Truck smells like rancid gym sock after rain
Discussion in '1st Gen. Tacomas (1995-2004)' started by ThunderOne, Aug 16, 2015.
  1. Aug 17, 2015 at 10:53 AM
    ThunderOne
    ThunderOne [OP] Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Ah okay, I was crawling around under the truck looking. I'll pop the hood and check later.
    Thanks
  2. Aug 17, 2015 at 12:22 PM
    Raised_on_Tacos
    Raised_on_Tacos Active Member
    2001 Silver SR5 Xtra Cab 4x4 4cyl Auto
    Don't know if this helps, but i had the same problem. I had a leak on the rear sliding window. Take a hose to it and test for any leaks.
    Got the rear window replaced along with seals.
  3. Sep 12, 2015 at 5:43 PM
    abcoe524
    abcoe524 New Member
    toyoya tundra 2004
    I have a 2004 toyota tundra ext cab and I have the exact same problem everytime it rains cat pee/soiled gym socks. In fact it's currently raining and the smell is driving me nuts and my wife and kids also. This thread caught my attention when I goggle searched it. I didn't even put toyota in my search so I was surprised to see this issue with other toyotas
  4. Sep 12, 2015 at 6:43 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    The smell has eventually gone away for me, probably because I no longer live in an area with lots of strays. But the pine sol trick is worth a shot.
    abcoe524 likes this.
  5. Sep 12, 2015 at 8:13 PM
    abcoe524
    abcoe524 New Member
    toyoya tundra 2004
    okay thank you I'll give the pinesol a try. my carpet seems to be wet in the back driver side corner of the cab.every time it rains, the smell i think is from the carpet getting wet and staying damp and musty creating the smell.definitely no cats near it but i need to figure out how and where exactly it's leaking in from
  6. Sep 13, 2015 at 1:57 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I had the same smell !!
    Funny I broke up with my girl friend she seemed to think Sex was more important then me working in the shop.
    No more smell go figure !!
  7. Sep 13, 2015 at 3:10 AM
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
    Above all else sex first. Then what ever you need to do. Even if you have to stop and shower to have sex. You can go back to work in the shop clean. Except for your boys I mean. I usually get a sandwich made for me after sex. :thumbsup:. I guess that means I did it right. :bananadance:
  8. Sep 13, 2015 at 3:33 AM
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    ‘25 TRD OR/W-UpGrade Package.
    Another thing to do is when running the AC a lot, before shutting off the truck shut off the inside circulation switch. This lets most of the water to drain out. You can see the difference on a hard surface. Big difference in the cabin after the truck has been sitting. Hope this was helpful .
  9. Sep 14, 2015 at 8:17 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    sounds like your suicide door window may be leaking. check the hinge to make sure it's closing all the way and clamping the rubber seal
    abcoe524[QUOTED] likes this.
  10. Sep 14, 2015 at 9:13 AM
    powerofchez
    powerofchez Well-Known Member
    New Mexico
    04 Taco 4x4
    Pull the carpet on the back of the cab, put a bright flashlight underneath your truck, and put butyl tape on any hole you see, and cinch down all bolts, as those go straight through the floor, and the metal-metal is what creates a water seal. I had about a half dozen clip holes that needed covering, and several 10mm bolts were hand loose.
  11. Sep 14, 2015 at 9:15 AM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    You need to piss on your truck to show those cats that it is your territory not theirs.
  12. Sep 14, 2015 at 9:45 AM
    abcoe524
    abcoe524 New Member
    toyoya tundra 2004
    Awesome advice guys I appreciate it thanks. Lmao @pissing on my truck :rofl:
  13. Sep 14, 2015 at 10:00 AM
    Navelfunk
    Navelfunk Well-Known Member
    Phyllis
    WA
    '03 DC SR5 V6 4x4
    Cap, incorrect rims & tires, stereo...
