Truck will click once when key is turned
Discussion in 'Technical Chat' started by TimberLandTaco, May 16, 2015.
  1. May 16, 2015 at 5:08 PM
    TimberLandTaco
    TimberLandTaco [OP] Well-Known Member
    Mason
    Northeast Oklahoma
    2012 Timberland Mica TRD Offroad
    Light, Bumpers, and lots of switches.
    The other day I crossed a flooded road. It got to where the wake from me moving forward was splashing over the top of my hood. Didn't cause any immediate problems. Since then I haven't had a problem until yesterday. Everything has been fine and then I got in my truck to go to lunch yesterday. It clicked once when I turned the key. Tried again and it fired up. After work (approximately four hours later) the same thing. I had my mechanic check it and he said it was a bad battery but my alternator is putting out the right amount. I went and bought a new battery and went to start it and it clicked once with each attempted start (tried five or six time) and on the last attempt it started. When it started I let it run for about 10 minutes and then killed it. Immediately after the truck would start up every time. An hour later I tried it again and the truck barely started. I have no clue what it is. Any help is appreciated.
  2. May 16, 2015 at 8:36 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    If the battery it good and there's enough voltage to charge battery, but it clicks when you try to start it, your starter is done.
    I had that happen. Started got wet, it would click click click click start. After a while it stopped clicking and would just work every time. Still using that starter.
  3. May 16, 2015 at 8:50 PM
    TimberLandTaco
    Mason
    Northeast Oklahoma
    I hope the same works for me. The thing that gets me is that after it starts up and runs its good for a little bit. But after I let it sit it goes back to click click click click start.
  4. May 16, 2015 at 9:47 PM
    CASTRATE
    CASTRATE Well-Known Member
    Gabe
    SW of Tulsa, OK
    2012 4x4 SR5 6spd
    I had to replace the starter in my pathfinder a couple weeks after a water crossing. Was riding shotgun in a jeep & went through a deep mud hole with water about 8" up the door. The next day, my buddy called me needing a ride to work 'cause his starter was shot.starters & alternators aren't known to like water
  5. May 16, 2015 at 9:53 PM
    high n mighty
    high n mighty Well-Known Member
    Oshawa Ontario
    01 camo taco
    Sounds like a starter to me
  6. May 16, 2015 at 10:12 PM
    millertime89
    millertime89 Flatlander
    Erik
    Saskatchewan
    06 TRD Sport DCLB 4x4
    Yes sir
    I also agree it's the starter; the mechanic you had check out your truck should have known that if the battery was fine then it was most likely the starter and he should have checked it out.
    The starter in my dad's F350 went a couple years ago, same thing with how it would 'click' and then fire. Kept getting worse until eventually I'd turn the key and it would click but would never fire.
    Starters aren't that expensive though, usually about $100. The expensive part is if a mechanic is installing it for you at $100 an hour.
  7. Jun 18, 2015 at 7:27 AM
    Tacodriver08
    Tacodriver08 To have faith, is to trust yourself to the water
    Texas
    05 X-Cab 4x4
    Too many to list
