Truck starts but only runs about 5 seconds?????
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kuneff, Dec 27, 2009.
  1. Dec 27, 2009 at 5:23 PM
    Kuneff
    Kuneff [OP] Carpe Diem
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    97 Tacoma, 2.7.
    It has been sitting about 4 years. I drained all the old gas and put 5 gallons of Exxon 93, and about 1/3 a bottle of Sea Foam. The truck fires right up, but only will run about 5 seconds. it idles and revs perfect for about 2-3 seconds then starts spitting and sputtering then dies out. Any ideas????
    New plugs, wires, air filter, fuel filter and fresh gas already.
    ***updated Info***
    Ok, fuel filter is in the correct direction of flow...
    I pulled the big line off the bottom of the fuel pressure regulator, and no fuel come out. I turn the key on, and still no fuel, I start the truck and still no fuel comes out. I took the regulator off and cranked the engine over... fuel everywhere...
    Is it possible that the pump is not delivering enough fuel for the truck to stay running let alone for the regulator to bleed out the excess???
    If the regulator is stuck closed, wouldn't the truck still run, just really rich?
    I pulled a spark plug and its black, but not wet at all, so I don't think its flooding or super rich either.
    and More...
    Fuel pressure is about 20 psi with the key on, and when running drops to about 15-18 before it dies out...
    So I bit the bullet and ordered a fuel pump and pressure regulator. I am just hoping to God that fixes it.
  2. Dec 27, 2009 at 5:24 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Any codes?
  3. Dec 27, 2009 at 5:24 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    sounds maybe like a fuel delivery problem to me. i know its a pita....but may need to check the fuel pump.
  4. Dec 27, 2009 at 5:31 PM
    Kuneff
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    My friend thats been helping me said the fuel pump also. He brought his tester over, but didn't have the right fitting for the truck.
    No codes...
  5. Dec 27, 2009 at 5:35 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    You can remove the hose off of the pressure regulator to see if it is working. Just have a catch can ready
  6. Dec 27, 2009 at 5:39 PM
    Kuneff
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    ^ok.. where is the regulator located and what will tell me if its working or not?
  7. Dec 27, 2009 at 5:42 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
  8. Dec 27, 2009 at 5:43 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    It will tell you if the pump is pumping.
    I remember you were also having vacuum line issues. Did you get them resolved also?
  9. Dec 27, 2009 at 5:44 PM
    Kuneff
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    cool, thanks.. So which end do I pull lose and what result shows me if it is working properly or not?
  10. Dec 27, 2009 at 5:45 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    The large hose with the clips on the bottom.
  11. Dec 27, 2009 at 5:53 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Breaks, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    This may be a stupid question but is the fuel filter pointing in the right direction?
  12. Dec 27, 2009 at 5:57 PM
    Kuneff
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    not a stupid question at all... I will check that tomorrow morning.
  13. Dec 28, 2009 at 11:35 AM
    Kuneff
    West Virginia
    Tacoma Woods Beater
    Tree Dents
  14. Dec 28, 2009 at 4:56 PM
    Kuneff
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    Anyone have any other suggestions?
  15. Dec 30, 2009 at 3:21 PM
    Tacojocoma
    Tacojocoma Member
    Los Angeles
    2003 PreRunner TRD
    Debadged, Kodiak Sidewinders
    Is there anywhere you might be able to go that is only 5 seconds away? : )
