Truck update. Who doesn't like king shocks
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cameron knust, Mar 11, 2017.
  1. Mar 21, 2017 at 8:27 AM
    #101
    cameron knust
    cameron knust [OP] Well-Known Member
    true true. but for real anyone got ideas for replacing the stock bump stops that are to tall to allow full stroke of my shocks?
    ChadsPride and Midknight[QUOTED] like this.
  2. Mar 21, 2017 at 9:09 AM
    #102
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    The stock bumps are pretty short already, I'd almost say the kings in the rear are meant to be paired with a lift for more room for travel.
  3. Mar 21, 2017 at 9:11 AM
    #103
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    You can also tweak dakars quite a bit by pulling leafs from the pack. That way it gives you exactly the height and ride you need.
  4. Mar 21, 2017 at 9:15 AM
    #104
    cameron knust
    hmmm good to know ill do some research on my rear the front bumps are fine. maybe if i want to stay away from bump ill do a stiffer valving in the rear shocks. idk ill ask some shops. until next time. thanks fellas
  5. Mar 21, 2017 at 9:16 AM
    #105
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    This. If they Kings you bought are longer and intended for lifted applications there is a chance that the shock is bottoming out. One of the reasons I did not go with kings was most In Stock options were for lifted applications (2+ inches). As such at stock ride heights you would need to extend your bumps to stop the shock from bottoming out or risk blowing the shock. The icons I bought were for 0-2 inches of lift and since I am running a 1 inch lift in the rear they fit the bill perfectly without having to custom order a shock.
  6. Mar 21, 2017 at 9:20 AM
    #106
    cameron knust
    as far as i know they werent they were direct plug and play 2.5s the 25001-121 kit didnt need to compress the shock she slapped in perfectly it does sit lower than i expected most people with kings in the rear i see their resis higher. so ill post a photo from my phone. but im thinking now its going to need tuning.
  7. Dec 30, 2018 at 7:08 PM
    #107
    wtfpenguin
    wtfpenguin Well-Known Member
    Menlo Park, CA
    2010 + 2013 MGM Taco 4x4 OR
    Reminder icon sucks!
