Truck skidding out of control - Light
Discussion in 'Technical Chat' started by Nick54, Dec 13, 2012.
  1. Dec 13, 2012 at 8:17 AM
    Nick54
    Nick54 [OP] Well-Known Member
    Nick
    Mentor Ohio
    2010 Tacoma TRD Sport
    ARB Rear Locker & Compressor, Bakflip F1, Antennex 13" flexable antenna, WeatherTech Floor Liners, WeatherTech Side Window Visors, Tacoma Bed Mat, Demello Rock Crushers, Dynamax Ultraflow SS Muffler, TSB 4-Pak Leaf Springs, AFE Pro Dry Filter, Redline Hood Struts, Color Matched Angry Eyelids, Combo Lock Bed Compartments, Bed Mat, Pop-N-Lock, Wet Okoles, Goodyear Duratracs on ProComp 7033's, M101A2 Trailer, Grillcraft Mesh Grill, Light Racing UCA's, King OEM Performance Remote Reservoir Adjustable Front & Rear Shocks, JVC NT3HDT, Blue Sea Aux Fuse Panel, BAMF Behind Grill Light Bracket, Kragen 55W 7" HID's, CBI Front Receiver, Home Link Garage Door Opener, FlyEyez Light Unit, Bud Built Front to Back Skids...
    Got an alignment yesterday and now my traction control light is on, anyone know what's up, or how to reset it. Thanks for the help.
  2. Dec 13, 2012 at 8:39 AM
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    Which truck skidding light is it (there are two)? Does it say OFF under it, or just the truck skidding?
    Is it blinking or solid?
    Any other lights on?
  3. Dec 13, 2012 at 8:46 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Maybe a wheel speed sensor? I'd just take it back. Make em fix it
  4. Dec 13, 2012 at 3:38 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
  5. Dec 13, 2012 at 3:41 PM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Literally JUST had the same light come on after my alignment on Friday.
    This is the only logical explanation I could come up with.
    VSC Recalibration PDF
    Since I got aligned outside the stealership, they want $99 to recalibrate it. I have a friend who works for Toyota, so I may be able to get it done for free. As far as they're concerned, Toyota is the only entity with that "Intelligent Tester" tool.
  6. Dec 13, 2012 at 3:58 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  7. Dec 13, 2012 at 4:18 PM
    KenLyns
    Belly of the Beast
    Not just the yaw sensor per se. The VSC system also uses the steering wheel angle sensor as part of its algorithm, so if the alignment process changed the toe and/or thrust angle slightly, that could throw it off.
  8. Dec 13, 2012 at 4:22 PM
    The Traveler
    SoCal
    That would explain a lot.
    My steering was about 10:00 while going straight after my hard hit, and they fixed it with the alignment...after that I got the light.
  9. Dec 14, 2012 at 7:44 PM
    Nick54
    Nick
    Mentor Ohio
