Truck stuck in park
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sportzman0, Mar 27, 2013.
  1. Mar 27, 2013 at 9:33 PM
    sportzman0
    sportzman0 [OP] Well-Known Member
    Tim
    Las Vegas
    Black emblems Tinted Windows Aftermarket Audio System LED Dome Lights Headlights Blacked Out
    So I started up my truck and it will not shift into gear. On my dash, it doesn't even show the parking break gear light. I am not able to move it out of gear. Any help please
  2. Mar 27, 2013 at 9:37 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    There should be a lock override release somewhere near your shifter. Should have a small plastic cover that comes off and you put a screw driver in it to override the shifter lock. Try this and see what happens.
  3. Mar 27, 2013 at 9:37 PM
    joes06tacoma
    Joe
    Central Coast, CA
    You most likely have a blown brake light fuse. Not sure if that's under the hood or behind the change tray, should be in the owner's manual. Any aftermarket wiring out back? We had a third brake light wire to the campershell get pinched and do this same thing on one of our work trucks.
  4. Mar 27, 2013 at 9:38 PM
    moondeath
    Pa, Gardners
    Or do you mean the shifter moves but the truck won't go into gear?
  5. Mar 27, 2013 at 9:42 PM
    sportzman0
    Tim
    Las Vegas
    Used the override and now I can move. Shifter wouldnt go in gear and move
  6. Mar 27, 2013 at 9:45 PM
    moondeath
    Pa, Gardners
    If this is working, then the switch under your brake pedal isn't sending a signal to the lock release.
  7. Mar 27, 2013 at 9:48 PM
    moondeath
    Pa, Gardners
    Like he said.
    I would check fuses when you get a chance.
  8. Mar 27, 2013 at 9:53 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    check the taillight fuse
  9. Mar 27, 2013 at 9:58 PM
    Fractured
    Fractured FPS-a-holic
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    TRD wheels, TRD cat back exhaust, ScanGauge 2, Debadged, Avid sliders, UWS bed box w/automatic LED light, Led Interior/Reverse/Lic. Plate lights, Yellow Fogs, Flyzeye Light, Color matched grill, Rearview mirror relocate bracket, Power Sliding rear window, Plasti-dipped bumper/"T" emblem
    Lightly press the brake and listen for a "click" by the shifter. If you hear one then you have some mechanical issue. If you don't, the interlock isn't releasing.
  10. Mar 27, 2013 at 11:45 PM
    sportzman0
    Tim
    Las Vegas
    Ok would that just be the fuse? Or do I need to take to Toyota. I'll try the taillights fuse didn't think of that but my taillights work along with my brake lights just not my blinkers
  11. Mar 27, 2013 at 11:49 PM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    Lol I read the title and went, "did they close the gate? How'd this guy get stuck in a park?!"
    :laugh:
    I don't have anything helpful to say either. That was it.
  12. Mar 28, 2013 at 9:21 AM
    Spitz Stang
    Spitz Stang Well-Known Member
    Mark
    Houston, TX
    2012 DC TRD OR 4x4
    OME 885 / Dakar,5100's, 265/65-16
  13. Mar 28, 2013 at 10:44 AM
    sportzman0
    Tim
    Las Vegas
    Thank you everyone it was the.ign1 fuse. Fixed it now I have my engine light on and 2 other lights on my dash 1 is airbag and only is swerve thing. How do u reset them
  14. Mar 28, 2013 at 11:17 AM
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    :rofl:
  15. Jul 27, 2013 at 9:11 PM
    Jon850FL
    Jon850FL is Lurkin'
    Jon
    DFS, FL
    thanks to this thread, wasnt stuck long today with the jetski. just glad it was at the gas station and not the boatramp....lol
    stupid trailer lights.....
