truck stuck on 4low ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ddiaz84, Mar 23, 2016.
  1. Mar 23, 2016 at 3:03 PM
    ddiaz84
    ddiaz84 [OP] chapin✌
    diego
    2013 toyota tacoma single cab 4x4
    Knn intake kit , lce performance headers, aftermarket wheels , bilstein 5100s 1.75 front lift , 1 inch rear block lift
    My tacoma got stuck on 4low while i was driving in heavy snow . Now it wont turn off . Maybe 4wd switch went bad ?
  2. Mar 23, 2016 at 3:43 PM
    Pigpen
    Dan
    Northwest Montana
    Manual or auto trans?
  3. Mar 23, 2016 at 3:46 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Start simple. Disconnect battery momentarily. Resets all electronics.
  4. Mar 23, 2016 at 3:47 PM
    Pigpen
    Dan
    Northwest Montana
    Well, let's make sure the proper procedure was followed to get out of low range first. Is it beeping when you try to go into 4 hi?
  5. Mar 23, 2016 at 3:47 PM
    ddiaz84
    diego
    Its automatic . I guess i wasnt using common sense . I was trying to switch it back while it was on gear , i tried it on neutral now it went back to normal
  6. Mar 23, 2016 at 3:48 PM
    Pigpen
    Dan
    Northwest Montana
    There it is. Glad you got it figured out.
  7. Mar 23, 2016 at 3:49 PM
    ddiaz84
    diego
    I appreciate your help 58 siesta
  8. Mar 23, 2016 at 3:49 PM
    koditten
    Kirk
    Central Michigan
    That's the normal way.
