Truck Totalled?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dOppy367, Apr 25, 2020.
  1. Apr 25, 2020 at 10:31 PM
    #41
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    didn’t even acknowledge the dude. Probably a kid and/or auxiliary.
  2. Apr 25, 2020 at 10:35 PM
    #42
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    Sorry to see that happen to your new truck but in the future try to plan a bit before you go out. Have an idea of what the area looks like. And the main point I'd like to make: a tree shouldn't die because you are a moron, especially on public land. If you are on private land and the owner is cool with it, go ahead, no one will stop you. But on public land it is both illegal without the proper permits and an uncool move.
  3. Apr 25, 2020 at 10:49 PM
    #43
    BangosTaco
    BangosTaco Well-Known Member
    2020 Toyota Tacoma TRD PRO [MT]
    Stock
    2 days? ok I wont feel so bad when it hails
    Malvolio likes this.
  4. Apr 25, 2020 at 11:03 PM
    #44
    dOppy367
    dOppy367 [OP] Member
    2020 Tacoma Red TRD Off Road
    Being an idiot for sure
  5. Apr 25, 2020 at 11:15 PM
    #45
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Hobbs, shane100700 and Kolter45 like this.
  6. Apr 25, 2020 at 11:23 PM
    #46
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    :101010:
    :threadjacked: :stayontopic:
    :itllbuffout: :sorry: :sawzall:
    Maybe now that its a bit scratched up, you can start on mods sooner without feeling guilty? (that's gotta be a record - 2 days!) Make some space for those 33" tyres so you can climb the tree next time, or push past it with sliders and an exoskeleton?
  7. Apr 25, 2020 at 11:24 PM
    #47
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    *tires :anonymous:
  8. Apr 25, 2020 at 11:27 PM
    #48
    smk87
    smk87 Well-Known Member
    About $300 a panel plus $250-$500 for the rocker
    JKU3000 likes this.
  9. Apr 25, 2020 at 11:28 PM
    #49
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    strongrob and Malvolio like this.
  10. Apr 26, 2020 at 2:26 AM
    #50
    20thumper
    20thumper Well-Known Member
    Tom
    2020 Tacoma DCSB OR
    I imagine your parents are as low class as you...
    tinker_troy, shane100700 and Kolter45 like this.
  11. Apr 26, 2020 at 4:36 AM
    #51
    mgmdclb
    mgmdclb Well-Known Member
    The Maritimes, Canada
    2018 MGM DCLB Sport
    I slid into a power pole like this in my 2nd gen, got a box side at a salvage yard for $400, 2 doors for $400, and I cut out that side of the cab about midway up the Center post and half way up the rocker on the drivers door and halfway up the rear window, they let me have that piece for $200. Welded it into my truck and sent it to someone else to finish it and paint the cab. Doors and box side were already silver and didn’t need paint.
    It ended up costing me about $3000 by the time it was done and you couldn’t tell the difference.
    Found out later I bent the rearend housing, but I was able to straighten it within spec with come alongs and a oxy/acet torch.
    Everything is fixable.
    mrtonyd and shane100700 like this.
  12. Apr 26, 2020 at 4:44 AM
    #52
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    no wonder car insurance premiums are so high for good drivers
    Hobbs, Lawfarin, strongrob and 2 others like this.
  13. Apr 26, 2020 at 4:50 AM
    #53
    no vtec 4me
    no vtec 4me Well-Known Member
    Kevin
    West Chester, Pa
    2017 Tacoma TRD Sport
    I had to replace two doors and paint the 1/4 on my wife’s car, cost to insurance was $5000. If your rocker and bedside have damage I bet you’re closer to $10k
  14. Apr 26, 2020 at 5:40 AM
    #54
    Kevin8se7en
    Kevin8se7en Well-Known Member
    2017 Inferno OR
    Kinda nice to see someone own up to what actually happened and take responsibility. I hope it doesn't hurt your wallet too much.
    I'm sure you're part of the 80% of people that think they are above average drivers, right? lol
    I keed I keed...
    strongrob, mgmdclb and Chew like this.
  15. Apr 26, 2020 at 5:42 AM
    #55
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Going to be expensive
  16. Apr 26, 2020 at 11:40 AM
    #56
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    It happens to most of us. Some just do it more than others.
    Bleep100, tinker_troy and shane100700 like this.
  17. Apr 26, 2020 at 11:47 AM
    #57
    shane100700
    shane100700 Bed, Bath & Beyond Crawler
    Montana
    2019 DCSB, OR
    Rocket Boosters
    Dibs!
  18. Apr 26, 2020 at 12:13 PM
    #58
    71tattooguy
    Dino
    Petaluma , Ca (707)
    It’s all good bro. We all fuck up. Your good that’s all that matters right
  19. Apr 26, 2020 at 12:15 PM
    #59
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Now we know why insurance premiums are high. I’ll bet it’s a lease too:rolleyes:
  20. Apr 26, 2020 at 12:25 PM
    #60
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Looks like two door skins, bedside, dress / bondo on the doorsill and cab corner, plus paint. Probably $8000 all said and done at insurance rates. Since the truck is worth $35,000+, it will not be totalled by most insurance companies' metrics.
    Look on the bright side. Now you can comfortably enjoy your new truck off-road without worrying about pinstripes. :D
