truck stopped running
Discussion in 'General Tacoma Talk' started by dntnosht, Sep 30, 2024.
  1. Sep 30, 2024 at 5:45 PM
    dntnosht
    dntnosht [OP] Well-Known Member
    SoCal
    2009 TRD Sport DCLB
    stocko
    Was driving my granddaughter home today as I turned into her complex my truck just shutoff.
    I coasted to her house and it started right back up again. Went and got gas went to the store and it was fine. No lights on the dash and it seems fine. Any idea what might have caused it?.
  2. Sep 30, 2024 at 6:03 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    .[​IMG]
    also wouldn't hurt to check/clean your battery terminals.
  3. Sep 30, 2024 at 6:10 PM
    dntnosht
    SoCal
    2009 TRD Sport DCLB
    stocko
    Just did that last weekend.
  4. Sep 30, 2024 at 6:21 PM
    dntnosht
    SoCal
    2009 TRD Sport DCLB
    stocko
    with dielectric gel on the posts.
  5. Oct 3, 2024 at 8:06 AM
    frdomfghtr899
    frdomfghtr899 Member
    Keaton
    2020 Black Tacoma
    It’s good that your truck started right back up and there are no warning lights, but that random shutdown could indicate a few things. Here are a couple of possibilities:
    1. Fuel delivery issue: Could be a momentary fuel pump or fuel filter issue, especially if you were low on gas before filling up.
    2. Electrical problem: A loose battery connection or ground wire could cause the truck to shut off randomly.
    3. Crankshaft position sensor: If this sensor is starting to fail, it can cause the engine to cut out briefly and restart without throwing a code.
    4. Ignition switch: On older vehicles, a worn ignition switch can cause intermittent issues like this.
    Did you notice anything unusual before it shut off? Also, has it happened again since that first time? That could help narrow it down.
  6. Oct 3, 2024 at 4:41 PM
    dntnosht
    SoCal
    2009 TRD Sport DCLB
    stocko
    1. Had the fuel pump and housing assembly replaced last year al though I don't recall the filter being replaced. I always get gas at 1/4 tank.
    2. had cleaned the battery posts the week prior, everything is clean and tight. I could check for a loose ground though.
    3. Not sure about this one. Anyway to check this one.?
    4. Well it is an older vehicle.
    Nothing unusual before it happened truck was running fine and no it has not happened again.
    5. It was a little strange.
  7. Oct 3, 2024 at 5:52 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    Corrosion on the battery terminals is one cause. Another is corrosion on the cable itself, hiding under the insulation. Or breaks in the battery cables that are bumped out of alignment by turning, then fall back into place.
    Another possibility.
