Truck sticks then loud BAM and it moves
Discussion in '1st Gen. Tacomas (1995-2004)' started by glsmaverick, Dec 27, 2011.
  1. Dec 27, 2011 at 10:48 AM
    glsmaverick
    glsmaverick [OP] Well-Known Member
    Howell MI
    96 Taco; 2.7l 4x4 5spd
    None
    So I have a 96 Taco 4x4 2.7l 5spd.
    A while back the truck just setting in my driveway or the parking lot at work would be hard to get moving. I give it some rev's and BOOM a loud break loose type sound would come about and it would move. This only happens after setting for 5+ hours and is independant of the temperature.
    I took it to the dealer a while back and they checked the e-brake and it was stuck so they relieved that, replaced a rear axle seal and told me all was good. I pulled away and for a couple weeks it was fine.
    It started to stick again and is getting progressively worse. So I take it back to the dealer; told them they did a shit job and to take another look because they obviously didnt fix the problem.
    I just got off the phone with the guy and he tells me the front calipers are sticking and need to be replaced. I luckily have no issue doing brake work and can handle this one. What I am wondering is; do you guys think that is the problem. I can pick up the calipers on the way home from work or order them but do not want to waste money on that if it isn't the problem
    Any help would be greatly appreciated ASAP!
  2. Dec 27, 2011 at 10:53 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    On mine, its the E-Brake. Happens if it gets wet and rusts in place. Normally when I wash the truck I'll leave the E-Brake off so it won't stick...
  3. Dec 27, 2011 at 10:54 AM
    glsmaverick
    Howell MI
    None
    Yeah its not the ebrake. It happens if I leave the ebrake disengaged and just throw it in first when I park.
  4. Dec 27, 2011 at 10:57 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Hmmm... Now that I think about it I kind of remember someone talking about this, but I forget what it was. I'll have to try to find it.
  5. Dec 27, 2011 at 11:14 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Problem: Michigan
    Solution: Move south.
  6. Dec 27, 2011 at 11:14 AM
    glsmaverick
    Howell MI
    None
    Yeah thanks for the completely pointless reply
  7. Dec 27, 2011 at 11:18 AM
    macgyver
    Brad
    Canton, GA
    You're welcome. :D However, it's probably the cold thats making them stick. You could try rebuilding the calipers yourself, however it's usually easier to buy some already re-conditioned calipers from your local auto parts store instead.
  8. Dec 27, 2011 at 11:33 AM
    glsmaverick
    Howell MI
    None
    It is not dependent on weather or temperature.
  9. Dec 27, 2011 at 11:41 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    I can't seem to find the thread I was talking about, but I know it was on here somewhere. If you have the time search around and you should be able to find it.
  10. Dec 27, 2011 at 11:45 AM
    glsmaverick
    Howell MI
    None
    What are you searching under deevon? I tried search for a while and couldn't come up with anything.
  11. Dec 27, 2011 at 11:46 AM
    moblarkus
    moblarkus Well-Known Member
    Mark
    British Columbia, Canada
    '06 Black Sand Pearl TRD Off-Road
    Satoshi grille, All-pro bumper, Allpro UCA's, Walker Evans coilovers, 10" Lightforce Blitz, PIAA 510's,Magnaflow cat-back, K&N CAI, Revtec rear blocks. TSB leafs, Firestone Ride-Rite air springs, Hopkins Agility brake controller.
    Wheel cylinders?
  12. Dec 27, 2011 at 11:47 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    I looked for a few things... Stuck truck stuck e brake... anything I could think of that would pop it up... I just don't have the time to look through them all. But like I said I know there is a similar thread. Its here.. just keep looking.. :)
  13. Dec 27, 2011 at 11:49 AM
    glsmaverick
    Howell MI
    None
    The dealership went over the rear brakes last time and said they looked good. That's how they found the bad axle seal and ebrake. The calipers aren't terribly expensive so unless someone comes up with a "this has happened to me before and here's how I fixed it" solution I will probably proceed with that.
    Keep the suggestions coming!
  14. Dec 27, 2011 at 12:00 PM
    TnRedNeck721
    TnRedNeck721 GO VOLS!
    Zach
    TN
    07 TRD off road 4WD
    hey man. i’m not trying to be mean or any thing. but i kinda agree with macgyver. that is has to do with salt. i think i have hear my uncle the lives in New York about 30 min from buffalo. talk about this.( i don’t remember what it is and it was not even on a toyota) but but it’s something that maybe rusting.
  15. Dec 28, 2011 at 4:23 AM
    glsmaverick
    Howell MI
    None
    I understand the rust issues believe me.
    That being said; I am picking up the calipers today and doing the swap this evening. Hopefully its pretty straight forward as I have done calipers on multiple cars with little issue.
    It was stuck so bad this morning that with the little bit of ice on my driveway I could not get them to brake loose until I was about 80' down the driveway and into the road. That sucked!!
  16. Dec 28, 2011 at 5:32 AM
    glsmaverick
    Howell MI
    None
    Hey, I'm sorry I asked for help.
  17. Dec 28, 2011 at 6:36 AM
    macgyver
    Brad
    Canton, GA
    Do yourself a favor and buy a vacuum pump if you don't already have one. It makes bleeding the brakes by yourself a piece of cake. Also works a lot faster than having one person pump the brakes while the other bleeds.
  18. Dec 28, 2011 at 6:40 AM
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2011 PreRunner SR5
    very, very stock.
    I like this guy!:D
  19. Dec 29, 2011 at 10:28 AM
    scyot89
    scyot89 Active Member
    TJ
    South Carolina
    2002 Tacoma 3.4L 4X4 5spd
    Stock
    I had this happen a few months ago, mine was doing the same thing. I noticed when i jacked my rear end up even with the e-brake released one of the back tires would not move. I adjusted the the tensioner inside the brake drum way back out to loosen it up, but that didnt completely fix the issue. So I bought new parts, replaced every part inside the brake drum, springs, pads, tensioner, and everything. Sanded the inside of my drums down a little also. That fixed my problem. I didnt read everything you said yours was doing, but mine was makin a popping noise when i went to take off somewhere, or especially when it had been parked for a few hours.
  20. Dec 29, 2011 at 10:50 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    OP, did you get the calipers changed up? Did it solve your problem?
