truck vibration between 50-55MPH
Discussion in 'Technical Chat' started by Detective_Dan, Apr 13, 2011.
  1. Apr 13, 2011 at 11:22 AM
    Detective_Dan
    Detective_Dan [OP] "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    before anyone says anything, yes i searched but there are too many threads on this subject to get a pinpoint answer.
    i have a 2010 prerunner DCSB, 5100s set @ 2.5 w/ stock coils, and stock UCA's up front with the harsh ride TSB installed from dealer in the rear w/ stock shocks. truck has 25,xxx miles. 285/75/16 hankook dynapro atm's on pro comp 8069's all around.
    ok so heres the scoop...
    anywheres between 50-55MPH, i am getting a fairly rough vibration that feels like it is coming from the rear of the truck, but i can still feel it in the steering wheel. IT WAS DOING THIS ON STOCK WHEELS, TIRES AND SUSPENSION, so dont say its because of the lift, the lift had no effect on it at all.
    i have checked and double checked all suspension (front and rear) and steering components and driveshaft multiple times and i can not find the cause.
    my thought at this point is that it is the carrier bearing, but i dont know how to tell if the bearing is bad. the rubber inside the "bearing" is fairly soft and i can wiggle the driveshaft around about 1/4 of an inch in all directions, but the rubber is tight against the driveshaft. the bolts holding the bearing to the truck are torqued.
    is the carrier bearing supposed to wiggle around this much? this is my first RWD vehicle so im not familiar with driveshafts.
    i am driving from new mexico to florida, and then back (about a month later) near the end of may and i would like to get this problem figured out before i drive 2000 miles when something could possibly be wrong.
    any input from someone who has had this problem?
  2. Apr 13, 2011 at 11:42 AM
    Detective_Dan
    Colorado Springs
    here is the bearing. sorry for the semi blurry pics, but my camera isnt the greatest.
    it doesnt look bad to me so i am deffinantly at a loss here
  3. Apr 13, 2011 at 11:44 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Check the angle of your drive line you may be the carrier bearing drop bracket I know I did.
  4. Apr 13, 2011 at 11:46 AM
    Detective_Dan
    Colorado Springs
    its not at any serious angle though, and it did it on stock suspension setup so i dont see how it can be at a too extreme angle from factory like that
  5. Apr 13, 2011 at 12:40 PM
    TAQUERO
    TAQUERO Well-Known Member
    RUBEN
    RIVERSIDE (SO CAL)
    06 TRD OFFROAD 4X4
    Bilstein 5100s set at 2.5 up front, icon aal 1.75, 6K HID headlights and foglights, foglight mod, limo tint, Weathertech floorliners. 17x9 XD Addicts 265/70/17 Hankook Dynapro MT
    Balance tires??
  6. Apr 13, 2011 at 12:58 PM
    Detective_Dan
    Colorado Springs
    its not a tire issue, ive had them balanced three times in the past 1000 miles, no difference.
    i know what an unbalanced tire feels like and this is different
  7. Apr 13, 2011 at 1:03 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I have the same vibration on my stock set up .
    Did you have it before your lift ?
  8. Apr 13, 2011 at 1:04 PM
    Detective_Dan
    Colorado Springs
  9. Apr 13, 2011 at 1:08 PM
    OZ-T
    Peter North
    British Columbia
    Missed that .
    I think that it is a wobble in the CB mount myself .
  10. Apr 13, 2011 at 1:09 PM
    Detective_Dan
    Colorado Springs
    cb mount is ??????? what lol
  11. Apr 13, 2011 at 1:11 PM
    OZ-T
    Peter North
    British Columbia
    The carrier bearing as you mentioned above .
  12. Apr 13, 2011 at 1:13 PM
    Detective_Dan
    Colorado Springs
    ahh gotcha, i was tryin to figure out what it meant haha. i dont want to spend the $100 or so on a new bearing and it not be the problem though
  13. Apr 13, 2011 at 1:15 PM
    OZ-T
    Peter North
    British Columbia
    Check out Beefed Tacos CB drops
  14. Apr 13, 2011 at 1:16 PM
    Detective_Dan
    Colorado Springs
    its just a 1/4 inch bracket right?
  15. Apr 13, 2011 at 1:21 PM
    OZ-T
    Peter North
    British Columbia
    No , it's not a shim , it replaces the OEM bracket and adds an additional bolt into an unused factory bolt hole there to make the mount stiffer .
  16. Apr 13, 2011 at 1:24 PM
    Detective_Dan
    Colorado Springs
    hmm, ill look into that. do you think a drop bracket might be the fix in this case? i have some metal bar stock layin around that i could easily cut and drill.....
  17. Apr 13, 2011 at 1:47 PM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    does it feel like a big cat purring. sorry theres not really any other way to describe it.
  18. Apr 13, 2011 at 1:53 PM
    THROUGHITALLDUDE
    THROUGHITALLDUDE Someone didnt put the tailgate down!
    Jeff
    Southern California
    2005 Silver Tacoma
    285-75-17 Definity ATs - 16'' Chrome Moto Metal 951s - 4'' Maxtrac spindles - Rear Icon Progressive Leaf Pack - Magnaflow exhaust - Aftermarket LED Taillights - BHLM - Custom Wet Okle Seat Covers - Moog Tire Rods - US Spec Ipod - K&N High Flow Filter - Daytime Running Lights - TRD Skid Plate - Grillcraft - Hellas Mounted behind the grill
    I just had this issue and I put a CB drop and it fixed it. But it could be your U joint angles I just replaced all my U joints so I would take it to a shop to have it looked at or if you feel its the CB get the drop and it could work.
  19. Apr 13, 2011 at 2:59 PM
    OZ-T
    Peter North
    British Columbia
    Mine is more of a whup whup whup
  20. Apr 13, 2011 at 3:24 PM
    Detective_Dan
    Colorado Springs
    same
