Truck struggles to start
Discussion in '3rd Gen. Tacomas (2016-2023)' started by usmcadamsa, Jan 9, 2017.
  1. Jan 9, 2017 at 4:19 AM
    usmcadamsa
    usmcadamsa [OP] Well-Known Member
    Adam
    2016 Tacoma TRD Sport 6Spd
    Bone stock
    i should say won't start!! So it's 12 degrees here in PA, my truck for past 4 days is struggling to start. So now it won't even turnover!!!! My friend said get a block heater, I think it's more then just that! Basically it doesn't have enough cold cranking power or crapping ignition. I'm calling Toyota dealer today to get this fixed. Any ideas what it could be?
    Of course I have appointments and it doesn't work
  2. Jan 9, 2017 at 4:23 AM
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    Battery's bad/weak.
    You shouldn't need a block heater in PA.
    wadeo, Garyji, specter208 and 5 others like this.
  3. Jan 9, 2017 at 4:29 AM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    Get the battery checked out,something is not right.
  4. Jan 9, 2017 at 4:33 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    Sure sounds like a bad battery. Not normal for a 1 to 2 yr old truck, but it does happen.
    Spare Parts, 98tacoma27 and gpb like this.
  5. Jan 9, 2017 at 4:33 AM
    bradwhitenikki
    bradwhitenikki Well-Known Member
    Brad
    2016 Tacoma Trd Off Road 6sp Auto
    Mist likely culprit is the battery. How old is the battery? Is it the stock battery , used with the towing package?
    Spare Parts and 98tacoma27 like this.
  6. Jan 9, 2017 at 4:40 AM
    usmcadamsa
    Adam
    Bone stock
    Stock battery and yes tow package
  7. Jan 9, 2017 at 4:40 AM
    jeffmansion
    jeffmansion Well-Known Member
    16UTILITY4x4MT2.7
    K&N 63 series CAI, AVS Vent Visors, 16x8 Level 8 MK6 Rims, 285/75/16 MT, Eibach Pro lift, JBA UCAs, Wheelers 3leaf AAL, DV8 skidplate, Westin bedmat, Backrack, swaybar delete, Magnaflow cat-back, 9Drive throttle controller, 2LO Mod, Cali Raised Rock Sliders, Tyger rear bumper, Chinese Body Armor front bumper clone, 10K pound Winch, Smoked headlights, LED Bulbs.
    my truck fired up this morning fine in -6 degree weather.
  8. Jan 9, 2017 at 4:40 AM
    usmcadamsa
    Adam
    Bone stock
    So thinking it is battery does factory warranty cover that?
    I don't want to spend 100+ out of my pocket
  9. Jan 9, 2017 at 4:40 AM
    gpb
    Atlanta
    It should this early I would think.
    smitty99 likes this.
  10. Jan 9, 2017 at 4:44 AM
    usmcadamsa
    Adam
    Bone stock
    Basically need a battery with higher cold cranks
  11. Jan 9, 2017 at 4:46 AM
    gpb
    Atlanta
    No, your battery is defective. It happens. Not often, but it happens.
  12. Jan 9, 2017 at 4:47 AM
    nv529
    nv529 Well-Known Member
    Nick
    Metro Detroit, Michigan
    2006 Long Travel Taco, 2010 FJC, 2018 F250 Alumiduty
    Sounds like you got a dud battery, stock CCA rate should be more than enough.
  13. Jan 9, 2017 at 4:48 AM
    gpb
    Atlanta
    Instead of posting here, I'd be calling my service advisor and arranging for them to get it taken care of right away.
  14. Jan 9, 2017 at 4:49 AM
    usmcadamsa
    Adam
    Bone stock
    They don't open till 9 lol. I been awake since 645, I had to reschedule some appointments
  15. Jan 9, 2017 at 4:50 AM
    gpb
    Atlanta
    Whoops. My dealer's service department opens at 7am
  16. Jan 9, 2017 at 4:51 AM
    gpb
    Atlanta
    As a stopgap, you *could* bring the battery indoors to warm up a while. Even when defective that can help get you going in a pinch.
    Just remember, negative terminal disconnects *first*.
    You don't want to see what happens if you accidentally short out the positive terminal to the body with your wrench.
    0210, MQQSE and usmcadamsa[OP] like this.
  17. Jan 9, 2017 at 4:52 AM
    usmcadamsa
    Adam
    Bone stock
    I regret buying my truck from koch33 worst dealership I've ever dealt with
  18. Jan 9, 2017 at 4:54 AM
    gpb
    Atlanta
    Are they the only one in your area? Other that that, there's nothing to prevent you from going to a different dealer.
    nv529 and MQQSE like this.
  19. Jan 9, 2017 at 4:54 AM
    usmcadamsa
    Adam
    Bone stock
    Oh I know that lol. Nope I'll let them pay for everything
  20. Jan 9, 2017 at 4:55 AM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Welcome to the 3rd Gen nightmares!
    barney7, smitty99, Coot83 and 2 others like this.
