Truck stalling after cleaning battery cables
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nj82701, Dec 26, 2016.
  1. Dec 26, 2016 at 3:57 PM
    Taco Addiction
    Taco Addiction We found Jimmy
    Houston, TX
    2004 Black TRD Offroad
    Kings, SCS Wheels and other mall crawling crap
    Hi. I have a question about tire pressure.. 88 psi ok?
  2. Dec 26, 2016 at 3:58 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Only on P rated tires. They have more flexible sidewalls and therefore can expand to hold the pressure better....
    I think. But I'm no expert.
    *obvious sarcasm*
  3. Dec 26, 2016 at 4:34 PM
    Bocsy44
    Bocsy44 Well-Known Member
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    This that and the other thing.
    could it be a problem with the alternator? just happened to crap out when he played with the battery? I have disconnected my battery before and never had restart issues after hooking it back up.
  4. Dec 26, 2016 at 4:42 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    Doubt it. The engine would keep running off the battery until the battery died... and then it wouldn't start at all.
  5. Dec 26, 2016 at 4:55 PM
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    true, but if the alternator isn't charging the battery its got no juice to run off of, but if that were the case i suppose he wouldn't really be able to get it running in the first place haha just spit balling some different theories to get people thinking
  6. Dec 26, 2016 at 4:59 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    @ahspurlock (Southeast TW mechanic) any input?
  7. Dec 26, 2016 at 5:08 PM
    WheelInTheSky
    WheelInTheSky Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
    Yeah, I've never encountered this either. Something like this would drive me f***ing crazy.
  8. Dec 26, 2016 at 5:10 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Guys, she (probably a 'he' to get immediate answers ) joined today just for us to solve a problem. Most likely has no intention of staying here and contributing to the TW family.
  9. Dec 26, 2016 at 5:14 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    K? Conspiracy much?
  10. Dec 26, 2016 at 5:20 PM
    WheelInTheSky
    G
    Jackson Hole
    Thank you, most worthless post ever!
  11. Dec 26, 2016 at 5:21 PM
    File IFR
    Central MA
    Nope, just street smart. Sorry to burst your bubble. The OP will never be heard from again on here..... you'll see.
    Ruggybuggy likes this.
  12. Dec 26, 2016 at 5:22 PM
    File IFR
    Central MA
  13. Dec 26, 2016 at 5:22 PM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    The ECU needs to relearn your driving habits. Just start it up. use your right foot on the go peddle if you need to, to keep it running. Then go for a short drive, then drive home. Shut it off for a minute, then restart and repeat. You may need to do this a few times. If that doesn't work, then post back. Good luck.
  14. Dec 26, 2016 at 8:06 PM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    ^^^ this. When power is cut the ECM's adaptively learned parameters (idle air, short and long fuel trims, etc.) will reset to default values--on older higher mileage vehicles it is not uncommon for such values to no longer be valid and new values will have to be learned. If things do not clear up after driving 25 to 50 miles ("normal" driving, not at high or steady speeds) consider replacing the spark plugs if not recently changed.
    Next the IAC valve may need to be cleaned/replaced (the IAC is key to reliable and smooth idle), also check for PCV and/or EVAP system or other intake vacuum leaks. If happiness is still elusive look into sluggish injectors and/or EGR issues...
  15. Dec 26, 2016 at 11:01 PM
    #35
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Clean the throttle body. this engine has a drive by wire throttle and does not have an IAC. the throttle plate (controlled electronically) is always slightly cracked open to allow a nice 750-800 rpm idle. this position is remembered in "adaptive" pcm memory. over time carbon/gunk builds up around the throttle plate making the opening for air to flow in smaller and smaller. the throttle plate position changes (opens wider) to account for the decrease in air flow as the carbon builds up. the problem begins when you come along and pull a battery cable. the pcm/throttle plate forgets its "learned" position and goes back to square 1. barely cracked open.. like when the truck was brand new and the inside of the throttle body was clean. now the throttle plate is buried in mud, no air can flow (at least not enough to sustain an idle) and it will start and die. yes you can drive it untill it "re-learns" on its own (and be that guy blocking traffic when his truck stalls out) or you can pull the air cleaner, get some carb cleaner (or maf sensor cleaner) on a rag and clean the inside of the throttle body and both sides of the throttle plate (gently hold it open w/ the handle end of a small screwdriver). a lot of times when i start the engine after doing this it will idle higher than normal for a couple minutes and then settle down.. cycle the a/c to engage the compressor, turn the steering wheel back and forth this "wakes up" the idle and forces it to adjust/settle into comfortable spot..
    do not spray carb cleaner into the intake. you can light your (plastic) on fire and nobody wants that..
    this is considered part of a battery replacement on most late model vehicles (everything is drive-by-wire these days) and folks don't want to hear "you may have to drive it for a while" after it stalls twice in the parking lot.
    landphil likes this.
  16. Dec 26, 2016 at 11:15 PM
    #36
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Yup. Clean the throttle body. Happens every time when we change battery's at the dealer. Clean the plate and area behind and in front of it with a rag. Don't spray directly into the Throttle, spray it on the rag.
    If you have two people, key on engine off have someone hold the gas pedal down. It'll open the throttle.. less of a pain. Less likely to mess up the motor in the throttle
    WebberLander likes this.
  17. Dec 27, 2016 at 3:15 AM
    #37
    ahspurlock
    ahspurlock The TW Mechanic
    Adam
    summerville.south Carolina
    08 T4R V8 Limited AWD on 37s
    Rear full long travel including upper and lower rear control arms. 37s Mickey Thompson Baja boss MT,
    you need to relearn the (ecu for idle reset) if you do not have a scanner like snapon or matco then
    remove the batt terms let it sit for 5 min then reinstall batt terms then trun key on but
    DO NOT START IT leave key on for 1-2 min then trun key off then crank it it should be fine at that point
  18. Dec 27, 2016 at 3:47 AM
    #38
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    clean everything
    maf
    throttle body
    maybe new plugs
    if it has a TPS sensor, get a new one
    what can happen is... as tps wears and maf gets dirty and even AF sensors...over time, the truck does learn
    how to run with [factory parameters and offsets the inputs from dirtier and worn sensors], and it
    can actually learn to run normal as stuff wears over time
    and then you reset the entire ECU, it goes back to factory fresh everything and then it
    runs like garbage because all the inputs are borderline and not dead-centered
    either that, or you disturbed a loose ground wire
  19. Dec 27, 2016 at 7:36 AM
    #39
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    this engine does not have a tps. tps is only needed when the throttle is controlled by a cable (the pcm needs to know what position your foot is in). forget about plugs, AF sensors, blah, blah, blah.. that stuff was working just fine before you pulled the batt cable off.. this guy is close, the engine does go back to factory fresh. as i stated, factory fresh position for the throttle plate is now buried in carbon..
    don't be the guy that throws a bunch of un-needed parts at a problem! it's funny at work because people don't want to pay for diagnostic time (they consider it a waste of money!) but they are perfectly fine w/ throwing sensors, fuel pumps, spark plugs, etc at the car with no idea if it's going to actually fix it..
    BrettBretterson likes this.
  20. Dec 27, 2016 at 7:45 AM
    #40
    Pabloeeto
    Pabloeeto Well-Known Member
    Paul
    San Diego
    06 DCSB TRD Sport 4x4
    K&N filter, 3.5 Aux input mod, Fox 2.0 Coilovers, Fox 2.0 Resi Shocks, Element UCAs, Old Man Emu Dakar Leaf pack.
    Yup ^^
    eccracer104[QUOTED] likes this.
