Truck stuck in limp mode
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GrampsTacoma23, Jul 1, 2022.
  1. Jul 11, 2022 at 6:40 PM
    #41
    Waasheem
    Waasheem
    2007 xrunner
    That reading is about what I expected. Sounds like you tested it correctly. Another possible cause ruled out.
  2. Jul 11, 2022 at 6:44 PM
    #42
    GrampsTacoma23
    GrampsTacoma23 [OP] Just hit 100k Club
    Jeff
    N GA
    2010 Silver Tacoma Base 2.7
    DJM Lowering kit, All LED lights on entire truck and inside, wheels
    Alright that's good but also bad bc now I'm even more confused, with how many codes I'm getting and how it happened instantly should I just bite the bullet and buy a new ecm? I could take it to Toyota but they want 215 just to look at it and diagnose it and I was told an ecm from Toyota was 570 without tax and 1 hour shop labor because apparently undoing a 10mm and unplugging it in 10 mins equals 1 hour. I would probably spend diagnosing and getting it fixed at the dealer double what it would cost to buy an ecm and install it myself
  3. Jul 11, 2022 at 7:04 PM
    #43
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    If your confident the PCM is faulty grab the service number off your PCM and see what a used one costs, auto trans PCMs can be relatively inexpensive but if you have a manual they can be hard to find and expensive.
    2nd gen PCMs are plug and play aside from programming the VIN which isn't nessesary to make the truck run and resetting the immobilizer (if equipped) which can be done with a jumper wire.
  4. Jul 11, 2022 at 7:10 PM
    #44
    GrampsTacoma23
    Jeff
    N GA
    Well from what I'm seeing from flagship one which is a reputable company and program ur ecu for u with ur Vin its 326 to 471 it just sucks I have to do this on a truck with less than 100k miles lol
  5. Jul 11, 2022 at 7:18 PM
    #45
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    All your vacuum hoses are good and not dry rotted?
  6. Jul 11, 2022 at 7:29 PM
    #46
    GrampsTacoma23
    Jeff
    N GA
    Yeah I've checked everything grounds vacuum hoses I've even sprayed starting fluid around intake and stuff and no difference in idle
  7. Jul 11, 2022 at 7:42 PM
    #47
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Maybe pop the #4 coil out and see if the tip where it clamps onto the plug is dry and not covered in oil. If it’s covered in oil the spark plug tube gaskets need replacement
  8. Jul 11, 2022 at 7:46 PM
    #48
    GrampsTacoma23
    Jeff
    N GA
    Tbh didn't think about that, if it needs a valve cover gasket I'll cry tears of joy if that fixes it
    Steves104x4[QUOTED] likes this.
  9. Jul 11, 2022 at 9:32 PM
    #49
    Waasheem
    Waasheem
    2007 xrunner
    I stand corrected. Prices you stated are far less than I expected.
  10. Jul 12, 2022 at 10:54 AM
    #50
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    So had one code, then replaced parts and got a whole bunch of new codes. Related to the parts you changed. Start going over everything you did. Might as well replace one part at a time with the original part. Then clear codes and see what comes back up.
    Dm93 likes this.
  11. Jul 12, 2022 at 9:06 PM
    #51
    GrampsTacoma23
    Jeff
    N GA
    I dont believe i actually had the original code i believe that was another car i had already fixed as when i look in the memory on my code reader it shows that code for the other car but then these same codes for the truck
  12. Jul 12, 2022 at 9:06 PM
    #52
    GrampsTacoma23
    Jeff
    N GA
    Nope everything looked new inside as expected
  13. Jul 12, 2022 at 9:07 PM
    #53
    GrampsTacoma23
    Jeff
    N GA
    Yeah thats why its tempting to just buy one and throw it in it really seems like the last issue
    Steves104x4 likes this.
  14. Jul 13, 2022 at 3:52 PM
    #54
    twblanset
    twblanset Well-Known Member
    Todd
    Vacaville, CA
    2015 TRD OR
    Mild lift and some tasty bits
    It's tempting to just buy a part and throw it in, but I usually regret doing it. The suggestion earlier to put all the old parts back in one by one is a good idea. They didn't fix your problem so you know they are probably good.
  15. Jul 13, 2022 at 4:03 PM
    #55
    GrampsTacoma23
    Jeff
    N GA
    The Maf sensor was already gone and i bench tested the pump and confirmed it didnt work the only other feesible option like i said and the one that honestly makes sense since like ive said the affects where instant and not something that happened overtime is a new ecm, i do know at one point this truck had roaches so theres a chance it got damaged
  16. Jul 13, 2022 at 4:04 PM
    #56
    twblanset
    Todd
    Vacaville, CA
    2015 TRD OR
    If you know anyone with the same truck, see if they will let you borrow their ECM for a day.
  17. Jul 13, 2022 at 4:07 PM
    #57
    GrampsTacoma23
    Jeff
    N GA
    I know no one with the same one everyone else has the v6 or a newer truck and there are zero tacomas here in junkyards, besides an ecm being about 400 bucks and thats plug and play they program ur vin and everything isnt bad i wish i could take the ecm out and have it tested on a bench but i have no idea where to get that done in North GA
  18. Jul 13, 2022 at 4:35 PM
    #58
    Waasheem
    Waasheem
    2007 xrunner
    Where I work, we use a place called flight systems for testing things like that. A quick Google search didn't show much. I could get contact info if you want.
    Something to think about. If something in your truck kills the ecm, you borrow someone's, it fries it, now you owe a friend a new ecm and a case of beer, and still need to buy one for yourself and figure out what's killing it.
  19. Jul 13, 2022 at 4:39 PM
    #59
    GrampsTacoma23
    Jeff
    N GA
    Yeah id be worried about that too, later on im gonna remove and open the ecm obviously not gonna touch anything but if i see water or roach damage then im replacing it
  20. Jul 13, 2022 at 4:50 PM
    #60
    steelcity2
    steelcity2 Well-Known Member
    Pittsburgh Pa
    2013 MGM DCSB TRD sport
    Bilsteins 5100's all 4 corners 1 inch rear spacer
    Have to ask, how does one get roaches in a truck?
    Canadian Caber likes this.
