Truck sits uneven
Discussion in 'Suspension' started by PeTRD, May 6, 2010.
  1. May 6, 2010 at 3:37 PM
    PeTRD
    PeTRD [OP] Member
    Pete
    CT
    02 Xcab TRD
    Tuff Country 3" suspension, Performance Accessories 3" body lift, K&N air Filter
    I have an 02 Trd tacoma I have a 3" body lift and a 3" tuff country coil spacer lift kit, the rear sits noticably higher in the back, I was wondering if I got coilover shocks for the front if it would help even it out more???
  2. May 6, 2010 at 8:04 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Nope. You'll need to lower the back with a shorter lift setup.
  3. May 6, 2010 at 8:12 PM
    PeTRD
    PeTRD [OP] Member
    Pete
    CT
    02 Xcab TRD
    Well I have blocks in the rear now, what's a more efficent way, plus where can I find a new kit for the rear?
  4. May 6, 2010 at 8:40 PM
    nvdeserted
    Reno, NV
    In that case it's easy. How much higher is the rear now? Just a matter of simple math at this point: if the rear sits 1" higher and you have a 3" block on there then just swap it out for a 2" block and then you'll be level.
    Try Toytec or Wheelers Off Road for different sized blocks.
  5. May 7, 2010 at 8:49 AM
    PeTRD
    PeTRD [OP] Member
    Pete
    CT
    02 Xcab TRD
    There's gotta be a better way then lowering the back.... What about the torsion bars????
  6. May 7, 2010 at 8:57 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    We don't have torsion bars unless you have a late 80's early 90's Toyota pickup. & cry about it. You drive a truck for **** sakes...its supposed to sit uneven...if it bothers you that much...you can throw a couple sand bags in the back.
  7. May 7, 2010 at 9:11 AM
    PeTRD
    PeTRD [OP] Member
    Pete
    CT
    02 Xcab TRD
    I have been for a while, mr. rude guy, i was just wondering if it was an easy thing to fix. I just got into lifting like 2 years ago i dont know much about all the different types of stuff u can do. From this picture it doesnt look bad, but when on flat ground the rear sits about 2 inches higher.
  8. May 7, 2010 at 9:15 AM
    sirsaechao
    Tim
    Commifornia
    Your options for the rear are swapping out the rear blocks or shackles for smaller ones.
  9. May 7, 2010 at 2:17 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Are you on the original toyota springs in back?
    Right now, all of the height you have in the back is either from the body lift and the blocks, right? The simple fix is to use a shorter block in back. However, that is not the only option.
    To change the height of the back could involve removing the lift block altogether. Course, with no block at all it would be too low but you can add an add-a-leaf to the toyota spring pack or even replace the springs with a set that gives some lift.
  10. May 7, 2010 at 6:29 PM
    nvdeserted
    Reno, NV
    Or just do a 6" lift on the front...
  11. May 7, 2010 at 11:04 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Yeah, you need to lower that back!
    I would get rid of that block lift back there and do an AAL. First measure what the difference is front to back on level ground to see how much you want to come down. But I would say a 1.5" or 2' AAL would do it.
  12. May 8, 2010 at 1:36 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    ^ x2. imo id go with aal instead of shackles or blocks
