truck surges forward when AC disengages
Discussion in '2nd Gen. Tacomas (2005-2015)' started by victorramse3, Mar 15, 2013.
  1. Mar 15, 2013 at 2:20 PM
    victorramse3
    victorramse3 [OP] Well-Known Member
    Victor
    Bakersfield, CA
    2013 Dbl cab TRD OR 4x4
    N/A
    I have been having this annoying issue with my truck's brakes.
    The truck has about 1200 miles on it, it is a 2013 DBL cab 4.0 auto TRD OR.
    The issue is that, when I am at a complete stop with the truck in Drive and with the A/C on, the truck seems to surge forward a little bit from time to time. I cannot tell if it is when the A/C compressor engages/disengages but I am assuming it is when the compressor disengages and stops robbing power from the engine. I have never owned an automatic before as a daily driver so this may be normal.
    The first time this happened I freaked out because I thought the car behind me hit me. I has only happened about 3 or 4 times, but I still do not like it.
    Does anyone else notice this happening with their trucks?
    :confused:
  2. Mar 15, 2013 at 2:21 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    It's the compressor belt engaging and disengaging. Everyone's does it.
  3. Mar 15, 2013 at 2:28 PM
    victorramse3
    Victor
    Bakersfield, CA
    N/A
    Is it normal for the truck to actually creep forward a little bit? Sometimes I feel like i'm going to hit the car in front of me.
  4. Mar 15, 2013 at 2:30 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Normal
  5. Mar 15, 2013 at 6:36 PM
    maykevin5
    maykevin5 Well-Known Member
    Kevin
    Carbondale Illinois
    2012 Tacoma SR5
    3 inch lift, stainless steps, JL/Focal audio sound system
    The truck comes with brakes. Press a little harder.
  6. Mar 15, 2013 at 6:51 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    It seems to be a toyota thing as my daughters 10 corrolla does it too.
  7. Mar 15, 2013 at 6:53 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Not just Toyota.
    Every vehicle I've had with AC since '88 has done it.
    Just learn to put a little more pressure on the brakes when stopped.
  8. Mar 15, 2013 at 6:57 PM
    machineman89
    machineman89 Well-Known Member
    Matthew
    San Leandro
    overlanding limo in progress :-P
    Weather tech floor mats, fog light any time mod, derped front embelem, Pelfretbilt 3 hoop plate bumper, 10k warn xeon winch-s some leds, pelfreybilt roof rack, scs stealth series rims, wrangler authority tires, BAMF 96" bolt on sliders, BAMF dif skid, some dirt....
    comen from a 5 speed to an auto again it surprised me, but a secend later i was like oh yea, A/C on or off ur change engine load, changing the needed braking pressure, surpising if u dnt know what to expect, nuttin once u learn the trucks personality traits :D
  9. Mar 15, 2013 at 8:01 PM
    Brandon###
    Brandon### Well-Known Member
    Our tacoma has done this since day 1, but the fj has never done it. (It has the newer 4.0l dual vvt engine in it)
  10. Mar 15, 2013 at 8:06 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    <jeremy clarkson voice> POWWERR!! </jeremy clarkson voice>
  11. Mar 15, 2013 at 8:33 PM
    Raceline08
    Raceline08 Well-Known Member
    Brett
    Santa Rosa, ca
    Silver 08 DBC SB 4x4 TRD Offroad
    front Billies, 885x coils, taco lean spacer, TC UCA'S, Magnaflow 22" OME Dakars, Billy 110 rear's, B.A.M.F CMC, custom made E-locker guard
    Yep totally normal, when ever the switch is turned turned to the defrost position / or ac button pushed the surging will happen.
    You can search around here a bit and find some good info.
    Brett
  12. Mar 16, 2013 at 5:07 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    I wonder if this has anything to do with the recent letter I got regarding the class action law suit against Toyota.
    We got three letters, one for the truck, and one for each Corrolla.
    PK
  13. Mar 16, 2013 at 5:17 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Wow, really? I can hear it turn on, feel the slight movement, as the engine speeds up a little to take the extra load, then let off as the ac cycles. ALL vehicals with ac do this, some hide it better.
  14. Mar 16, 2013 at 11:43 AM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Nahh... the letters I got were related to the floor mat recall issue that was resolved 2 years ago.
    There were no incidents confirmed by the black boxes to be the fault of the vehicle's electronics, yet people are still trying to cash in on it.
  15. Mar 16, 2013 at 11:51 AM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Normal. Apply brakes harder.
    FWIW, I've never noticed this on any other car I've hard. Perhaps just different brake pedal feel and I may have been pushing the brakes in harder subconsciously and never noticing it.
  16. Mar 17, 2013 at 11:36 AM
    victorramse3
    Victor
    Bakersfield, CA
    N/A
    Thanks for all the replies guys!
    This makes me feel a bit better.
    I just drove my wife's 2011 Honda Civic and it does not have the same issue (smaller less torque engine I assume)
    I will just have to apply more pressure to the brake pedal
    :D
  17. Mar 17, 2013 at 12:26 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    It still get's me every now and then when I am not leaning on the brake pedal all that hard but as soon as it revs, something clicks in my brain to press a little harder.
  18. Mar 17, 2013 at 2:05 PM
    graywolf2011
    graywolf2011 Well-Known Member
    Orlando Florida
    11 Tacoma 4X4
    undercover hard toneau, stainless steel nfab step bars
    The ECU has idle compensation software that is supposed to maintain engine idle at normal when the compressor engages, ie automatically adjusts the idle to compensate for the load of the compressor. But like anything else, it is not perfect. If you feel a significant surge, you might want to get your idle speed checked, it may be too low. Just a thought.
  19. Mar 17, 2013 at 6:33 PM
    PMK
    Florida
    10 DCLB TRD Sport
    Nope, these are different. These are not TSB or recall letters. We got three, specifically about a class action lawsuit against Toyota.
    PK
  20. Mar 17, 2013 at 7:20 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    That's what I got. A class action lawsuit letter apparently regarding Toyota's handling of the floor mat recall situation.
    My letter wasn't from Toyota.
    Like I usually do with class action lawsuit letters, I pitched it.
