Truck squealing on start-up...
Discussion in 'Technical Chat' started by Tacomanator, Oct 21, 2010.
  1. Oct 21, 2010 at 4:52 PM
    Tacomanator
    Tacomanator [OP] Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    as the titile states, its squeals even louder when its cold outside, the squeal goes away after the truck is warmed up tho. not sure if its the fan belts or what :confused:
    anyone else experiance this? what could it be??
  2. Oct 21, 2010 at 4:57 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    nevermind... it is my belts. looks like ill be replacing those soon
  3. Oct 21, 2010 at 4:57 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    Before you start your truck, get a small cup of water and open your hood. Start the truck and when you hear the squeal, pour a little water on the belt. The noise should go away if it is the belt.
  4. Oct 21, 2010 at 5:02 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    thanks ill give that a try. after doing a search, im almost certain its my belt tho.
  5. Oct 21, 2010 at 5:07 PM
    AK27
    AK27 Well-Known Member
    sounds like the belt. mine was doing that
  6. Oct 21, 2010 at 5:46 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    ^^ yea, i guess i shoulda done a "search" first
  7. Dec 10, 2010 at 5:57 AM
    loudgonzo
    loudgonzo Member
    I have this problem too, belts replaced 3 months ago. Thought about the water spray, but the squeal lasts about 2-3 seconds then goes away. Even after running for a while, engine hot, turn the truck off, then back on, it will still squeal for a few seconds, then goes away. This only happens during when starting.
