truck topper fit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTuesday, Sep 1, 2010.
  1. Sep 1, 2010 at 6:04 PM
    TacoTuesday
    TacoTuesday [OP] Member
    I am looking to get a topper for my 07 taco. I am leaning toward a the leer 100xl and the ARE z series. The difference is likely the way it fits to the bed. I want to be able to remove the rail caps and conceal the paint chafe with the marriage of the topper. I am leaning toward the Leer. However, I would certainly like to see how yours fits and hear your opinion.
    Did you leave your rail caps in place? Is it a clean install? anything.
  2. Sep 1, 2010 at 6:34 PM
    goride
    goride Well-Known Member
    Josh
    UTAH
    09 trd sport dbl cab lb
    Tinted windows,Upgraded stereo system,satoshi grill with piaa lights behind,dash light color mod to blue,mag light holder,OME dakar leafs,Toytec ultimate lift,LR uca's, BFG AT's 285/70/17 on Pro Comp 7089s,weather techs, leer shell,CBI sliders and rear bumper w/tire gate,soon DTLT w/ wicked flow catback exhaust
    rail caps left on ,nice fit ,no leaks,love it
  3. Sep 1, 2010 at 6:46 PM
    TacoTuesday
    How is it attached? I do not want to drill through the rail caps in case I want to run without the topper. I do not want to do irreversible damage that will be seen as poor craftsmanship by a potential buyer in the future.
  4. Sep 1, 2010 at 6:50 PM
    l_prettyman
    l_prettyman Well-Known Member
    Logan
    Easton Shore Maryland
    06 4x4 SR5
    12% tint, Leer cap, Pioneer Avh3100DVD headunit, Kinetik 2000 battery, Memphis pr1.1000 amp, Pioneer subwoofer(not sure what kind), Back-up Camera, PA/CB system
    have the same cap for my short bed. loved it!! had leaks in the front corners but i plugged that with silicone. all-in-all, very nice cap
  5. Sep 1, 2010 at 6:52 PM
    JoeyTacoma
    JoeyTacoma Well-Known Member
    Eagle, Colorado
    2017 TRD Off-Road Pro Cement
    285/75 R16 BF Goodrich All Terrain KO2
    Mine uses the bedrail system to connect the topper. No drilling or holes.
  6. Sep 2, 2010 at 5:44 AM
    goride
    Josh
    UTAH
    Same no drilling holes,they use the rail system like stated above. I do beleive imo that snug top,leer and a.r.e are the best quality. Good Luck
  7. Sep 2, 2010 at 6:23 AM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Oceanside, CA
    10 DCLB
    TRD Fleshlight
    I went with the ARE Z series and have no complaints. The installer silicone sealed under the rail caps, no leaks at all. One other thing to consider is that the ARE caps are painted where as Leer are gelcoat. UV/weather tend to fade gelcoat over time.
  8. Sep 2, 2010 at 6:35 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    I have an ARE CX (I think) and I didn't remove the bed rail caps. Sometimes I take the topper off and I didn't want to have to worry about putting the rail caps back on. I put a layer of weatherstripping between the topper and the bed rail caps. At the front of the bed I had to use two layers of 1/2 foam weatherstripping because there is no rail cap at the front of the bed. It still leaks a little at the front corners, but it just runs down the inside of the bed and under the bed mat. Here's a pic.
  9. Sep 2, 2010 at 6:46 AM
    Dimonback
    Dimonback Well-Known Member
    Patrick
    Austin, Tx, from all over hell and back
    Geezer double cab w/ shell
    Leer 100, rail caps left on, gasket front (perfect for letting the pups get some of the AC). Good fit, good quality, and installed in 10 minutes without drilling.
  10. Sep 2, 2010 at 11:10 AM
    ozmon420
    ozmon420 Well-Known Member
    miami, florida
    08 tacoma
    18x9 pro comp 7031 rims, alpine iva-d310 w/sirius sat radio, ipod connection, tv tuner, reverse camera, bug deflector, wet okole seat covers, tinted windows, running boards, toytec coilovers front set at 2.5'' , AAL rear,5100's rear, TC UCA, leer topper, bruteforce rear bumper, ARB rear locker.
  11. Sep 2, 2010 at 11:40 AM
    catsgot9
    catsgot9 Member
    Allen
    KC MO.
    05 DC 4x4 TRD OR 6spd
    who makes that one?
  12. Sep 2, 2010 at 7:15 PM
    TacoTuesday
    Does anyone know for sure if the leer is coated in gel or paint?
    I really like the look of the leer however the ARE has a Yakima rack option. Those parts are all over. If I were to pick up the ARE I would likely get the Z.
    goride, do you know?
  13. Sep 2, 2010 at 7:24 PM
    ozmon420
    miami, florida
    08 tacoma
    thats a leer topper
  14. Sep 2, 2010 at 7:48 PM
    goride
    Josh
    UTAH
    I dont know what gel is, im sure its just painted and clear coated,leer also comes with rack packages or if you find a used top you can install rails and put your own rack on, I found my top on ksl 6 months old (basically brand new) for half the price.
  15. Sep 2, 2010 at 7:51 PM
    Rtrn2taco
    Rtrn2taco Nostalgia...
    Philadelphia
    08 DC PreRunner (silver)
    Leer caps are absolutely painted base/clear coat.
  16. Sep 2, 2010 at 8:17 PM
    goride
    Josh
    UTAH
    What is gel?how is it different? please teach me.
  17. Sep 2, 2010 at 8:31 PM
    saltwater taco
    saltwater taco Well-Known Member
    Brandon
    Telluride, CO
    2001 3.4 5spd 4x4 TRD
    softopper, sleeping platform
    Gel coat is like what they use on boats. It's more durable than paint but it'll get oxidized after a while. I have a leer and love it, but it seems that girls don't really like it. Anybody else have that problem? (not trying to thread jack or anything)
  18. Sep 2, 2010 at 9:28 PM
    dirtytaco2010
    dirtytaco2010 Well-Known Member
    south lake tahoe, CA baby
    SR5 TRD Sport LB
    custom badging, Black Badges, tint, General AT/2's, nerf bars black, ultra-gauge,toytec AAL, removed mud flaps, Bilstein 5100's @ 2.75, AFE pro dry s air fliter, spidertrax, black rock 17'' wheels
    might just be your geographical location I love my leer so does my chick. I still take it off time to time cuz I like both looks and the ability to be able to utilize my bed too. get the Leer. Easy to get replacement parts too
  19. Sep 2, 2010 at 9:32 PM
    TacoTuesday
    My wife was not for it for a long time, she says it looks too grandpa. However, there is a baby on the way and we will need some more room that is dry. When I have traveled to WY, MT, WA, ID, places where the weather is bad for much of the year, most of the Tacomas I saw had toppers with racks. It is just a good way to keep things out of the weather and possibly increase the carrying capacity. Not to mention keeping others' hands off my stuff in my high crime home town.
  20. Sep 3, 2010 at 3:25 PM
    ASH
    ASH Well-Known Member
    SF Bay Area, CA
    2010 DC PreRunner TRD Off Road
    SnugTop Rebel Shell, Bilstein 5100's @ 1.75, Rear TSB, BFG A/T KO 265/75/16, Tranny TSB, WeatherTech Digital Fit Floor Mats, Debadged (Sides), Black Badges (Tailgate), Avid Off Road Sliders, TRD Shoulder Pads, Factory Color-Matched Grille w/Blacked-Out Emblem
    Same here. Mine is a SnugTop Rebel BTW:
