Truck very tipsy
Discussion in '4 Cylinder' started by silverback, Nov 21, 2009.
  1. Nov 21, 2009 at 2:12 PM
    silverback
    silverback [OP] Well-Known Member
    central CA
    2006 Prerunner SR5
    painted door handles, bilstein 5100's front and back, K&N air filter. Precision power component speakers and Kenwood deck.
    I was driving down the road yesterday and decided to check the body roll on this truck. Holy crap I felt like the truck was going to tip over. I was only doing 40. Severe body roll. This is an 06 reg cab pre runner. If I just switch to the bilstein 5100's will this solve some of the problem. Or do I have to completely replace both side leaf springs. I cant dodge a thing so watch out granny.:eek:
  2. Nov 21, 2009 at 2:13 PM
    silverback
    central CA
    2006 Prerunner SR5
    No lift that I know of. Tall stance though.
  3. Nov 21, 2009 at 2:13 PM
    RoyB
    RoyB Well-Known Member
    Chicago burbs
    '09 TRD DC Sport
    body roll improved immensely with the larger leaf springs on my truck fwiw.
  4. Nov 21, 2009 at 2:17 PM
    moto932
    moto932 What's the matter, Colonel Sandurz? CHICKEN?
    Eric
    Dayton, Ohio
    04 TRD Off Road
    Basically stock. OME 882s, HD Dakars and nitrochrgers, TG front bumper, custom rear bumper, 4Xinnovations sliders, RAT skids, Softopper, 255/85/16 ST MAXX's on 16" steelies, 1" B.O.R.A. wheel spacers Scangaugae II, deck plate mod, grey wire mod,ECGS bushing, diff breather relocation, alarm mod, defrost w/o compressor mod, de-badged, sockmonkey beside decals.
    has your sway bar been removed?
  5. Nov 21, 2009 at 3:30 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Take this as a grain of salt....but....
    The truck is probably fine. It's your ass-meter that's too sensitive. I've seen this countless of times offroading. It's an 'unnaturdal' feeling and why you suspect its tippy.
  6. Nov 21, 2009 at 3:33 PM
    copernicus
    copernicus Well-Known Member
    Does your truck have a bench seat? The first day I got my truck I felt like it was rollover across the highway.
    My regular cab feels floaty, and the bench seat does nothing to keep you in place.
    My future lowering springs and swaybar will undoubtedly help.
  7. Nov 21, 2009 at 4:50 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    Simply put as a broad generalization, offroad supple is opposite of on road performance. Trying to to combine towing and offroadability is always difficult, let alone slaloming like a car.
    If you want stability on road get sway bars , or get bigger sway bars ,lower it too with smaller tires or lowering kit. TRD offroad and onroad performance wont combine well, like an f-15 that cant seem to corner on the runway at 100 mph.
    Reg cabs being shorter have quicker steering/ 36' turn radius , sorta feels floaty that way.
  8. Nov 21, 2009 at 5:57 PM
    Reaper22
    Reaper22 Well-Known Member
    Palmyra Missouri
    SR5 Tacoma
    Radient Red, Red Grille, Debadge'd, Blacken'd Headlights, DTRL's, Cruise Control, Fog Lights, 2 1\2" suspension lift, 285\75\16 Nitto Dune Grapplers, Pioneer Premier DEH-P510UB stereo, Pioneer 3 way fronts with factory tweeters & Kenwood tweeters, Kenwood truck boxes behide seats with 8" subs in each, Wet suit like tacoma seat covers
    Mine felt that way till I put some Spidertrax spacers all way around..
  9. Nov 21, 2009 at 6:16 PM
    Tacoyota
    08 4wd
    On my old 97 Dakota, I went from 15" to 16" rims,combined that with a 70 sidewall instead of 75. Just that alone really firmed it up w/o making it feel stiff. What body roll was there wasn't a problem after that.
  10. Nov 21, 2009 at 6:24 PM
    cheehab
    cheehab I bleed Black and Gold
    Adam
    Winter Park, CO
    2015 Tundra TRD Pro CrewMax
    I'm loving the diversity of the suggestions in this post!:)
  11. Nov 21, 2009 at 6:38 PM
    Tacoyota
    08 4wd
    Tough topic, so many variables possible. Assuming its stock, I doubt there is a problem. Trucks lean when cornering, hell, I bet a geo metro could out corner a 4wd taco.I think of it as a design characteristic, not a design flaw.
  12. Nov 22, 2009 at 11:44 AM
    xsvtoyz
    xsvtoyz Well-Known Member
    AL
    Oklahoma
    03 Pre-Runner Inprogress
    HID (ACA)/ Web cams/ Header/Full Custom exhaust/ K&N FIPK II/SuperCharger
    what tires are you running? size? psi? I was running some hwy treads and they seem to give the same feeling like jello when I whipped the wheel back and forth. I now have commercial grade tires with some stiff sidewalls and they helped the jello feeling and upped the psi to about 35 all the way around. It does not seem to wobble with the wheel whips but the heavier tires sure impacted the mpg.
  13. Nov 22, 2009 at 2:06 PM
    RoyB
    Chicago burbs
    '09 TRD DC Sport
    they have larger swaybars for these trucks?! where do i get them!
  14. Nov 22, 2009 at 2:36 PM
    Tacoyota
    08 4wd
    not sure if they are larger , but eibach or hellwig make a set I think
  15. Nov 23, 2009 at 9:37 AM
    ToeCutter66
    ToeCutter66 Active Member
    Kevin
    Sterling VA
    09 4x2 5-lug
    None, yet.
    I have an 09 5-lug regular cab auto that I push very hard through the turns, tires howling etc, and I don't feel as if I get much body roll. My other ride is a 2004 Infiniti G35 Sport Sedan 6mt, that car is rated at 0.9gs of lateral grip, and I push that way harder than my truck. So as a comparision I do not feel that my truck has bad body roll, but it is a tiny 5-lug that is way lower to the ground.
  16. Nov 23, 2009 at 10:05 AM
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
    If it's tipsy, perhaps you should stop using the ethanol gas they give you guys down there in the States!! :eek::eek: ;)
  17. Nov 23, 2009 at 10:38 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    sway bar might have been removed. I had mine pulled off for offroading and it definitely helped offroad but lent to a lot of body roll under hard cornering. I just put it back on this weekend and now unless i'm going to go on an off roading trip, i think it will stay on.
    Other than that recommendation, tire pressure, type/profile of tires, and understanding that its a high-profile truck are all things to think about.
  18. Nov 23, 2009 at 6:25 PM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    yes they do :D
    but no, you can't get them:D
    theyre for 5 lug trucks :D
  19. Nov 23, 2009 at 6:27 PM
    Kelson
    Kelson
    Honolulu, Hawaii
    id have to say the 5 lugs and the 6 lugs have comprable handling...the 6 lugs are higher up but have a much higher spring rate than our trucks...i drove my dad's truck for awhile and now mine....and id have to say the 6 lug trucks don't have an excessive amount of body roll
    i would have to say the OP should check his swaybar
  20. Nov 23, 2009 at 10:30 PM
    silverback
    central CA
    2006 Prerunner SR5
    Well The truck is a pre-runner not a 4x4. I currently have 265/75/16 toyo countrys. My psi Is 34 all around. The back end sits about an inch taller than the front so im not sure If the previous owner added a leaf for better load carrying. You are right on with the jello comment, thats exactly how it feels. I will be replacing the tires with General Grabber AT2 same size. Maybe that will help. Im not looking to do slalom in this truck just a little freaked how I feel like im riding around on Slinky springs. The truck is completely stock.
