Truck Sits Uneven?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by xmixpixx, Mar 6, 2010.
  1. Mar 6, 2010 at 6:29 AM
    xmixpixx
    xmixpixx [OP] Well-Known Member
    Lancaster, PA
    05 SR5 TRD Off Road 6 spd
    I recently noticed that the rear end of my 05 tacoma is sitting uneven. The drivers side of the rear of the truck is lower, and the whole truck looks crooked. I had parked on a snowpile a little while ago and it flexed the rear end to about its max, so could this cause negative pressure in the shock preventing it from fully extending? (i'm going off of mountain bike suspension for this idea)
  2. Mar 6, 2010 at 6:30 AM
    Rocketball
    Rocketball If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    It's not just you.
    This is known as the "Taco Lean".
    Unfortunatley it's very common. :cool:
  3. Mar 6, 2010 at 6:36 AM
    xmixpixx
    Lancaster, PA
    It's not the "tacoma lean". I would say the gap in the rear wheel well is probably 2 or 3 inches different from left to right in the rear. The front looks "normal"
  4. Mar 6, 2010 at 6:39 AM
    xmixpixx
    Lancaster, PA
    I just went out and measured. At the center of the wheel, the passengers side wheel well gap is roughly 7", and the drivers side is roughtly 5.75". Is the taco lean really this bad?
  5. Mar 6, 2010 at 6:45 AM
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
    taco lean is about a 1/4 inch. check your shock.
  6. Mar 6, 2010 at 6:46 AM
    xmixpixx
    Lancaster, PA
    It's probably a little under half. Thanks for the unfortunate info! I was sure i screwed up the rear shocks and could get it back to normal! btw I love the truck lrgrnr
  7. Mar 6, 2010 at 6:48 AM
    xmixpixx
    Lancaster, PA
    That's what I was thinking...
  8. Mar 6, 2010 at 6:56 AM
    luni
    luni Resident Gun-toting Hippie
    Burt's Mustache
    Ft Bragg, NC
    TRD OR
    Icon c/os, TSB 4 leaf pack, Unbreakable Fab tube winch bumper, Mile Marker SEC12000, Roadless Gear winch control panel, Bud Built skids, URD Pipe Bomb Y pipe, snorkeled rear diff breather, no carpet
    Stock taco lean is barely noticeable. I checked my 09 when it was still on the show room floor with 1 mile on it, saleman thought I was on crack.
    Lift components sometimes don't compensate for it making it worse. Dakar leaf springs come with a driver side and passenger side spring.
  9. Mar 6, 2010 at 6:58 AM
    xmixpixx
    Lancaster, PA
    Are there any signs in particular I should be looking for when I check the shocks out? I am able to lift up on that side of the truck and the shock does extend. I was rear ended last july, and had some frame damage, and I'm starting to wonder if this is a result of that in some form....
  10. Mar 6, 2010 at 6:58 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    What did you do to screw up the suspension?
    Typically, the driver's side does lean down more as the weight is unbalanced, and causes more wear on the suspension on that side. Driver, battery and fuel tank are all on that side... so unless you have a 300lb passanger (and aren't that yourself) to help balance it out everytime you drive... it'll 'break in' that side more.
    However, if the driver and pass side is running the same height... did you twist the frame/body? Also you might want to check the bed alignment... is it lined up the same at the cab on both sides? The fact you mentioned you thought you screwed something up makes me wonder... though these trucks can take a real beating even on some mild jumps...
  11. Mar 6, 2010 at 6:59 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    You replied before I finished lol...
    Unfortunatly it sounds like you might have a tweaked frame... I'd follow up with that, and if it is you need to get with the insurance company... normally twisted frame means a totalled vehicle.
  12. Mar 6, 2010 at 7:04 AM
    xmixpixx
    Lancaster, PA
    I parked at a Burger King for a few hours, and knew my one wheel was partially on a snow pile. I didn't noticed how bad it was until I got back in my cousins truck from fishing, and saw I had completely flexed out the rear suspension. I thought I was on about 2 or 3 inches of snow, but instead that rear wheel was way up on the pile.
    It was a very drastic difference that I have noticed. The front of the bed seems alligned with the cab, while the rear of the bed has a noticeable lean.
    As far as the accident goes, I got rear ended, and I had just towed the boat so I had my hitch in, and that buckled the rear of my frame pretty good. They ended up cutting off the rear of the frame, replacing the bed, etc. It seems "klanky" in the rear end of the truck when I'm driving, but I can't simulate the klanks by grabbing a hold of the bed and trying to shake it at all.
  13. Mar 6, 2010 at 7:05 AM
    Taco4x4NC
    Taco4x4NC Well-Known Member
    David
    Western North Carolina
    2010 4x4 DC/LB "Pytrite Mica/Katzkin leather
    3m clear bra or Venture, stant locking gas cap, Shield, front windows tinted, weathertechs, ARE "Z" topper. Sockmonkey decal, Billy 5100's x 4 corners, Eibach coils, Toytec 1.5 AAL. Michelin 265/75/16 MS2's, Grillcraft MX series/TOYOTA badging. FJ/SE TRD Anthracite gray wheels. Katzkin leather/heated seats.
    Had the same lean...they all do.
  14. Mar 6, 2010 at 7:05 AM
    luni
    Burt's Mustache
    Ft Bragg, NC
    TRD OR
    Check your leaf springs and spring hangers also. In particular look at the welds. If there was weakening from the accident you might have aggravated it.
  15. Mar 6, 2010 at 7:08 AM
    xmixpixx
    Lancaster, PA
    It is so noticeable that last night walking out of a restraunt my fiance noticed it from probably 50 yards. And she wasn't even looking for it.
  16. Mar 6, 2010 at 7:25 AM
    brg88tx
    brg88tx Well-Known Member
    my 03 taco does not lean
  17. Mar 6, 2010 at 7:26 AM
    RainDodger
    RainDodger YGWYPF
    Great Northwest
    '09 Black, TRD Sport
    None yet! It's new!
    An inch and a quarter doesn't indicate that something is bent or messed up. That's just the way it is. You could take it into a suspension shop and they could help you out, but it's really not worth it in my opinion. My brand new '09 is probably nearly an inch out of whack. I can notice it, but no one else does.
    Just a note... at least with a stock suspension... checking your shock has nothing to do with it. The weight of your truck does NOT sit on your shock. It sits on the springs. The shock's job is to slow and absorb the movement of the suspension when it moves up or down. Your shock should have nothing to do with the height of your truck. The "problem" will be defined by springs or something bent out of specs (unlikely).
  18. Mar 6, 2010 at 7:39 AM
    xmixpixx
    Lancaster, PA
    Good to know, thanks
  19. Mar 6, 2010 at 7:42 AM
    glandnut
    glandnut Grease Monkey
    Florida
    09' MGM TRD DC Sport LB(gone), 16' 4Runner Trail
    secret stuff.
    Anyone with the rear TSB notice the lean is gone?
  20. Mar 6, 2010 at 7:43 AM
    luni
    Burt's Mustache
    Ft Bragg, NC
    TRD OR
    brb
    I don't like measuring fenders since they're curvy and it's hard to get an accurate number soooo
    15" from the ground to the base of each front spring hanger.
    32 1/2" from the ground to the corner of a dropped tailgate.
    Measurements taken in my garage with 1/8 of tank and some crap in the backseat.
    Level.
