truck starts then dies
Discussion in '1st Gen. Tacomas (1995-2004)' started by ericjames, Sep 7, 2010.
  1. Sep 7, 2010 at 9:55 AM
    ericjames
    ericjames [OP] Member
    Eric
    Alabama
    The truck started to have a slight hesitation only when cold and did not do it til I would start down the road.Well it got worse and finally would not stay cranked after started. I replaced the plugs,fuel filter,dist. cap and rotor. I pulled the return hose off the regulator and it has alot of gas flowing out of it. I put vice grips on the return hose and it stays running so out of curiosity I put a pressure gauge on that line with a valve behind it and fully closed it had around 80 psi. so I dont think it should be the fuel pump. I was just wondering if anyone might have a clue what it is before I start replacing stuff. I have already priced a regulator witch is what I thought it was said they could one in the morning
  2. Sep 7, 2010 at 10:21 AM
    tacosuprem
    tacosuprem Well-Known Member
    Florida
    4x4
    more info on your truck year, motor, miles.....
  3. Sep 7, 2010 at 10:51 AM
    ericjames
    Eric
    Alabama
    sorry about that its a 1995 tacoma 4x4 2.7l with 150k
  4. Sep 7, 2010 at 11:07 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    maybe the fuel filter?
  5. Sep 7, 2010 at 11:20 AM
    Danosabre
    Danosabre Well-Known Member
    Dan
    Gardner,Ma
    09 TRD Off Road
    Extang Trifold bed cover,DDM 55W 6000k HID, maglight, Vent visors
    Make sure you are getting a good healthy spark.
  6. Sep 7, 2010 at 12:33 PM
    ericjames
    Eric
    Alabama
    If I close the valve a little and hold around 70 psi on the return line it runs perfect . I was gonna check the o2 sensors but they are not gonna come out easy,the nuts are about rusted off. I just cleaned the mass air and the throttle body. no change
  7. Sep 7, 2010 at 2:01 PM
    Sirlight
    Sirlight 1337 h4x0r
    Orange County, CA
    2004 PreRunner Xtra Cab
    STOCK
    IACV?
    If you hold the throttle till the motor is at normal op temp, what happens then? motor stay running ? any CEL's ?
  8. Sep 7, 2010 at 3:04 PM
    ericjames
    Eric
    Alabama
    I took the o2 sensors out and cleaned them with carb cleaner and it works fine now not sure how it would have affected the truck so much . now I have a p0125 code but the thermostat gasket is leaking a lil bit I am going to fix that and see if that fixes it . Also anyone have a online service manual they could send me!
  9. Sep 7, 2010 at 3:37 PM
    Sirlight
    Sirlight 1337 h4x0r
    Orange County, CA
    STOCK
    The link for the service manuals for our trucks is at the top of the main page stickied. Here it is Good luck.
  10. Sep 7, 2010 at 4:43 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    i recently started having the same problem. the truck seems to want to quit as soon as it starts sometimes it actually does quit then is hard to get going again. cleaned the mass air but doesnt make a difference. i was just about to start a new thread but then i seen this,hope ya dont mind OP.
  11. Sep 7, 2010 at 6:08 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
  12. Sep 7, 2010 at 7:24 PM
    ericjames
    Eric
    Alabama
    I dont mind at all I need all the help I can get , I cleaned the upstream sensor it runs now but it still is not right.It still lacks the power it had but it runs still has the code p0125 from what i gather is the o2 , I guess I might go get a new o2 sensor tomorrow the had the up stream for $118 and downstream for $142.I know I could probably get one a little cheaper somewhere but I dont like to wait
  13. Sep 8, 2010 at 1:04 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    ive got new o2 sensors so i know its not that. my cel isnt on, so i guess ill try changing the fuel filter its probably the same one since the truck was made anyway.
  14. Sep 8, 2010 at 7:14 PM
    ericjames
    Eric
    Alabama
    New upstream o2 sensor problme solved . but I have a new code P0420. I think it may be due to the fact that it has no cat. on it
  15. Sep 9, 2010 at 4:38 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    ^nice. yah your definitly getting that code because of the missing cat, you can get rid of that with the URD simulator though.
    i changed my fuel filter tonight hopefully it fixes me up.fingers crossed
