Truck turned off while driving
Discussion in 'New Members' started by DMOFOG, Mar 27, 2016.
  1. Mar 27, 2016 at 9:26 PM
    DMOFOG
    DMOFOG [OP] Member
    2006 Tacoma V6 4x4
    2006 V6 4x4 180,XXX mi turned off while going about 65mph. Oil light came on as I was coasting in neutral. While coasting I attempted to turn on and it wouldn't turn over. While waiting for my ride, I cranked it and it fired up. But sounded and felt like it was about to die and sounded like it needed the gas pedal pumped to prevent it from dying. It died. Just cranked and cranked. ADVICE?! Alt? Batt? Sensor? Should I listen for fuel pump to kick on when I turn key? My Toyota buddy mechanic said its prob my alt. My engine light came on last month. And again 3 days ago but turned off. Autozone read said it was the catalytic converter sending a code.
  2. Mar 27, 2016 at 9:29 PM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    If the alternator fails the battery won't charge and soon you won't be able to start it.
  3. Mar 27, 2016 at 9:34 PM
    DMOFOG
    DMOFOG [OP] Member
    2006 Tacoma V6 4x4
    Would a bad alt cause it to shut off? I've replaced alt before and had them drain my battery on a jeep and mustang. But never had a vehicle die on the hwy. Thought if that were the case (bad alt), it wouldn't start after I would've parked it. That's always been my experience and found out but again. Never while driving....
  4. Mar 27, 2016 at 9:49 PM
    cosmicfires
    David
    Everett, WA
    I don't have any experience with vehicles shutting off as you describe but I assume if it was the alternator the battery would be too dead to start the truck.
  5. Mar 27, 2016 at 9:54 PM
    DMOFOG
    DMOFOG [OP] Member
    2006 Tacoma V6 4x4
    I had a friend show up to try and jump it. It cranked but didn't turn over. And we sat there for a good while. Thinking bout pulling both off and checking them at auto store. Hoping it's just alt. Thanks.
  6. Mar 27, 2016 at 9:58 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    The only time my truck died while driving was when the spark plugs were bad... Or maybe it was the coils... Idk but it was one or the other. I'd check those.
    DMOFOG[OP] likes this.
  7. Mar 27, 2016 at 10:02 PM
    DMOFOG
    DMOFOG [OP] Member
    2006 Tacoma V6 4x4
    I changed them about a year ago. Doesn't mean they can't go bad so ok. I will deffo keep that in mind. Thank you.
  8. Mar 28, 2016 at 11:56 AM
    DMOFOG
    DMOFOG [OP] Member
    2006 Tacoma V6 4x4
    IT WAS MY FUEL PUMP. $850 out the door. Apparently it's a pain to get to. Thanks for the feedback.
    DustStorm4x4 likes this.
