Truck was stuck in snow. Now it feels sluggish and horrible (Manual Transmission)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BangosTaco, Mar 1, 2021.
  1. Mar 1, 2021 at 3:20 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    It was a bit of a joke, if you smelled burning smell, your clutch is done sorry.
    philth likes this.
  2. Mar 1, 2021 at 3:24 PM
    sbb
    sbb Active Member
    CNY
    2020 Red OR DCSB, 2006 Indigo OR
    Highly customized radio presets / Metric fuel adapter
    Also the obvious... how well does it coast once moving? Get it on a road and see if it rolls without drag. That answer will eliminate a bunch of culprits.
    Good luck!
  3. Mar 1, 2021 at 3:33 PM
    Skidog1
    Skidog1 Well-Known Member
    Chicagoland
    2016 Black TRD 4x4 Sport DCLB
    If you do drive it stop and see if any wheel it hot. Check it very lightly with a gentle quick pat so you don't get burned.
    D2. and philth like this.
  4. Mar 1, 2021 at 3:36 PM
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    I smoked the clutch in my Jeep from getting stuck in the snow. Sounds very similar lol.
    whatstcp, philth and Junkhead like this.
  5. Mar 1, 2021 at 3:37 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Were you in 4hi?
  6. Mar 1, 2021 at 3:45 PM
    CalcityRenegade
    2023 T4R ORP KDSS
    Yep. Was young and dumb. Now I am just dumb... LOL
  7. Mar 1, 2021 at 3:54 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Haha!
    Yep, 4hi is terrible for those situations.
  8. Mar 1, 2021 at 3:56 PM
    philth
    philth .
    I hope OP comes back to update what the issue is/was and doesn’t just bail lol
  9. Mar 1, 2021 at 4:16 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    You fvcking Canadians hovering around like vultures...
    Im in for the outcome...i'll side with the clutch guys on this one
  10. Mar 1, 2021 at 4:18 PM
    BangosTaco
    BangosTaco [OP] Well-Known Member
    2020 Toyota Tacoma TRD PRO [MT]
    Stock
    That's the thing. It drags when it's moving.
    You made me remember something I tested the other night out. I tried to down shift 5th to 3rd from 50MPH without pressing any gas. The RPM drops like crazy. Shouldn't the RPM go up?
    t@com@, sbb[QUOTED] and Junkhead like this.
  11. Mar 1, 2021 at 4:19 PM
    BigBlueTexas
    BigBlueTexas Well-Known Member
    I too experienced some weird shi* when we got hammered here in Texas with all the snow. We had two snow dumps, during the first dump, I drove around town in 4H and kept it in 4H at the end of the day when I garaged BigBlue for the night. Every time I left the garage it seemed like the tires were frozen to the concrete. Rev it up a bit and ease up on the clutch and it would start to stall. Kinda started getting pissed coz I can't move forward so I shift it into reverse and BAM ! The tires broke loose and I was on my merry way. I too did smell a slight scent of something burning but there's no way it was the clutch (at least I hope not). During the 2nd dump, I put it back into 2H when I was done for the day and never had that "frozen tires to the concrete" ever again. It's been over a week since the storm and everything seems in order. Can somebody please explain.
  12. Mar 1, 2021 at 4:22 PM
    TRD Ted
    TRD Ted Well-Known Member
    2020 Army Green TRD Pro
    Dealer says it’s normal.....
    trktwo, Junkhead and philth like this.
  13. Mar 1, 2021 at 4:27 PM
    philth
    philth .
  14. Mar 1, 2021 at 4:31 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Good lord, using 4hi isn't going to cause any damage. In fact for snow hi range is less likely to spin tires than lo range. Not saying the clutch isn't damaged, but it isn't because he was in high range. If you're stuck you're stuck. You reach a point where you come at it from a different angle. You need to dig it out. Repeatedly spinning wheels just overheats everything and causes more harm than good.
    1 Dead After Car Gets Stuck In Snow, Catches Fire In New Jersey – CBS New York (cbslocal.com)
  15. Mar 1, 2021 at 4:35 PM
    #35
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
    they should unless the clutch is slipping really bad....might be another sign that it is dead
  16. Mar 1, 2021 at 4:40 PM
    #36
    averagejp
    averagejp Well-Known Member
    2005 Black Tacoma Extended Cab
    Work in progress
    Question for you, if you don't mind. I know you drive a stick. What is the cost to replace the clutch, ballpark? Was just curious. I don't drive a stick but wanted to know if you had any experience with the cost to replace.
    philth and Junkhead[QUOTED] like this.
  17. Mar 1, 2021 at 4:47 PM
    #37
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    I honestly never had to replace a clutch in any of my vehicles. Not sure where you are, but in Canada it could be anywhere between 600-1200, depending on labour and parts.
  18. Mar 1, 2021 at 4:53 PM
    #38
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    I respectfully disagree sir.
    Do you drive a manual off road? Even backing up in 4hi will burn the clutch, you are at a big disadvantage. Give me any truck and I can burn the clutch in 4hi in under a minute, OP was stuck for 10hrs and was in 4hi trying to get out...
    ATs have a torque multiplier, MTs torque multiplier is the transfer case.
  19. Mar 1, 2021 at 4:55 PM
    #39
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Your clutch is done sir.
  20. Mar 1, 2021 at 4:58 PM
    #40
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    This.
