Truck slipping down icy driveway. 6 speed.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by octoben, Dec 13, 2020.
  1. Dec 13, 2020 at 2:58 PM
    octoben
    octoben [OP] Active Member
    Ben
    2020 Cement Tacoma TRD Sport Premium Manual
    I went for a ride in the snow today to try out my new winter tires. I have a slopped driveway. I backed in and parked in 2h. Looked out a half hour later and saw my truck in the middle of the street!!!
    Luckily there was no damage. I changed my underwear and made sure the parking brake was set and the truck was in reverse.
    I parked it again in 4hi. I think this should help cause now the front is engaged.
    What should I do to make sure this doesn't happen again? Things Ive thought of.
    1. Sand bags in back
    2. Park in 4hi or 4low
    3. Park front up the hill??
    4. Wheel chocks?
    Any suggestions are appreciated
  2. Dec 13, 2020 at 3:04 PM
    philth
    philth .
    Clear/Salt your driveway?
    Lastplace, Sig45, BSFord and 19 others like this.
  3. Dec 13, 2020 at 3:04 PM
    kairo
    kairo >_>
    Nor Nev
    '20 OR DCLB Quicksand
    put some salt down and melt the ice.
    Sig45, Tacosha and philth like this.
  4. Dec 13, 2020 at 3:05 PM
    octoben
    Ben
    I always salt after I clear the driveway, but I should put some down before the snow hit this time.
  5. Dec 13, 2020 at 3:06 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    So I have good experience with this one. My driveway is steep all the way to the garage door.
    I always leave my truck in 4wd when parking in the driveway if there is snow there. I will also dump some salt in front of and behind each tire when I park.
    1: sandbags wont help, if 1 wheel looses traction the other wheel will just spin due to the differential
    2: park in 4wd (high)
    3: doesnt matter what way you park, it will slide
    4: if the tires are slipping, wheel chocks will slip too, plus you will probably forget to remove them or the truck will of slid tight onto them.
  6. Dec 13, 2020 at 3:08 PM
    octoben
    Ben
    Thanks that was my thoughts exactly. I'm thinking 4hi will help the most. Did you have any issues after parking in 4hi?
  7. Dec 13, 2020 at 3:08 PM
    CdnSldr
    CdnSldr ______________
    Canada Eh!
    1. Confirm park brake actually locks up rear wheels.
    2. Engaging 4x4 will definitely help. High or low doesn’t matter. If your parking brake is holding as it should, don’t put it in gear. IF you still want to leave it in gear, engage the parking brake first and take your foot off the brake allowing the truck to roll forward slightly and the parking brake to take up the slack, THEN put it in gear.
    3. If your parking brake won’t lock up the rear, then refer to the dealer for warranty work if you’re not comfortable adjusting it yourself.
    4. Continue to reverse in. Your parking brake works slightly better to stop forward motion ( as opposed to rear motion) as the shoe are designed to lever against the drum a certain way, causing them to engage harder.
    demiTacoma, SR-71A and octoben[OP] like this.
  8. Dec 13, 2020 at 3:09 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    5. Move to Miami
  9. Dec 13, 2020 at 3:10 PM
    octoben
    Ben
    I tried just leaving it in gear but it will eventually overcome the compression and roll. With the brake on and in gear it seems solid as far as I can tell.
  10. Dec 13, 2020 at 3:11 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Double check what pressures your new winter tires are at.
  11. Dec 13, 2020 at 3:17 PM
    skiwaves8
    skiwaves8 Well-Known Member
    Pagosa Springs Colorado
    TRD
    If you use your parking brake you take the chance of freezing your crappy drum brakes!
  12. Dec 13, 2020 at 3:17 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    permanent solution always works
    Hooper89 and shakerhood like this.
  13. Dec 13, 2020 at 3:20 PM
    5nahalf
    Erik
    Minnesota
    Nope, I put it into reverse, then flip off 4wd and start going down the driveway. By the time I need to turn its disengaged. But in the winter I need 4wd to even get up my driveway.
    Here is my drivway, the pad that half my truck sits on is still a hill, but not as much as getting up.
  14. Dec 13, 2020 at 3:21 PM
    CdnSldr
    Canada Eh!
    If you don’t, you will “freeze” your parking brake cable eventually. The vast majority of jurisdictions require a functioning emergency brake for the vehicle to be considered “fit”.
    Edit: by freeze I mean corroded/seize etc
    shakerhood and octoben[OP] like this.
  15. Dec 13, 2020 at 3:22 PM
    octoben
    Ben
    I honestly have no choice but to use the park break. I'll break it free by moving if it freezes.
    CdnSldr[QUOTED] likes this.
  16. Dec 13, 2020 at 3:23 PM
    frodoz737
    frodoz737 TOP WRENCH
    Texas
    Wheel chocks people.
  17. Dec 13, 2020 at 3:25 PM
    Foster1
    Foster1 Well-Known Member
    California
    2023 SR V6 4x4
  18. Dec 13, 2020 at 3:26 PM
    flatus
    flatus Well-Known Member
    biloxi,ms
    2020 TRD OR DCSB 4wd Auto
    Waiting for bank account to grow
    I feel for you cold weather northern folks. I have a steep driveway but my biggest concern is slippery, moldy/mildewy, driveway cause of our warm/humid winters. I don’t think my truck will slide down it though. I do break the tires loose pulling up sometimes though.
  19. Dec 13, 2020 at 3:27 PM
    5nahalf
    Erik
    Minnesota
    wheel chocks do zero when the ground is covered in snow and ice and the wheels are already slipping.
    octoben[OP] likes this.
  20. Dec 13, 2020 at 3:33 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    My driveway is sloped and in the 20+ years I've been here, not once has my truck slid down. If it's too icy to walk on, it's too icy park on. Down goes some ice melt until it's no longer an issue. I don't use my emergency brake much in winter (seen too many freeze up) and don't park in 4WD.
    philth likes this.
