Truck stuck in 4WD
Discussion in '3rd Gen. Tacomas (2016-2023)' started by playdjembe4god, Mar 15, 2016.
  1. Mar 15, 2016 at 3:28 PM
    playdjembe4god
    playdjembe4god [OP] Member
    2016 Tacoma TRD Off-Road
    Let me start off by saying I've had 2 FJs, a 4Runner, and 2 Tacomas and have never had any problems with any of them. I've taken the current one wheeling on the trails behind my house countless times too.
    So...last week my truck got stuck in 4 high. I tried going back and forth in a straight line and stuff like the manual and the forums say. The light just kept flashing like it was trying to disengage, but nothing. I tried switching the knob to different stuff but wouldn't switch to 4 low or 2WD. It was right by my house so I drove home. I could tell as soon as I turned in the driveway that it was still 4WD. I called the dealership and they had me call Toyota Care to have it towed. They gave me a loaner and checked it out. They had to open a case with Toyota. First they thought it was just the switch because when they hooked their computer up, it wasn't showing it doing anything but that didn't fix it. They ended up replacing the transfer case. When they opened up the old one, they found the shift fork stuck to the actuator shaft and gears were stripped. Now that I have a new shift and transfer case, everything is good.
    Just thought you guys should know in case someone else has it happen.
    WMDtech and James_Bond like this.
  2. Mar 15, 2016 at 3:31 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Damn that sucks. Do you have the dealer service write-up notes from this? Would be curious to see them for records purposes.
    The hammer likes this.
  3. Mar 15, 2016 at 3:31 PM
    DanielTaco
    DanielTaco Well-Known Member
    Daniel
    Iceland
    2016 Tacoma DCSB TRD OR 3.5
    Miles on the truck? Had you previously used the 4wd?
  4. Mar 15, 2016 at 4:23 PM
    arkywally
    arkywally Well-Known Member
    David
    2016 DCSB TRDOR
    ICON Stage4 285/70/17 Cooper STT Pro Method NV
    Sounds like a bad actuator assembly, it engaged but never disengaged, why it stripped your gears is another story...Actually I think these have a "high rate of failure" compared to other 4 wheel related issues, ,but not destroying the diff. It would be nice to understand why it did that (stripping the gears) instead of just not disengaging.
  5. Mar 17, 2016 at 8:46 AM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    There's another post about this very same thing.... so 2 issues with the 4WD engagement problem and stripped gears.
  6. Mar 17, 2016 at 11:53 AM
    DecaturTide
    DecaturTide Well-Known Member
    River City
    2016 SR AC BARCELONA RED
    Check out "Broken Taco" thread. Same thing.
  7. Mar 17, 2016 at 12:06 PM
    redbull9944
    redbull9944 Well-Known Member
    Southwestern PA
    2016 DCSBTRDOR Inferno 6MT, 2004 Double Cab 4WD Project
    Prinsu Rack, 275/70R17 Cooper ST MAXXs, TRD PRO 4Runner Wheels, 5100s
    Where's @BlueT? He blamed the OP of the broken taco thread for his 4WD issues. I wonder if he'll blame you, too
    DecaturTide likes this.
  8. Mar 17, 2016 at 12:22 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    :rolleyes:
    I don't know if this guy broke it too, but other guy definitely did because he was playing between all modes on asphalt then made turn before system could fully disengage.
    In the op case don't have a clue but it's not the same problem.
  9. Mar 17, 2016 at 12:33 PM
    redbull9944
    Southwestern PA
    :facepalm:
    Lawfarin likes this.
  10. Mar 17, 2016 at 12:52 PM
    OffsetPlayer2
    OffsetPlayer2 Cornbread fed
    In the woods and fields, NC
    17 DCSB Off Road 4wd
    Weather Tech floor mats
    Was the broken taco one an OR as well? I can't remember. Oh, and he didn't break it. The truck let him know that it was no longer in 4wd so shut that shit up.
  11. Mar 17, 2016 at 12:57 PM
    COskimtb
    COskimtb Well-Known Member
    2016 Tacoma OR 4X4 DCSB 6MT MGM
    It was a Sport.
  12. Mar 17, 2016 at 12:58 PM
    OffsetPlayer2
    Ahh gotcha. Thanks for the confirmation.
  13. Mar 17, 2016 at 1:01 PM
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    BlueT fell off the short bus, you have to just ignore him.
  14. Mar 17, 2016 at 5:35 PM
    WMDtech
    WMDtech Well-Known Member
    Nate
    TN
    2018 TRD OR 4X4, White, DCSB
    None... sigh
    Damn, at least it's fixed. Best of luck with your Tacoma down the road.
  15. Mar 18, 2016 at 3:49 AM
    OffsetPlayer2
    Agreed. He's ignored on my end but when someone quotes him I still get the pleasure of seeing his posts.
  16. Mar 29, 2016 at 11:50 AM
    playdjembe4god
    Sorry I'm barely getting back to you guys now. I don't know what I did with the notes (probably tossed em). Had just over 4,300 miles and I'd used the 4WD on this truck more times than I can count (both high and low) on the trails and mud pit right behind my house (it's a shortcut, sort of).
