Truck Starts Then Dies in 2-3 Seconds
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoguy1993, Jun 8, 2021.
  1. Jun 8, 2021 at 12:57 PM
    truchador
    truchador Well-Known Member
    Otto
    WV
    15 DC OR
    weathertech, seat covers, scratches
    Wow this forum is a wealth of helpful knowledge :)
    Marc70, tacotoe, Mmaira2018 and 6 others like this.
  2. Jun 8, 2021 at 1:46 PM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Pretty incredible right
  3. Jun 8, 2021 at 2:23 PM
    Tacoguy1993
    Tacoguy1993 [OP] Active Member
    Western KY
    2021 Army Green TRD Sport DCSB
    I'm getting anywhere between 0.8 and 1 on the reading.
    tacotoe and T-yoda like this.
  4. Jun 8, 2021 at 2:28 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Yeah, that is just outside of the specified range.
    And that is with the resistor at 68 F’.
    I’d jump the connector and make the call that way.
    I don’t trust or have confidence in the “test procedure”.
    In your case, it’s simple enough to check “what works”. As in - Jumping the connector.
    Then find a local salvage yard and get a used one. (If you want to go cheap)
    tacotoe, Too Stroked, T-yoda and 2 others like this.
  5. Jun 8, 2021 at 3:15 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Yeah just jump the connection (either at the plug for the resistor or the relay location like mentioned JUST MAKE SURE TO DO THE PROPER PINS AT THE RELAY) and see if it works.
    tacotoe and TnShooter like this.
  6. Jun 8, 2021 at 9:17 PM
    Taco'09
    Taco'09 Well-Known Member
    OP, I am just a bit curious. Was the original fuel pump replaced with an OEM or some other lower cost aftermarket?
    tacotoe, MarX and Mmaira2018 like this.
  7. Jun 9, 2021 at 2:56 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    yup, better than any mechanic because everyone on here has years/decades of knowledge and genuine love for our trucks
    Marc70 and tacotoe like this.
  8. Jun 9, 2021 at 5:12 AM
    Tacoguy1993
    Western KY
    I believe both have been aftermarket.
  9. Jun 9, 2021 at 11:23 AM
    Waasheem
    Waasheem
    2007 xrunner
    Oh dang.
    Well let us know what fixes it. Guessing the resistor.
  10. Jun 9, 2021 at 12:16 PM
    Tacoguy1993
    Western KY
    Ordered a new resistor last night, will update when it arrives.
    tacotoe, MarX and PzTank like this.
  11. Jun 9, 2021 at 12:57 PM
    Tacoguy1993
    Western KY
    Hate to admit it but I gapped the new iridium spark plugs and just now read that may damage them. Guess I'll take them out and check them.
  12. Jun 9, 2021 at 1:03 PM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    gapping should not hurt the plugs. That's how you measure the effectiveness of the plug.
  13. Jun 9, 2021 at 1:41 PM
    Tacoguy1993
    Western KY
    While I wait for that resistor, has anyone had any similar results with a bad throttle position sensor?
  14. Jun 9, 2021 at 1:56 PM
    nd4spdbh
    SoCal
    Have you tried simply making a lil jumper to bypass the resistor (unplug it and put the wire in place?)
    TnShooter likes this.
  15. Jun 9, 2021 at 2:09 PM
    #35
    Taco'09
    The TPS is actually a system that is part of the throttle body and the accelerator sensor in an electronic form and unlike an actual TPS many are familiar with on earlier cars that could be replaced as a spare part and/or adjusted.
    For this reason I would recommend not digging into and destroying the throttle body as it is sealed and $$$. I'm not sure there is anything inside that could be adjusted anyway.
  16. Jun 9, 2021 at 3:17 PM
    #36
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    On iridium tipped spark plugs the iridium is a Very Hard material and that makes it very brittle and subject to breakage and shattering. That is why they do not recommend gapping them.
    https://www.densoautoparts.com/spark-plug-installation
    Before attempting to gap any DENSO Iridium Power spark plug, please review the specification chart in the front of this catalog to verify the factory-preset gap. In most cases your Iridium Power plugs do not need to be gapped. Even with small variations in the factory set gap the ultra-efficient firing power design will compensate for those small variations. Should you decide to re-gap your Iridium Power plug, use extreme caution as improper gapping may damage or destroy the Iridium center electrode or porcelain center.
    T-yoda, tacotoe and Too Stroked like this.
  17. Jun 9, 2021 at 3:29 PM
    #37
    nd4spdbh
    SoCal
    Also, dont run the Irridiums in the v6 unless supercharged. Standard ones will work better and be cheaper. No need to change them out now as they wont cause a run then die issue like you are having.
    Tacoguy1993[OP] and tacotoe like this.
  18. Jun 9, 2021 at 4:11 PM
    #38
    Waasheem
    Waasheem
    2007 xrunner
    A parts guy I was jokingly complaining about my plugs not being pregapped properly opened every one and slammed the gaps closed. We poked fun at each other like that so it wasn't that big a deal.
    I'm not sure what harm it would do, probably none, to stick a bypass wire in place of the resistor. That is if your hurting without the taco.
  19. Jun 10, 2021 at 8:10 AM
    #39
    Tacoguy1993
    Western KY
    I did do that and it runs, it's just hard to tell if that's the problem because it seems to be intermittent. Is it safe to drive with the jumper wire in place? If so, I will try that when I get home and see how it runs. Also, after the last fuel pump was replaced it seemed like the RPMs were a little jumpy, it'd drop below 500 for a second while slowing down and then jump back up.
  20. Jun 10, 2021 at 8:14 AM
    #40
    nd4spdbh
    SoCal
    Yeah just make sure the jumper wire is sufficient in size (similar to the harness side wire size) and that its secured in place well (put some electrical tape around it) so the jumper doesnt fall out or short to a ground. This will simply run the pump at full speed and yes it will cause more wear, but for a couple days of driving there shouldnt be any issues on the fuel pump over the life of the pump, so long as its not an already failing pump.
