Truck starts, wont turnover now I can’t turn it off
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cullenff, Feb 8, 2023.
  1. Feb 8, 2023 at 3:38 PM
    Cullenff
    Cullenff [OP] New Member
    2019 TRD Pro.
    I tried to start my truck, no prior issues besides key fod battery(I changed it). The truck starts but does not turn over and clicks. After that every light and warning comes on. My truck is now stuck on. Every time I pushed the ignition it clicks and warnings flash. The vehicle thinks I’m trying to turn it over.
    MGMDesertTaco likes this.
  2. Feb 8, 2023 at 3:40 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Welcome to the forum. Disconnect the battery and have it tested. Funny electrical issues come from dying batteries.
  3. Feb 8, 2023 at 3:42 PM
    Gatafly
    Gatafly Well-Known Member
    Shawn
    2020 TRD OR AT V6 MGM
    Maybe battery is bad and the low voltage is causing the warning flashes. modern vehicles can be very finicky to low voltages.
  4. Feb 8, 2023 at 3:43 PM
    MGMDesertTaco
    That fast clicking sound is a sign your battery is dead. I swapped mine for an ever start 24f agm from Walmart. I think it was about $150-$170 and comes with 4 years free replacement warranty. Also using an off grid engineering battery strap, but the oem battery strap will still work in the meantime.
    Cullenff[OP] likes this.
  5. Feb 8, 2023 at 4:15 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Lt. Dangle and Chew like this.
  6. Feb 8, 2023 at 5:00 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    1) Your terminology is a bit confusing. Typically when someone says their engine starts they mean it turns over and starts running like normal.
    2) it’s normal for a bunch of dash lights to be on if the ignition is on but the engine is not running.
    3) a clicking sound upon engaging the starter typically means you have a dead battery
    4) a dead battery doesn’t necessarily mean the battery requires replacement. It could just need a recharge. But it’s evidence that the battery needs replacement
    CAVEAT: I’ve never had a push to start automobile.
  7. Feb 8, 2023 at 5:13 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    This is the second post I’ve seen about this issue this week. Does your truck lock and unlock?
  8. Feb 8, 2023 at 5:18 PM
    bockafer
    bockafer Well-Known Member
    Earth
    22 Limited 4x4 MGM
    Did you take your foot off of the brake when trying to turn off the truck with the push start button?
  9. Feb 8, 2023 at 5:25 PM
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    Sounds like the hydraulic traction compressor is out of phase. :thumbsup:
  10. Feb 8, 2023 at 5:40 PM
    Cullenff
    It does not lock. Radio was on
  11. Feb 8, 2023 at 5:50 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Find the ign fuse and pull it out.
  12. Feb 8, 2023 at 5:52 PM
    MGMDesertTaco
    It's the battery. :facepalm:
    brandon78lusch likes this.
