truck sputtering need help
Discussion in '1st Gen. Tacomas (1995-2004)' started by bubbasparkx, Jun 29, 2009.
  1. Jun 29, 2009 at 9:20 PM
    bubbasparkx
    bubbasparkx [OP] Member
    rancho cucamonga
    03 prerunner sr5
    rims and tires
    i have a problem with my truck!!!!! everytime i take off from a complete stop my truck starts sputtering from 1000 to 3500 rpms. i dont no what it is... it sounds like its miss firing but the plugs look fine. i have changed the fuel filter but that wasnt it.....
    PLEASE HELP!!!!!!!!!!!!!!!!!!!!!
  2. Jun 29, 2009 at 9:27 PM
    1999tacotrd
    1999tacotrd 1999 Taco TRD xtracab 3.4 V6 4x4
    Dose it hesatate then take off? cause mine is doing that and also sometimes when comeing to a stop it starts spurtting untill i hit the gas.
  3. Jun 29, 2009 at 9:30 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    might wanna seafoam the engine and see if that helps any
  4. Jun 29, 2009 at 9:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Is it throwing an Engine light? Are all the vacuum lines propperly connected, with no leaks?
  5. Jun 29, 2009 at 9:36 PM
    bubbasparkx
    rancho cucamonga
    03 prerunner sr5
    rims and tires
    no engine light and nothing is leaking and vacuum lines are connected and yes it does hesitate on take off i was thinking it might be the 02 sensors but im not sure
  6. Jun 29, 2009 at 9:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Check for a leak near the throttle body. the MAF could need to be cleaned as well. O2's will throw an CEL. Check the easy stuff first.
  7. Jun 29, 2009 at 9:40 PM
    bubbasparkx
    rancho cucamonga
    03 prerunner sr5
    rims and tires
    but wouldnt the maf throw on a cel
  8. Jun 29, 2009 at 9:40 PM
    beastlytaco
    Ian
    08 Access Cab SR5
    yeah see if your throttle body is dirty. and if so, seafoam that son of a gun
  9. Jun 29, 2009 at 9:40 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Not if its dirty.
  10. Jun 29, 2009 at 9:41 PM
    bubbasparkx
    rancho cucamonga
    03 prerunner sr5
    rims and tires
    thanks ill try that and see if it works
  11. Jun 29, 2009 at 9:43 PM
    bubbasparkx
    rancho cucamonga
    03 prerunner sr5
    rims and tires
    could you tell if the o2 sensors were bad by turning your key to the on position and check if they are warm or not
  12. Jun 29, 2009 at 9:45 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No. If it was your O2's, it would trip the CEL. Clean the MAF with some electronic contact cleaner, and see what happens. Have you done any work on you engine recently?
  13. Jun 29, 2009 at 9:47 PM
    bubbasparkx
    rancho cucamonga
    03 prerunner sr5
    rims and tires
    nope i have just been driving it and changing the oil and clean the air filter every now and then....
  14. Jun 29, 2009 at 9:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    ah HA! Your running a K&N, Im guessing?
  15. Jun 29, 2009 at 9:52 PM
    1999tacotrd
    If u figer out what it is besure to let me know mine says its buring lean it has cell light po172 on and i cleaned the MAF did'nt help a bit
    is seafoam bad for the motor couldnt it mess it up ?
  16. Jun 29, 2009 at 9:52 PM
    bubbasparkx
    rancho cucamonga
    03 prerunner sr5
    rims and tires
    nope lol i dont have money right now im only 16 with no job it sucks
  17. Jun 29, 2009 at 9:56 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    For a PO172 code:
    Inspect all vacuum and PCV hoses, replace if necessary
    Cleanthe MAF sensor. Consult your service manual for it's location if you need help. I find it's best to take it off and spray it with electronics cleaner or brake cleaner. Make sure you are careful not to damage the MAF sensor, and make sure it's dry before reinstalling
    Inspect fuel lines for cracks, leaks, or pinches
    Check the fuel pressure at the fuel rail
    Check the fuel injectors, they may be dirty. Use fuel injector cleaner or get them professionally cleaned/replaced.
    Check for an exhaust leak before the first oxygen sensor (this is unlikely to cause the problem, but it is possible)
  18. Jun 29, 2009 at 9:57 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ok...Double check the vacuum lines for leaks or cracks, check for leaks aroud the throttle body, and clean the MAF.
  19. Jun 29, 2009 at 10:11 PM
    bubbasparkx
    rancho cucamonga
    03 prerunner sr5
    rims and tires
  20. Jun 30, 2009 at 12:33 AM
    1999tacotrd
    Is there a VAC leak test kit?
