Truck will barely move
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Otis1382, Jan 2, 2018.
  1. Jan 2, 2018 at 2:55 AM
    Otis1382
    Otis1382 [OP] Well-Known Member
    warren
    Chelsea Al
    '16 DCOR 4x4 quicksand
    So I got off work this morning and got in my truck to warm it up. I released the parking brake and put it into gear. Truck would not move without considerable gas. Thought it might be the e brake. Tried releasing and applying it. Didn't help. Any thoughts?
  2. Jan 2, 2018 at 3:20 AM
    AeroCooper
    AeroCooper Half the strength of ten (microscopic men)
    NH
    2018 Barcelona Access Cab Off Road
    Remote start, tailgate inserts, nifty key fob case, Husky X-Act floor liners, AVS vent shades, bed mat, MX4 Tonneau cover, Tyger step rails
    Try gently tapping the drums with a hammer a few times.
  3. Jan 2, 2018 at 3:49 AM
    Otis1382
    warren
    Chelsea Al
    I tried that. Saw it in some earlier threads.
  4. Jan 2, 2018 at 3:52 AM
    Otis1382
    warren
    Chelsea Al
    Called a tow truck. I assume it's something more than the e brake. Tried cycling the 4wd. It won't go into 4wd
  5. Jan 2, 2018 at 4:37 AM
    tibadoe
    tibadoe Well-Known Member
    Joe
    Gladys, VA
    17 Tacoma SR 4X4
    My guess is rear brakes froze. When you parked, were the brakes wet? Don't take much if it's cold outside. Let us know the outcome.
    captn.fat.beard and Otis1382[OP] like this.
  6. Jan 2, 2018 at 5:24 AM
    Flyinbrianbmx
    Flyinbrianbmx Well-Known Member
    2016 Blue Tacoma SR5 Rockstar
    your drum brakes are frozen, I've read you can put it in drive the reverse then drive until it releases. Don't use your e brake in freezing temps
    robssol and Otis1382[OP] like this.
  7. Jan 2, 2018 at 6:00 AM
    Otis1382
    warren
    Chelsea Al
    Not wet. Also, when the tow truck winched it on just the the back passenger tire would lock up. I tried forward and reverse to no avail. At dealership now.
  8. Jan 2, 2018 at 6:40 AM
    strotman
    strotman Well-Known Member
    Do you happen to live in the lower mainland? Keep us posted, this happened to me yesterday. Could go in reverse but that was about it. Eventually it drove.
  9. Jan 2, 2018 at 8:03 AM
    Otis1382
    warren
    Chelsea Al
    Alabama. one time when I was offroad with some of the guys from the Alabama thread the same wheel locked up on me. they were yelling that I was still locked but I had already taken it out. this and the fact that I was eating at my tires I figured id just take it to the dealer. still under the 36k warranty. should find something out in a couple of hours.
    Jerry311SD likes this.
  10. Jan 2, 2018 at 8:39 AM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    Sounds like frozen drums--I've been trying to get into a habit of not using my ebrake due to freezing temps and not wanting to deal with this issue.
    Otis1382[OP] likes this.
  11. Jan 2, 2018 at 12:56 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    I've NEVER had an issue with the park brake freezing, but I live in a COLD climate....it stays cold till spring... AND I always set the park brake when I put it in Park. (keeps my drum pads adjusted also)..
    You guys in an "off n on" climate where you are wet today froze tomorrow, this issue might happen...!!
    Pretty bad if you gotta tow it for that.... I'd think I'd try to find some dry pavement and run her forward/reverse a few times..
    Good luck... let us know what the issue is...!
    SOSC, Otis1382[OP] and shakerhood like this.
  12. Jan 2, 2018 at 4:07 PM
    Frankenstuff
    Frankenstuff Busy iracing
    Frankie
    16TRDORDCsb 4x4 & 2020 BMW M2 competition
    16 trd ORdcsb4x4 c4 swingout rear, cbi t3 front , arb lift,16"grabber x3 rtt, hilift,jerry cans,and sliders . 81 hilux trail donkey
    16 degrees in my area this morning . I parked my truck Friday with the ebrake on . This morning it was frozen . I worked it free and drove 32 miles to work and when I got there the screw compressor was frozen (line coming out ) so I hopped back in and went for some diesel for a heater an hour later and whoops engaged the parking brake ..Yep frozen lol.
    They free up pretty quick though. Ebrake not set tonight.
  13. Jan 2, 2018 at 4:32 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    So weird how this seems to affect so many and also none at all. Thankfully I have had no issues after washing it or letting it sit extended periods in high and low temps.
    Lt. Dangle likes this.
  14. Jan 2, 2018 at 4:43 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Same here, but this and other threads have changed my habits on using the parking brake. For now anyways.
    shakerhood[QUOTED] likes this.
  15. Jan 2, 2018 at 4:50 PM
    shakerhood
    Southern Ohio
    I have been driving 35 years and never once have I had a handbrake freeze, we had a terrible ice storm about 10 years ago where it took me 3 days to get a door open on my 1st Gen Taco and the tires were frozen solid to the ground! Maybe it is a bad design in these 3rd Gens but now I am also starting to reconsider not using it.
    Clevername and kgilly like this.
  16. Jan 2, 2018 at 5:02 PM
    Cole man
    Cole man I like a clean taco....
    Paul
    Bluegrass state
    2017 tacoma SR 4x4 V6 MGM
    Stock so far
    So what was the problem?
  17. Jan 2, 2018 at 5:05 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    I had it happen one time on my current rig. Popped loose after a couple forward to reverse cycles. Drove 20 miles in slushy conditions only to park it outside as temps dropped well below freezing.
    Never on my other 2 Tacos
  18. Jan 2, 2018 at 5:17 PM
    Plain Jane Taco
    USA
    I think it was a combination of wet + flash rust + frozen components. Kind of a perfect storm
    shakerhood likes this.
  19. Jan 2, 2018 at 6:04 PM
    Syncros
    Syncros Well-Known Member
    Had it happen a few times with my 2nd gen. A few times offroad too, dust, sand etc gets in the drums and jams the parking braje mechanism.
  20. Jan 2, 2018 at 6:28 PM
    Frankenstuff
    Frankie
    Nope. No rain for a week and I did not wash it . 16 degree weather will do it with an hr to sit though I'll never use the ebrake again if its below freezing. Kind of eager to see what happens tomorrow.
    Kind of feels like I'm making an ice road trucker run.
    I'm gonna pull the drums and grease up (very lightly)a couple things .
