truck wants to "follow the road"
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cevallos.j, Feb 14, 2012.
  1. Feb 14, 2012 at 12:44 PM
    cevallos.j
    cevallos.j [OP] Well-Known Member
    Jorge
    Coronado
    2006 Prerunner access cab
    I just got new wheels and tires installed on my truck, both used, it is a 2006 access cab 2wd. tires are 265/70/17
    Before changing tires i did not have this problem, but now it feels like the truck wants to follow the road, if there is a bump or unleveling of the road, it feels like the tires catch on it and it wants to follow it. Its pretty bad and it will jerk the truck around, especially on the little bumps that separate lanes.
    What could I check besides allignment?
    maybe something down there is loose
    I thought it might just be the bigger tires but my dad drove it and said something is no doubt wrong.
    Thanks guys
  2. Feb 14, 2012 at 12:45 PM
    S.S.T.
    S.S.T. Well-Known Member
    Torrance, CA
    07 TRD Off Road Access Cab
    Icon 2.5 Extended Travel Coilovers, 5100 rears, Icon Progressive 3 leaf AAL, Hankook Dynapro ATM 265/75R16, 16x8 Renegade 6 wheels, AFE Pro Dry S air filter, BHLM.
    Alignment. Should solve your problems.
  3. Feb 14, 2012 at 12:47 PM
    himmie
    himmie No.
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Yes.
    Could be an issue with the actual tires, as well. Could try a rotation and see if the pull goes away.
  4. Feb 14, 2012 at 12:49 PM
    S.S.T.
    Torrance, CA
    Just noticed that you said the tires are used. How many miles? Are they worn evenly?
    I would still get an alignment to rule that out, then go from there.
  5. Feb 14, 2012 at 12:51 PM
    cevallos.j
    Jorge
    Coronado
    they have about 60% left. ill get alignment checked and let you guys know,
    thanks for the quick reply
  6. Feb 14, 2012 at 12:51 PM
    magnew
    magnew Well-Known Member
    Ft. Collins, CO
    TRD
  7. Feb 14, 2012 at 12:58 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Radial tires are directional. Once they're mounted and used in a direction, they should always be run in that same direction. That's why when you rotate tires you keep move them front/back but keep them on the same side of the truck.
    Pay attention to the wear marks before you put too many miles on there and see if you can figure out how they were mounted by the previous owner.
  8. Feb 14, 2012 at 12:59 PM
    jeremy_283
    jeremy_283 Super Member
    08 TRD Offroad Access Cab 4x4 Auto 4.0L
    Hella Rallye 4000 Cornering Lights PIAA 510 Fog Lights All Pro Front Bumper All Pro Rear Bumper All Pro Transfer Case Skid All Pro IFS Skid All Pro Rock Sliders All Pro High Clearance Hitch OME Dakar Leaf Springs OME Rear Shocks OME Front Shocks OME 885 Front Coils Wet Okole Seat Covers WeatherTech Floor Liners Sony Head Unit JL XD600/1 Amp 2 JL Audio 10” Subwoofers Custom Subwoofer Enclosure Kenwood Front Speakers Sony Rear Speakers Sound Deadening Mats LED Interior Lighting Pop N’ Lock Tailgate Lock Viper Alarm System Extra D-Rings In Truck Bed Maglite Seat Mount Disable Seatbelt Chime Rear Differential Breather Relocation Hi-Lift Bed Mount Flexible Front Mud Flaps 110v Inverter Always At 400w ABS Kill Switch Locking Center Console Removed Sway Bar
    I saw the title and instantly though of the Stephen King movie "Christine"
