truck wanders at highway speeds after level kit instalation
Discussion in 'Suspension' started by EXLRATE, Sep 12, 2017.
  1. Sep 12, 2017 at 2:11 PM
    EXLRATE
    EXLRATE [OP] Member
    james
    2017 white tacoma trd sport
    I was hoping someone could help me with the alignment specs for my 2017 Tacoma trd sport 4 door. I installed a 2" leve kit on it and the alignment would not go into spec with stock uca
    so I purchased there uca and it brought camber to spec but caster is what I think is wrong
    it only has 1.25 pos. caster and at highway speeds it seems like I cant keep it between lanes
  2. Sep 12, 2017 at 2:13 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Def need more castor. What UCA did you get?
  3. Sep 12, 2017 at 2:14 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Sub'd
    geekhouse23 likes this.
  4. Sep 12, 2017 at 2:24 PM
    EXLRATE
    EXLRATE [OP] Member
    james
    i bought the cheapie kit from rough country and it came with the disc that went on top of the strut and blocks under rear axle with rear shocks so i wanted to stay with rough country and i bought rough country uca but cant get any more caster,prob should have went with different kit huh
  5. Sep 12, 2017 at 2:27 PM
    EXLRATE
    EXLRATE [OP] Member
    james
    any thoughts on the eibech uca......they claim to be able to get +or- 4degrees of caster
  6. Sep 12, 2017 at 2:27 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    [QUOTE EXLRATE, post: 16019511, member: 229824"]i bought the cheapie kit from rough country and it came with the disc that went on top of the strut and blocks under rear axle with rear shocks so i wanted to stay with rough country and i bought rough country uca but cant get any more caster,prob should have went with different kit huh[/QUOTE]
    Yup that company is generally referred to on here as Junk Country, should have done more research before purchasing a lift. You have a link to this said kit? I am guessing it is Hockey Puck spacers.
  7. Sep 12, 2017 at 2:28 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
  8. Sep 12, 2017 at 2:30 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Totally should have, but, let's work with what you got. Seems to me that the 2" level kit is more than just 2". Measure just how thick the spacer is and you pretty much multiply that by 2 to get the amount of lift it will give you. Next, compare stock UCA'S to the aftermarket ones. Take a stock UCA from passenger side, flip it, and compare it to the driver side aftermarket UCA. Are they the same? How do they differ? Is the aftermarket BJ further back than the OEM? Are the arms shorter or longer? I ask this because I haven't had the opportunity to do a rough country lift yet.
  9. Sep 12, 2017 at 2:35 PM
    EXLRATE
    EXLRATE [OP] Member
    james
    i will check texcoma
  10. Sep 12, 2017 at 2:37 PM
    EXLRATE
    EXLRATE [OP] Member
    james
    i cant see the link to the person to call and talk to you sent me
  11. Sep 12, 2017 at 2:39 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    headstronoffroad.com but I will set a Private Message with you and her so hold on.
  12. Sep 12, 2017 at 4:08 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    You should be able to get a better alignment WITHOUT aftermarket uppers. Shitty alignment tech or frozen eccentrics.
    Unchained 5150 likes this.
  13. Sep 12, 2017 at 8:57 PM
    EXLRATE
    EXLRATE [OP] Member
    james
    thanks for your help guys,ill do some more reading
