Truck starts for 2-3 seconds then stalls. Need help.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Maximus82, Nov 22, 2016.
  1. Nov 22, 2016 at 9:48 PM
    Maximus82
    Maximus82 [OP] Member
    Aaron
    1996 Tacoma 4WD 2.7L
    None
    I have a 1996 Tacoma with 2.7L engine. Recently, I had to replace the MAF sensor, the alternator and the battery. After getting this done, I went to start my truck, it started for 2-3 seconds, and then just died. I listened near the tank when my wife started it once and I could hear the fuel pump running. I am running out of diagnosis ideas...
    I wanted to see if anyone have a good idea or has run into this problem yourself, before I go buying a bunch of parts. Any help would be much appreciated!
    (Haven't seen any related posts on the forum.)
  2. Nov 22, 2016 at 9:52 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    It is not uncommon when replacing the battery for your ECU needing to relearn some basic engine operating info. Start your truck, and put your foot into the gas just enough to keep it running at something around 2k RPM (in park/neutral) for roughly one minute. The ECU should re-learn what it needs and your truck will idle on its own again.
  3. Nov 22, 2016 at 10:53 PM
    eon_blue
    Azusa, CA
    If that doesn't work then I'd look into the MAF sensor you just installed, maybe it got dirty somehow when you were putting it in (the sensor itself is extremely sensitive). Maybe try cleaning it with MAF cleaner
  4. Nov 22, 2016 at 10:53 PM
    eon_blue
    Azusa, CA
    Did you replace the MAF sensor yourself?
  5. Nov 23, 2016 at 2:46 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Is the Malfunction Light On if so pull the code
  6. Nov 23, 2016 at 3:06 AM
    Indy
    Indy Master of all I survey.
    Make sure the maf is actually connected and in stream. Thats exactly the behavior you get if the intake tube isn't hooked up. you can usually force it to keep running, badly, by working the throttle but it won't keep runnibg or get any better.
  7. Nov 23, 2016 at 8:33 AM
    jschenck
    jschenck New Member
    Omaha NE
    1999 SC 2.7 4x4 manual
    31x10.50
    If you turn on the defrost (or the AC) it'll kick up the idle a bit - may help troubleshoot this issue.
  8. Nov 23, 2016 at 11:15 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Any time I had this happen the MIL is tripped P1300 the ECM does not see the Igniter Signal so the fuel is shut off.
    Starts and shuts off it will do this to the battery is dead unless the problem is fixed.
    A few other codes will shut off the fuel as well without looking I can`t recall them
  9. Nov 23, 2016 at 11:20 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I had to change an igniter once and the truck ran for another 10 years (then another 10 years after I sold the truck) and check the ground wires are clean
  10. Nov 23, 2016 at 6:57 PM
    Maximus82
    Aaron
    None
    Thanks for all the help guys! I did recently replace the MAF sensor and put it in myself and kept it in the packaging until install, to keep it clean. I did notice after it started I forgot to tighten the air tube connecting to the MAF (dumbass move), so I tightened it down real good. I will try some of your tips tomorrow morning when I get off work and see how they work. Thanks again! Updates coming soon.....
  11. Nov 26, 2016 at 10:36 AM
    Maximus82
    Aaron
    None
    Ok guys, so I finally got around to messing with my truck and I figured something out. So with all the new equipment the truck acts as I posted; but, if I disconnect the MAF, the truck runs. It runs like it has no MAF but it will stay running. Does that mean that I got a bad part or am I missing something?
  12. Nov 26, 2016 at 10:41 AM
    eon_blue
    Azusa, CA
    May be a bad sensor, but try cleaning it with MAF cleaner before writing it off just to see if maybe it got dirty somehow.
    If that doesn't work I'd pick up another one and give it a shot, if it works you know you got a bad one the first time and hopefully you can return it.
  13. Nov 26, 2016 at 10:43 AM
    Maximus82
    Aaron
    None
    I'll try the cleaner. I tried to start the truck and then reconnect the MAF and it died immediately.
  14. Nov 26, 2016 at 10:44 AM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    My guess would have been the old banana in the tail pipe trick...
  15. Nov 26, 2016 at 10:46 AM
    Maximus82
    Aaron
    None
    I'll check that too, lol.
  16. Nov 26, 2016 at 11:15 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    At no time are you getting a code??
  17. Nov 26, 2016 at 12:17 PM
    Maximus82
    Aaron
    None
    Ok just got back from advanced auto. The guy said I had the MAF circuit code, but it was disconnected. I cleaned the MAF with the cleaner and changed the air filter, but when I plug in the MAF or try to start the truck with the MAF plugged in, it stalls. I guess I'll have to replace it again, because I can not think of anything else...
  18. Dec 18, 2022 at 1:39 PM
    wellsf
    wellsf Well-Known Member
    Lexington, MS
    1999 Toyota Tacoma V6 3.4L SR5 manual 4x4
    So I’m having the same exact issue it will crank for literally 2 seconds then die. It’s a never ending loop. Unplugged the oem MAF and boom it runs. Headed to get a new MAF.
  19. May 3, 2023 at 3:33 AM
    Rebelsaint
    Rebelsaint Member
    Arizona (Winslow & Tucson)
    99 Taco ex cab 3.4, 6 lug, 2wd, 1st Gen
    Same here so frustrating!!!! I did however see that one of my valve cover bolts didn’t look right. I couldn’t believe it but everyone of them I could move with my fingers (except for 2 because couldn’t reach them). But that didn’t fix crank start die! I no longer have the codes p0100 or p0110 but still won’t run either!!
  20. May 3, 2023 at 4:55 PM
    F.I.LetsGoFishing
    F.I.LetsGoFishing Well-Known Member
    95.5 4wd 3rz mt
    Neglected Original
    check the tube that runs from the air cleaner to the plenium, any air leaks will cause a stall. when mine cracked, it was the same as what you have explained. but if I held the accelerator for a minute i could let off the gas and maintain idle but if i shut the ignition off and tried to restart (even just seconds) I would be back at square one with holding foot on gas pedal.
    Rebelsaint likes this.
