Truck turns sharper one way then the other
Discussion in 'Suspension' started by BackwoodsTaco, Mar 1, 2014.
  1. Mar 1, 2014 at 12:08 PM
    BackwoodsTaco
    BackwoodsTaco [OP] Well-Known Member
    Paul
    Stokes, NC (Eastern NC)
    Radiant Red 01 DC, 4X4, SR5, Supercharged
    TRD Supercharger, URD 7th injector kit, TRS RetroFit, Deck Plate Mod, No Chime Mod, Fog Light Mod, CB/ashtray Mod, 2.5" Spacer Lift, 1.25" Lift Shackles, 4 Tab Light Bar From Eddie209
    I just got my truck back from the body shop a few weeks ago and now my truck turns sharper the the left then it does to the right. When I turn to the left at full lock it scrubs the frame pretty bad. When it was in the body shop they had to replace my LCA, due to the miss hap, and I'm thinking that has something to do with it. Is there a way I can adjust it to get my steering back right or should I just take it back to the body shop?
  2. Mar 1, 2014 at 12:25 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Compare the front suspension at the left wheel vs at right wheel:
    1. Are there roughly equal number of threads showing on the tie rods?
    2. Are the lower balljoint piece installed the same way?
    Get an alignment done. Maybe front toe or caster is way off. Most body shops don't have an alignment jig.
  3. Mar 1, 2014 at 12:36 PM
    BackwoodsTaco
    Paul
    They got it alined after they did the work. It doesn't pull to either side and I don't feel anything odd when I'm driving. Should I post the alignment sheet?
  4. Mar 1, 2014 at 12:38 PM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    back to the shop! because you can. if it was fine before and now its all effed its probably their fault.
  5. Mar 1, 2014 at 12:40 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    What size tire do you have?
    With my 265/75/16 BFG AT's i rub the frame some at full lock, and have worn some paint off the frame, worse on the drivers side than the passenger side.
  6. Mar 1, 2014 at 12:44 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    The retard mechanic didn't center the rack when he put it back in (not sure why he removed it in the first place).
    Take it back and make them fix it.
  7. Mar 1, 2014 at 12:44 PM
    BackwoodsTaco
    Paul
    I've got 265/75/16 Destination M/Ts. But before my accident they barley rubbed the frame and now it rubs it really bad on the passenger side and don't rub at all on the driver side. My truck turns really sharp to the left but not as sharp to the right
  8. Mar 1, 2014 at 12:46 PM
    BackwoodsTaco
    Paul
    I'll call them monday and see what they say. Hopefully I can drop it off before I leave town for the week
