Truck took a poopy
Discussion in '1st Gen. Tacomas (1995-2004)' started by Croth51, Apr 12, 2017.
  1. Apr 12, 2017 at 3:33 PM
    #41
    Croth51
    Croth51 [OP] Croth Metal Works
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    16 Method NV,33 Bfg AT KO2, 14 in Fox shocks hydraulic bumps swayaway coilovers 50 in LED Lightbar A pillar Ditch lights ,Custom Skidplate,4 Hella Hid lights,Custom grille,7 in Pioneer touch screen Head unit, 12 in CT sounds Meso CT 1400.1 amp, kicker doorspeaker, 500 watt doorspeaker amp, white LED rocklights, LED pod Dustlight,
    Anyone know what the batt light can be an indicator of
  2. Apr 12, 2017 at 3:35 PM
    #42
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    If you have a towing package you will need the 130 amp Alternator, I would use that one with the dual battery set up even if you do not have a towing package.
  3. Apr 12, 2017 at 3:35 PM
    #43
    TomTwo
    Bill
    I-85 Southbound
    Charging system issue.
    Croth51[QUOTED][OP] likes this.
  4. Apr 12, 2017 at 3:37 PM
    #44
    TomTwo
    Bill
    I-85 Southbound
    Let us know what you find out
    Croth51[OP] likes this.
  5. Apr 12, 2017 at 3:37 PM
    #45
    Croth51
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    I
    l gst that too...
  6. Apr 12, 2017 at 3:41 PM
    #46
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    Clean off the terminals, if you know how to use a electrical meter check the battery voltage with the truck off, should be 12.4-12.8 check it with it running. Should be over 13 then. Turn the truck off and check the voltage to the battery cable where it bolts on to the starter. Compare that voltage to what's at the battery to see if they are nearly the same or if your having a significant voltage drop.
  7. Apr 12, 2017 at 4:29 PM
    #47
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    You said you have an aftermarket radio? Like sub's and amps?? How big? Do you run then with a good amount of thump? Do the headlights dim when the bass hits hard?
    If yes. Especially the last one and you've on the same stock components I whojnd say like a few others your voltage regulator is probable bad. It happened to a car I had with a very mild system.
  8. Apr 12, 2017 at 5:22 PM
    #48
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    optima batteries discharged under 10.5 volts usually require a special charging process.
  9. Apr 12, 2017 at 5:47 PM
    #49
    Croth51
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    Its huge... But I have capacitor and all big 3 upgraded and 2 batts and a capacitor..
  10. Apr 12, 2017 at 5:48 PM
    #50
    Croth51
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    I hope that its a misreading and not actually under 9.5
  11. Apr 12, 2017 at 5:52 PM
    #51
    YamaDirtrider
    Josh
    Elizabeth CO
    Defiantly get the alternator tested. It's very possible that you've worked the voltage regulator too hard and it's going bad. It can show a good voltage but the wave can be erratic and that hurts the batteries. Once it starts on it's own have a parts store do a full battery/charging system test
  12. Apr 12, 2017 at 6:29 PM
    #52
    Croth51
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    That will be the plan... Leaving work on a jump and gonna charge the batteries.. Then go through the whole system
    YamaDirtrider[QUOTED] likes this.
  13. Apr 13, 2017 at 8:22 AM
    #53
    Croth51
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    So, I actually think BOTH batteries are bad? I hooked them both up to a charger 2 batteries in parralel on a 40 amp charge and didn't even bring the voltage up at all. My old red top I replaced which was still good just getting old after sitting for 4 month hooked it up and it started right up like cranked it so fast. Gonna warranty the 2 batts and get alternator tested aswell
  14. Apr 13, 2017 at 10:42 AM
    #54
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    13.8 volts might be barely ok in a stock configuration where you have a single, wet cell lead/acid battery. But it's inadequate with an AGM type battery. AGMs require 14.5 volts or more ideally to get a full charge. You have compounded the problem by having your stock alternator trying to support and maintain two AGM types.
    What are you using to manage your dual battery setup? Is it a BlueSea ML-ACR?
  15. Apr 13, 2017 at 11:36 AM
    #55
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    bad battery, alternator not charging/low etc..
  16. Apr 13, 2017 at 12:50 PM
    #56
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I'm gonna guess only 1 bad battery. It's compromising the whole system.
    These AGM batteries require some special charging characteristics.
    I've been against using these in our trucks for years.
  17. Apr 13, 2017 at 12:57 PM
    #57
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    and must be charged with an optima charger
  18. Apr 13, 2017 at 1:04 PM
    #58
    YamaDirtrider
    Josh
    Elizabeth CO
    False. Needs to be a trickle charger
    Ritchie likes this.
  19. Apr 13, 2017 at 1:43 PM
    #59
    Croth51
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    So... Redid my electrical completely, got 2 full size batteries... Resting voltage is around 12.3 now everything audio wise is so much better. And everythinf now is a lot cleaner then my first teenage install
    YamaDirtrider likes this.
  20. Apr 13, 2017 at 1:57 PM
    #60
    Croth51
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    Bart light is still on.... Pulling alternator and testing it
