truck starts by itself
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ryan c, Jan 7, 2012.
  1. Jan 7, 2012 at 2:37 PM
    ryan c
    ryan c [OP] rookie
    ryan
    661 Lake Ez
    '06 4x4 swb dc
    2.5" lift in front, aFe air intake, anytime foglights, cut 9" off antenna, superwhite headlights, spintech exhaust, med. tint in the front, weathertech floorliners and caltech seat covers, dashtek dash cover, CHLM, debadged and destickered,
    hey guys, ive had my truck for over 2 years now and occasionally have had problems with the auto start. quite often ive awoke in the middle of the night cause my fog lights turned on randomly. and a few times ive actually had my truck start up by itself. i have a viper auto start. anyone heard of this?
  2. Jan 7, 2012 at 2:41 PM
    dubbedSinner
    dubbedSinner blisters
    Lowered 3/4, debadged, led tails, projector headlights with hids, billet grill, blacked out windows, painted front and rear bumper and grill shell. Inside, 4 crappy 15's, suede wrapped headliner and door panel inserts, alpine double din, few painted pieces inside, and every led is either blue or white.
    I would check all the wire connections, would be a pain to do especially if you didn't install it but it sound like something is possibly getting power when it shouldn't be.
  3. Jan 7, 2012 at 2:43 PM
    theredofshaw
    theredofshaw Well-Known Member
    Reno/Sparks, NV
    2016 Honda Civic (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    this would be my answer.
  4. Jan 7, 2012 at 2:44 PM
    TeamSarcasm
    TeamSarcasm Flawless Escalation to the Ludicrous
    The better coast
    Is that a remote start? Maybe its getting a signal from a neighbor. My garage door did that and we couldn't figure it out till my neighbor opened his door and mine opened at the same time.
  5. Jan 7, 2012 at 3:17 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    sell it and but an american.......they have a hard time starting when you turn the key.:laugh: jk,take it back to who ever put the viper on it,they might be able to change the frequency on your transmitter.
    TacomaZL likes this.
  6. Jan 7, 2012 at 3:18 PM
    TacomaPrime
    TacomaPrime Cybertronian Tacoma
    Greg
    Illinois
    05 Prerunner SR5 TRD off road
    That would be AWESOME!
  7. Jan 7, 2012 at 3:21 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Your Truck is haunted..... Might have to do an exorcism or some shit...
  8. Jan 7, 2012 at 3:23 PM
    Forster46
    Forster46 Very nice how much?
    Nick
    Mount Vernon, WA
    The doritos locos taco
    6000k HID's, AUX Reverse Lights, 3" Rough Country Suspension Lift, Pioneer AVH-P4200 Double Din, Underglow and footwell Lights, Camo Seat Covers, Duralast Tool Box, Blacked Out Badges, Grill, Front Emblem, Midland CB Radio, Amber Strobes, POWER REAR WINDOW, cup holder LED's, Firestik 3' in bed, console divider, Ultragauge.
    It must be a decepticon.
  9. Jan 7, 2012 at 3:40 PM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2009 4x4 Access Cab, TRD Sport
    These things have a setting that will start the motor when battery voltage drops past a specified level in order to charge it up a tad. If you somehow have that feature enabled and if your battery is weak and it is cold at night, well there you go.
    My older Clifford also has a timed start function as described here. If you had inadvertently enabled this it might also do something similar.
    3-14 TIMER MODE—TIMED STARTS/TEMPERATURE STARTS: The system will start every 3-hours until canceled
    by the brake, hood, or neutral safety shut-down wires (a maximum of 6 times). The temperature start
    mode will not start the vehicle unless the interior temperature of the vehicle is less than 0 degrees F. The temperature
    start mode will exit after 18 hours
  10. Jan 7, 2012 at 3:43 PM
    jdtemple
    jdtemple Well-Known Member
    Bay Area CA
    08 DBLCAB LB TRD Sport
    Lift & Tires, in cab power outlets, Locking Bed Boxes, K&N
    I call bullshit on that.
    You know how many people would be dead because of carbon monoxide poisoning from cars parked in the garage that started up to charge a battery.......
    In the winter my garage will freeze bottled water.
    jmaack likes this.
  11. Jan 7, 2012 at 3:50 PM
    Raylo
    MD, USA
    Post above should have said "some" RS systems do this. Not saying his specific RS model has it, but some do. Here is a thread that lists several brands and models that do this. Just something else to check before you go digging into the wiring and relays.
    http://audioforum.termpro.com/topic/15/164.html
  12. Jan 7, 2012 at 3:55 PM
    ryan c
    ryan c [OP] rookie
    ryan
    661 Lake Ez
    '06 4x4 swb dc
    thanks for the input guys.yah 1 salesman told me that viper product was recalled. 2 other people now have told me it wasnt recalled. i bought the truck used and there is no info on the alarm system. could be a transformer as that was my initial thought too. as well as thinking someone was stealing it. i live in a rural area so it cant be a neighbors signal. maybe electrical but i dont know.
  13. Jan 7, 2012 at 3:58 PM
    Raylo
    MD, USA
    And here is a link for one DEI RS product that does specifically have a low volt start. I had one similar to this on my last truck which is where I recall seeing the feature for the first time. As I said, just one possible cause to eliminate that would be easy to check.
    http://www.adelcom.net/CLIFFORD-909005 Intellistart-Page.htm
  14. Jan 7, 2012 at 3:58 PM
    jdtemple
    Bay Area CA
    Wow, that is crazy, and a lawsuit waiting to happen.
  15. Jan 7, 2012 at 4:01 PM
    Raylo
    MD, USA
    Might be valuable if you lived in North Dakota and had to park somewhere you that you couldn't plug in your engine heater.
  16. Jan 7, 2012 at 4:02 PM
    Texoma
    Texoma IG: cwehlin
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Look online on their website for the operators manual. Remote starters have an option for automatic start on a timer. You set it with your 2 way key fob
  17. Jan 7, 2012 at 4:19 PM
    jackhart
    jackhart Well-Known Member
    11 DCLB
    i had several companies refuse to install my remote starter in my stick shift truck because of liability issues. i mean if you left it in gear and you then later remote started it, you could potentially kill someone.
  18. Jan 7, 2012 at 4:22 PM
    Raylo
    MD, USA
    T'would be ugly! Same with timed start. I assume the modern systems require the same interlocks to be installed and procedures to be followed as they do for any manual tranny install where you have to do a certain sequence before you leave the vehicle to be able to remote start it before next disarm. It is like the Windows dialog box that asks "are you really sure you want to delete that file? (remote start this car?)".
  19. Jan 7, 2012 at 4:31 PM
    acdronin
    acdronin Well-Known Member
    Stephen King called, he wants his truck back
  20. Jan 7, 2012 at 4:37 PM
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    do you have the foglight anytime mod? because depending on how you wired it up, that can explain why your foglights turn on randomly
