truck starts then dies
Discussion in '1st Gen. Tacomas (1995-2004)' started by 97st8axletacoma, Nov 23, 2023.
  1. Nov 23, 2023 at 2:58 PM
    97st8axletacoma
    97st8axletacoma [OP] Member
    randy
    97 3.4 straight axle swap tacoma
    never ran into a problem like this i’m stumped my truck died on me after changing the battery ended up changing the alternator,fuel filter,fuel pump, and maf but still won’t crank only time it would is when i give it gas only things i can think of is idle air control valve, fuel injectors, and ignition coils any advice would help also happy thanks giving
  2. Nov 23, 2023 at 2:59 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    If it works when you throttle it, yes, I would look at IAC, or you can adjust the throttle plate
    97st8axletacoma[OP] likes this.
  3. Nov 23, 2023 at 5:38 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    You might have just forget to mention if you pulled any codes?
  4. Nov 23, 2023 at 7:20 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
  5. Nov 23, 2023 at 7:28 PM
    O'Silver_Taco
    MD
    Next I'd investigate the other engine sensors......ect sensor...
    then throttle position sensor ....
    these engines are pretty simple......but they don't like non-oem engine sensors...
    you know the ones they sell for 1/10 the price of the real ones.....
    A scanner that reads live data....can take a lot of guess work out of it...
    https://www.amazon.com/BlueDriver-B...cint=&hvlocphy=&hvtargid=pla-4584070138336563
  6. Dec 5, 2023 at 8:16 PM
    97st8axletacoma
    randy
    the code i pulled was the maf sensor P0101. i changed the Iac and cleaned the throttle body still no start. i just changed fuel injectors and it still does the same thing cranks on than dies very stumped on this one
