Truck took a poopy
Discussion in '1st Gen. Tacomas (1995-2004)' started by Croth51, Apr 12, 2017.
  1. Apr 12, 2017 at 2:48 PM
    Croth51
    Croth51 [OP] Croth Metal Works
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    16 Method NV,33 Bfg AT KO2, 14 in Fox shocks hydraulic bumps swayaway coilovers 50 in LED Lightbar A pillar Ditch lights ,Custom Skidplate,4 Hella Hid lights,Custom grille,7 in Pioneer touch screen Head unit, 12 in CT sounds Meso CT 1400.1 amp, kicker doorspeaker, 500 watt doorspeaker amp, white LED rocklights, LED pod Dustlight,
    Ok guys... So I'm having trouble lets see if you can pinpoint it. So this morning went to the gym... Cranked over the truck no problem... Left the gym cranked over no problem... Went home... Left home to go to,lunch cranked no problem. Left lunch cranked no problem... Went to leave my girls house... Truck DEAD batteries read at 9.5 volts... In running two deep cycle optimas... Jumped it went home put it on the charger. Forgot to turn the charger on... So ofcourse battery was dead. Jumped it. Drove around 15 miles freeway. Went out to truck. Wont crank over at all. Reads 9.8 volts.. Wtf. Also its not the alternator... I have a big stereo and the voltage meter reads 13.5-13.7 while driving....... So wtf?
  2. Apr 12, 2017 at 2:50 PM
    Oowen
    Oowen Well-Known Member
    Owen
    Reno, NV
    '22 Cummins
    How old are the batteries?
    Croth51[OP] likes this.
  3. Apr 12, 2017 at 2:50 PM
    Blais03
    Blais03 Guess I'll bring a spare wheel bearing...
    Nick
    Easthampton MA
    '08 Reg. Cab 4WD + '06 Reg. Cab 2WD
    charge your battery and find out whats draining it.
  4. Apr 12, 2017 at 2:53 PM
    quetzal
    quetzal Well-Known Member
    Mario
    Long Beach, CA
    '02 XtraCab SR5 TRD 4x4 5spd
    All-Pro UCAs, King 2.5 C/Os, All-Pro Expo Leafs, Bilstein 10" Shocks
    Dirty/corroded battery terminals?
  5. Apr 12, 2017 at 2:53 PM
    Croth51
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    One optima is about a year old.. Other is about 3 months old... What could be causing it to be fine 6 hours ago and now at 9.8 volts...
  6. Apr 12, 2017 at 2:54 PM
    Croth51
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    Kinda old... But pretty clean
  7. Apr 12, 2017 at 2:54 PM
    Oowen
    Owen
    Reno, NV
    '22 Cummins
    Accessory that isn't turning off?
  8. Apr 12, 2017 at 2:55 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    One of the batteries took a dump. Find out which one, and remove it.
    koditten and Croth51[QUOTED][OP] like this.
  9. Apr 12, 2017 at 2:55 PM
    Croth51
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    That could be right but I have such a battery bank... I don't know what could drain it that fast.
  10. Apr 12, 2017 at 2:56 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Is the alternator not charging the battery?
  11. Apr 12, 2017 at 2:57 PM
    Croth51
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    Thats what I was thinking... But one optima at a year old and another at 3 months.? And all of a sudden it giving me problems? Also took them to AutoZone and they both tested good
  12. Apr 12, 2017 at 2:57 PM
    Croth51
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    While running my voltage meter reads 13.8....
  13. Apr 12, 2017 at 2:57 PM
    Croth51
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    Also thanks everyone for all the help... Very confusing
  14. Apr 12, 2017 at 2:59 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    Sorry. Busy, kinda just skimmed through it.
    Croth51[QUOTED][OP] likes this.
  15. Apr 12, 2017 at 3:00 PM
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    Optimal wont charge under 10.5 volts Use jumper cables to hook to a battery with good voltage and once the optima reads over 10.5 then connect a trickle charger to the optima while keeping the other battery connected. Do that for a few hrs then disconnect everything and see what the optima voltage is at
  16. Apr 12, 2017 at 3:04 PM
    Croth51
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    No prob any input helps
    Will try this...
  17. Apr 12, 2017 at 3:06 PM
    YamaDirtrider
    Josh
    Elizabeth CO
    That could have a lot to do with it! lol
    But yea. How I discribed it is what the optima paper says to do. I know, I know, no one reads it but I was board at work one day and read the whole thing :thumbsup:
  18. Apr 12, 2017 at 3:07 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    That looks like a bucket of smashed assholes. Take the terminals off and scrub those posts and clamps.
    wilcam47 likes this.
  19. Apr 12, 2017 at 3:09 PM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    What are you looking at in the pic? Is it the lead getting pinched or shorted by the screw or whatever?
  20. Apr 12, 2017 at 3:09 PM
    Croth51
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    YamaDirtrider[QUOTED] likes this.
