checking at the lights for power. I have power on the running light circuit (which I knew had power because, well, they worked) but I had no power on the brake lights or turn signals (with brake depressed and signals on) Soooooo I moved to the truck side of things. I picked up when of those plug-in testers for the 4-pin connector and it shows that I have power to the running lights but with any combination of hazards, signals and brake I have no power on the Right or Left brake/turn circuits and confirmed with a multimeter. Moved over to check the 7-pin connector and same thing. No power on RH or LH brake/turn. I checked the fuses in the truck, under hood and drivers kick, that I could find labeled towing and did not find any bad (however as I'm typing this I'm realizing I only did a visual not a resistance check, will go back and check tomorrow). I'm going to bring home my wire piercing leads for my multimeter from work tomorrow and check before each plug to see if I have power on that side or not. Wanted to reach out and see if anyone here has had this issue and could maybe point me into some checks that I may not have thought of yet. Electrical isn't exactly my strong suit. Injection molding is but that doesn't really help me that much here. :notsure:
    Any help would be greatly appreciated amigos:cheers:
  2. Sep 29, 2020 at 6:18 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    check 17 trd 1st without trailer being hooked up
    then check to be certain however the trailer pigtail is connected
    that it is correct ...............NOT shorted or grounded
    check for side crosses & corrosion
    if ALL is good U KNOW issues are on the trailer !!!!!!!
    if everything truck + pigtail is correct leave Unconnected
    check ALL wiring on trailer visually to be certain
    wiring is NOT worn grounding inadvertently with frame o trailer
    now hook up to trd & start trouble shooying trailer
  3. Sep 29, 2020 at 7:48 PM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    It has been awhile since I messed extensively with the trailer wiring. From what I recall, the trailer left turn / right turn / brake lights are controlled by the combination meter (the dash cluster). The combination meter monitors for short circuits to ground, as well as shorts between the LH and RH light wires, etc.
    My recommended first step is to disconnect the trailer, power cycle the truck, and see if the truck side is providing power correctly without being hooked up. Then ohm the truck. I bet you will find that the RH and LH trailer light circuits are shorted together.
    The trailer tail lights are NOT controlled by the combination meter.
    Tullie D likes this.
  4. Sep 29, 2020 at 8:33 PM
    caribe makaira
    Caribbean, Puerto Rico
    Stop/Turn Combo is inside the Combination Meter (not a separate module). If the Tow fuse is blown then no Stop/Turn on 4 pin or 7 pin Tow connector.
  5. Sep 30, 2020 at 5:47 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Wire piercing leads will screw you in the future -- moisture gets in the holes and corrodes the wire. Don't do that to your future self.
    Pickupman2007 likes this.
  6. Sep 30, 2020 at 6:25 AM
    Pickupman2007
    Pickupman2007 Well-Known Member
    Kenneth
    Murfreesboro, TN
    2022 Rivian R1T
    2020 Tacoma: Morimoto xB LED Headlights & fogs, MESO Total Tail S1, Fortin Evo One Remote Start, OEM Audio Plus System 500Q,, Redarc trailer brake controller, Carplay2Air wireless adapter, Custom shift knob, Electric tailgate lock, Chrome tailgate inserts, Limited fog light bezels, 2018 TRDOR Grill, Chrome door handle covers
    In case it helps here is the towing diagram. Looks like the turn signal/brake lights for the trailer come straight from the combination meter.
  7. Sep 30, 2020 at 7:32 AM
    skoop92
    skoop92 [OP] Member
    K.
    I've narrowed the issue done to being a truck side issue, not trailer but I'm all for triple and quadruple checking
    I've got power to the running light circuit but absolutely 0v to the stop/turn on both left and right. Ill have to ohm between left and right, I havent checked that yet.
    So the tow fuse is in the combination meter or is it straight wired?
    noted, didnt really think too hard about that apparently.
    Thanks for this, definitely going to save it and try to make some sense of it.
    Thanks for the leads y'all! I can't spend a whole lot of time on TW since I'm at work but the combination meter are they fused there or straight wired from it? Do I need remove the whole dash or is this a case of removing the bezel and cluster and getting behind there? Or should I look at other things before resorting to that?
    Thanks again everyone.
  8. Sep 30, 2020 at 7:36 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    DON'T use a DMM to check for bad grounds, use a good-quality incandescent (an LED test light is virtually the same as a DMM in terms of what it will tell you) test light. A DMM will show ground even if it's poor, but by placing a load on the circuit, you can get a visual check on the "quality" of your ground.
    Pickupman2007 and RustyGreen like this.
  9. Sep 30, 2020 at 1:43 PM
    caribe makaira
    I think the pic shows where the fuse is...:playball:
  10. Sep 30, 2020 at 4:26 PM
    skoop92
    skoop92 [OP] Member
    K.
    Got that, had already checked it but his phrasing made is seem as if it was inside the combination meter, which is what had me confused, but thanks.
    Anyway, all fuses under the hood are good, all fuses under the dash on the drivers kick are good, every fuse labeled with any variation of "tow" has been checked good. The only thing I didn't check is the towing relay because, well I do not know how to test one without a power probe, but I imagine sense my running lights work, that should be fine, right? I pulled the 7-pin plug off the back side of the bumper and noticed quite a bit of corrosion on the pins, checked for voltage anyway and still did not have any power on RH/LH Stop and Turn. No pins seem to be shorted together either.:notsure:
  11. Sep 30, 2020 at 4:54 PM
    caribe makaira
    "His"? Who's phrasing?
    Anyway, the module that handles the Towing combining of the STOP/TURN is part of the Combination Meter, it's not a part that can be removed. If it has failed then a new Combination Meter is the fix.
  12. Sep 30, 2020 at 8:41 PM
    caribe makaira
    OP, with a Probe Lamp, verify TURN & STOP on these connectors.
    TLT =Towing Left Turn
    TRT =Towing Right Turn
  13. Oct 1, 2020 at 4:00 PM
    skoop92
    skoop92 [OP] Member
    K.
    T
    hanks for the info man. Looks like my problem is the combination meter. I have no power at either connector.
    Thanks for the replies everyone.
  14. Oct 1, 2020 at 5:34 PM
    caribe makaira
    This could resolve your issue without buying a new Combination Meter...
    Connectors C9 & C10 are on the Combination Meter.
