truck stalling on left turns only. lol.
Discussion in '1st Gen. Tacomas (1995-2004)' started by tularisgp, Jul 24, 2009.
  1. Jul 24, 2009 at 1:26 PM
    tularisgp
    tularisgp [OP] Member
    03 Tacoma
    so for some reason my truck stalls making left turns. not right turns. but hard lefts or U-turns. if i go right and stay right, im ok. haha. thought i was out of gas so i filled up the tank, still have issues. tried searchin the forum but havent seen anything.
    thanks in advance.
  2. Jul 24, 2009 at 1:28 PM
    98tacoma27
    Ben
    Not Beech Creek
    Welcome to TW
    Fill out your profile. We can help you best if we know they year, model and engine, what package......etc............etc.................etc.
  3. Jul 24, 2009 at 1:31 PM
    tularisgp
    03 Tacoma
    oh man sorry about that i just joined here, the truck has me stumped.
    its an 03 V6 4x4. i wanna say its SR5, but that might be wrong.
  4. Jul 24, 2009 at 1:32 PM
    98tacoma27
    Ben
    Not Beech Creek
    Auto or standard?
  5. Jul 24, 2009 at 1:32 PM
    98tacoma27
    Ben
    Not Beech Creek
    Does it completely die or just sputter?
  6. Jul 24, 2009 at 1:34 PM
    tularisgp
    03 Tacoma
    auto.
    itll sputter a bit sometimes. but if i make a U turn itll die completely and start right back up with no problem. i have a feelings its got somethin to do with the power steering because i noticed around the reservoir its wet. like its backing up through there.
  7. Jul 24, 2009 at 1:37 PM
    98tacoma27
    Ben
    Not Beech Creek
    I have heard of this once before but for the life of me I can't remember what it was.
  8. Jul 24, 2009 at 1:40 PM
    tularisgp
    03 Tacoma
    damn! well if you come up with something. im all ears.
  9. Jul 24, 2009 at 1:41 PM
    98tacoma27
    Ben
    Not Beech Creek
    In the mean time, check you fluid level if you haven't already. See if you can stall/sputter by turning left in the drive way.
  10. Jul 24, 2009 at 1:44 PM
    tularisgp
    03 Tacoma
    done and done. i was in a parking lot earlier doin circles. left turn circles are a no go. right, i can do it all day till im dizzy. left will either sputter and buck like mad or just flat die out.
  11. Jul 24, 2009 at 1:52 PM
    dman597
    dman597 Well-Known Member
    Doug
    maryland
    2012 DC 4X4 SPORT w/Tow
    6" Pro Comp Lift,295-75-R17,access rollup,Tint,front hitch,nfab step bars
    i had this problem with my caliber i took it to the dealer and they flashed the ecu and it fixed it. i dont know if this is what is causing your problem but i am just stating that i had simlar probs and thats how they fixed it on a dodge caliber
  12. Jul 24, 2009 at 7:28 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    Do you have an ex-girlfriend that hated your truck that you always used to turn left to get to her place to pick her up...?
    Just sayin...:)
  13. Jul 29, 2009 at 6:25 AM
    98tacoma27
    Ben
    Not Beech Creek
    Is your battery loose? Check the connections also.
  14. Jul 29, 2009 at 6:39 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Does it happen when turning, and stopped? It could be the idle up circut. When a load is applied to the engine via the steering pump, the idle up circut compensates by raising the engine speed.
  15. Jul 29, 2009 at 6:40 AM
    98tacoma27
    Ben
    Not Beech Creek
    I just can't see why it does it on left turns only?
  16. Jul 29, 2009 at 10:54 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I dont know either.....:confused:
  17. Jul 29, 2009 at 11:20 AM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    This is a long shot but maybe you have a loose wire and its ether grounding out or losing connection when you turn left. I had an ignition wire on my 4wheeler that went down from the handle bars and every time Id turn right it would kill the 4-wheeler cause it pulled the wire apart.
    I dont know what wire it would be that is doing this but just a thought!
  18. Jul 29, 2009 at 11:27 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Could be worth a shot.
  19. Jul 29, 2009 at 3:58 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    Dirty fuel sock
  20. Jul 30, 2009 at 6:47 AM
    98tacoma27
    Ben
    Not Beech Creek
    :confused:
    How would that affect his trucks on left hand turns only?
