Truck starts, power to rear wheels, won't go anywhere...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mahmer09, Apr 22, 2019.
  1. Apr 22, 2019 at 2:19 PM
    Mahmer09
    Mahmer09 [OP] Well-Known Member
    Ladera Ranch, CA
    2017 TRD Off Road 4x4 DBLB (Super White)
    Hey!
    I have a 2017 TRDOR 4X4, 23,200 miles. I haven't been off-roading lately. This morning, I start my truck, no parking brake, put it in drive, I can feel power to the rear wheels but it feels like there are blocks under my front wheels, it won't go anywhere. I even got out to check. No blocks. I turn it off, try again and again. Same thing. The truck will not move, it feels like the front brakes are pressed but I assure you they are not.
    Finally get it towed to local Toyota dealership. I am at work at this point and they turn it on and no problems. WTF!? This has happened before but I was able to just turn it off and back on and it was fine. Anyone hear of this before? What is going on?
    Thanks for any thoughts/info.
  2. Apr 22, 2019 at 2:25 PM
    I.eat.tacos
    I.eat.tacos Well-Known Member
    Steve Rogers
    '18 TRD 4x4 Sport
    Possible chance your truck might still be engaged in 4lo?
  3. Apr 22, 2019 at 2:25 PM
    KGTaco
    KGTaco Well-Known Member
    Southern California
    2019 Tacoma TRD 4x4 Offroad
    King 3.0/Bumps/Deavers/33s
    This is for sure weird
    Do you use your parking brake when you Park? & If so, at what point do you release it? After you change gears or before?
    Mully likes this.
  4. Apr 22, 2019 at 2:40 PM
    Jes
    Jes Well-Known Member
    Knoxville
    2017 Taco TRD Pro Cement
    This happened to me once. I actually spun the rear tire trying to pull out of a parking space, then got out to check under the truck. Thought I was going crazy.
    After a restart it drove fine. That was 3-4000mi ago.
  5. Apr 22, 2019 at 2:52 PM
    Mahmer09
    Ladera Ranch, CA
    No, it was not in 4lo. I thought it might be 4 wheel drive related.
  6. Apr 22, 2019 at 2:54 PM
    Mahmer09
    Ladera Ranch, CA
    Just got contacted by dealership, passenger rear drum brake. Guess my intuition was off, haha. Something causing it to actuate on its own I guess?
  7. Apr 22, 2019 at 2:54 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    ABS locked up.
  8. Apr 22, 2019 at 2:55 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    When you parked the truck did you engage the parking brake? Then disengaged and tried to drive but it wasn’t going anywhere?
    Or was the parking brake never engaged at all.
  9. Apr 22, 2019 at 2:57 PM
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    Stuck parking brake cable? I had that happen once on an old Colorado that I used to own. Since was an automatic transmission I never use the thing and it got rusty, and then I guess I pressed it once and it seized up.
    Big tall dave and EatSleepTacos like this.
  10. Apr 22, 2019 at 3:55 PM
    FritoBandito
    FritoBandito Well-Known Member
    Texas
    2016 Limited 4X4 DCSB
    I have an auto and still set the parking brake every time I park. Drove a manual for years and it’s just a habit.
    Big tall dave likes this.
  11. Apr 22, 2019 at 3:57 PM
    eon_blue
    Azusa, CA
    If there's power going to the rear wheels then they would be spinning...are you saying they're spinning but the truck isn't moving? My guess then would be a frozen parking brake or issue with the drums.
    If the wheels aren't spinning at all then something's probably up with the transmission, sounds like it's stuck in neutral
    edit: nm I see you already got it figured out in another post
