truck slid off jackstand, am I ok?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeremy_283, Jan 17, 2010.
  1. Jan 17, 2010 at 9:26 AM
    jeremy_283
    jeremy_283 [OP] Super Member
    08 TRD Offroad Access Cab 4x4 Auto 4.0L
    Hella Rallye 4000 Cornering Lights PIAA 510 Fog Lights All Pro Front Bumper All Pro Rear Bumper All Pro Transfer Case Skid All Pro IFS Skid All Pro Rock Sliders All Pro High Clearance Hitch OME Dakar Leaf Springs OME Rear Shocks OME Front Shocks OME 885 Front Coils Wet Okole Seat Covers WeatherTech Floor Liners Sony Head Unit JL XD600/1 Amp 2 JL Audio 10” Subwoofers Custom Subwoofer Enclosure Kenwood Front Speakers Sony Rear Speakers Sound Deadening Mats LED Interior Lighting Pop N’ Lock Tailgate Lock Viper Alarm System Extra D-Rings In Truck Bed Maglite Seat Mount Disable Seatbelt Chime Rear Differential Breather Relocation Hi-Lift Bed Mount Flexible Front Mud Flaps 110v Inverter Always At 400w ABS Kill Switch Locking Center Console Removed Sway Bar
    my truck kinda slid off the jackstand on the front a arm while i was rotating my tires, it didnt like crash to the ground or anything, but it fell into the earth, the ground was soft and had a few rocks in it, my disc looks fine with no scratching, and i bent the inside disc guard back strait cause it got bent a little bit when it fell, is there anything else that could be wrong that i cant see?
  2. Jan 17, 2010 at 9:44 AM
    TMCAEG
    TMCAEG Well-Known Member
    Vancouver, Canada
    2005 Access Cab TRD Black
    You're probably fine, just make sure there are no rocks caught in your brakes. Take this as a lesson learned. Should always have a block, jack stands, or even a tire under there so that IF it slides off or falls you will be protected...
  3. Jan 17, 2010 at 9:48 AM
    gusotto
    gusotto gusotto
    Gary
    Iowa
    2001 Tacoma 4X4 SR5 Extended Cab
    AGREED!!!!
    Working under the truck without a jackstand can be fatal.
    Even just rotating tires!
  4. Jan 17, 2010 at 9:56 AM
    jeremy_283
    is it fine that the disc guard got bent? is there an easy way to replace those?
  5. Jan 17, 2010 at 10:00 AM
    ksj
    ksj Well-Known Member
    Pacific NW
    2018 Cavalry Blue TRD Pro
    265/75-16 KO2
    You'll probably want to get an alignment...
  6. Jan 17, 2010 at 10:12 AM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    I could be wrong here, but it sounded like the op allready had the truck on a jack stand and it slid off...correct? Maybe the op could elaborate a bit on what caused this to happen so others wont run into the same problem and get injured. Was the truck in park with the emergency brake on? Did you have just one wheel off the ground? Did something bump the truck to cause this, or did it happen when useing the jack? Please explain...
  7. Jan 17, 2010 at 11:02 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    The important part is that hopefully no one is injured. I guess reassemble your truck and see if there are any issues with alignment, rubbing, etc.
  8. Jan 17, 2010 at 11:19 AM
    Chester
    Chester Well-Known Member
    Nor Cal
    07 Access Cab TRD-OR M-V6 4x4
    Rear Spring TSB,Locker Mod,In bed cargo lights,Fully de-badged,TRD Seat Covers,Trailer Harness Relocation,Painted wheels,Extra tie-downs,5100's,Biceman lighting,09 stereo with sirius & isimple ipod interface,Rear diff breather mod,K&N Air Filter
    Sounds like it is a case of bad placement with the jackstands,As you jack the other side the weight and load will shift.I made mine back in HS with a nice top that cradles the frame rail.Some of the jackstands I see for sale have these silly little tops that look useless.Good to hear no one was hurt!
  9. Jan 17, 2010 at 11:43 AM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    X1
  10. Jan 17, 2010 at 1:18 PM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    it may be because the jackstand was on the A arm ??
    not a good place to support the truck.
  11. Jan 17, 2010 at 1:50 PM
    crittergitter
    crittergitter Proud to be Canadian Navy
    Stu
    Shearwater, NS
    '06 Tacoma 4WD Double Cab
    Bugger, skid plate, colour coded cap, bed mat, AFE Air Filter, Rear diff breather mod, Chirp on door lock;unlock, ABS mod, Weathertechs front and rear, 60" Hi-lift jack, LED light mod in rear bed, 12V accessory in bed, n more stuff.
    Glad to hear you were not hurt. The jackstands are to be used on a part of the suspension / frame that does not flex / hinge that way there is lots of support and less chance of a "slide". If it slipped off and fell on soft earth I suspect that your only issue will be stones or gravel. I can't see why an alignment would be necessary if it did fall on the soft earth you described. My $.02.
  12. Jan 17, 2010 at 1:54 PM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    Good to hear you were not under it when it fell. I always lay my wheels under the truck when I use jack stands.
  13. Jan 17, 2010 at 2:58 PM
    drjohnson36
    drjohnson36 Well-Known Member
    09 Pre-Runner SR5 DC
    Last year, with my old car (Scion tC), a 5.2 earthquake occurred while I was underneath changing the oil. I had it on a jack with one jackstand propped up next to it as a backup. The rear wheels were blocked. While I was still under it, the car somehow slid off the jack but caught the jackstand.
  14. Jan 17, 2010 at 3:01 PM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    Damn! That's crazy.
  15. Jan 17, 2010 at 3:15 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    These trucks are tough as hell. Last weekend I took mine for a 'little' 40mph jump and landed on the skid... seriously thought we totalled the truck out. So minus a stock skid plate crushed I really can't find crap... and I've looked up and down lol.
    Crazy man, I always have backup stuff under a car for it to slide onto. I thought maybe I was just being paranoid but i'm glad to see it saved someone!
    I have my 280z up on 6ton jacks right now with backups and blocks under for slip protection... even them I'm still cautious as hell around it. I'd like more but being a unibody there really isn't much more I can do...
  16. Jan 17, 2010 at 3:28 PM
    jeremy_283
    alignment? that doesn't make any sense as to the way it landed
  17. Jan 17, 2010 at 3:32 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    Well, these trucks have pretty high clearance. That's a pretty large fall... there's always a chance you could tweak stuff, including the frame. Once you get it back up and running you'll know if it's pulling though.
  18. Jan 17, 2010 at 3:38 PM
    TMCAEG
    Vancouver, Canada
    Glad you're ok - that must have scared the @#$% out of you. I'm always nervous when under any vehicle because you just never know. Always make sure the stands are on secure solid ground and a back up in place just in case.
  19. Jan 17, 2010 at 3:46 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    Yep, not a problem. Just bend the guard back as best you can.
  20. Jan 17, 2010 at 3:49 PM
    SC4333
    Grant
    San Antonio, TX
    As for the alignment, you shouldnt have anything to worry about. I've seen the front end of an F-250 powerstroke come crashing to the ground before with no ill effects. Other than the guy under it..
    If something does happen to be off, it will be obvious when you drive the truck. If this if the case, then take care of the issue as needed.
