truck stolen!!
Discussion in 'Northern California' started by rbeezy, May 3, 2012.
  1. May 3, 2012 at 7:52 PM
    #41
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    WOW, this totally sucks. i hope it's not a common thing with tacomas. put up the license plate number so we can keep an eye out.
  2. May 3, 2012 at 8:01 PM
    #42
    joes06tacoma
    Joe
    Central Coast, CA
    If your truck has a flashing red light under the radio, next to the airbag lights, then yes, you have a transponder chip in your key's rubber head. I have cut one apart and seen it.
  3. May 3, 2012 at 8:05 PM
    #43
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    '18 T4R & '06 F250
    6" lift 40s
    Good luck, sucks :(
  4. May 3, 2012 at 8:09 PM
    #44
    Superx2
    Superx2 Well-Known Member
    Joey
    Iowa
    I agree, i wouldnt want it back. God only knows what was done. :cheers: to you.
  5. May 3, 2012 at 8:17 PM
    #45
    Deathcure
    Deathcure Well-Known Member
    Wheeling WV
    12 Tacoma Off Road
    Sub for up dates and that suck makes me want to call home and make shure my truck is still there on vacation atm
  6. May 3, 2012 at 8:21 PM
    #46
    VanillaGorilla
    VanillaGorilla Itsnevertoearlytostartbee fingupyourobituary
    Erik
    East Bay Area, CA
    09 BSP Pre Runner SR5
    Tint. (DONE) Soon to come. 3in Llift (OME) Color matched grill (DONE) BHLM (DONE) Tail tint (DONE) Pro comp rims (8069) End goal: Murdered out truck
    I'll be on the lookout. not to many satoshi'd tacomas over where i am so if i see it ill notice. good luck!
  7. May 3, 2012 at 8:25 PM
    #47
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Okay I just went to check. Below the radio I have a red car shaped light with a "key" in it that blinks after I use the remote to unlock the car. When I lock it, it blinks also. My alarm is a separate light under the steering wheel and that is a solid red "dot" light.
    Is the car shaped light the transponder light?
  8. May 3, 2012 at 8:30 PM
    #48
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Yes the car shaped light is the transponder. If you pay attention the light goes out as soon as you put the key in the ignition.
  9. May 3, 2012 at 8:32 PM
    #49
    joes06tacoma
    Joe
    Central Coast, CA
    X2
  10. May 3, 2012 at 8:36 PM
    #50
    babytruck
    NorCal
    Huh. Learn something new every day. Thanks to you both!
    So if the stolen truck has a transponder, then the bad guy who makes the key on the run would have to program something to the truck, right? Because you can't just put a cut key in there and the thingy not communicating with the truck, right?
  11. May 3, 2012 at 9:19 PM
    #51
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    Damn that sucks man. I'll def keep an eye, we're right in the same area. Sorry bro
  12. May 3, 2012 at 9:21 PM
    #52
    Flip Dog
    Flip Dog Active Member
    Dave
    Santa Cruz, Ca
    Super White 4x4
    Sorry but, did he mention where it got stolen from? That might help too. Ill keep an eye out.
  13. May 3, 2012 at 9:21 PM
    #53
    babytruck
    NorCal
    Not yet. I've been awaiting.
  14. May 3, 2012 at 9:25 PM
    #54
    MJonaGS32
    MJ
    SF Bay Area (East)
    A lot of the stolen trucks in this area are either found in Oakland or Tracy area
  15. May 3, 2012 at 9:26 PM
    #55
    babytruck
    NorCal
    That's it. I'm going to put the truck away and drive my car.
  16. May 3, 2012 at 9:29 PM
    #56
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    that sucks, any update?
  17. May 3, 2012 at 9:29 PM
    #57
    NorCalSport
    NorCalSport Well-Known Member
    Sorry to hear..what part of the Bay Area?
  18. May 3, 2012 at 9:35 PM
    #58
    eh2win
    eh2win HIM
    09 prerunner
    afe s-dry filter
    hopefully you get it back.
  19. May 3, 2012 at 9:38 PM
    #59
    tacomafide
    tacomafide Cheese it in there!
    Sean
    Alberta
    '10 DCLB TRD Sport+Leather Pkg.
    de-badged, de-stickered, no jewlery, level kit (removed after second front dif), tint, skid plate (now dented), front tow hook off of Land Cruzer, reciever d hook (cleavis), yellow wire mod, abs kill sw. mod, window visors, stubby antena, anytime reverse lights mod, anytime reverse camera mod, blizzacks on stealies, bed lights mod, weathertec mats allround,
    They would have had to tow it no?? Engine immobilizer??
  20. May 3, 2012 at 9:40 PM
    #60
    tacomafide
    Sean
    Alberta
    My dog ate the rubber off the key and there is 100% some kinda chip thingy in there.
