Truck Will not Idle
Discussion in '1st Gen. Tacomas (1995-2004)' started by shaggie, Jan 6, 2013.
  1. Jan 6, 2013 at 10:02 AM
    shaggie
    shaggie [OP] New Member
    sean
    CA
    01 Tacoma 4WD
    I own a 2001Tacoma 4WD with a 2.7L engine. With 245k on the truck, it still runs strong; however, the truck has developed a problem. Yesterday, I tried starting the truck from a cold start and it did not want to idle. The truck would run only if I kept my foot on the gas and the engine revved up; however, when I removed my foot from the accelerator, the engine would die. Could this be an O2 or mass air flow sensor? I just cleaned the mass air flow sensor about six months ago with a cleaner designed for that purpose. I have not seen an error code or a check-engine light on the dashboard, and the truck runs great as long as I keep the engine revved up. This problem happened overnight Any suggestions? Would appreciate the help.
    Thanks,
    Shaggie
  2. Jan 6, 2013 at 10:08 AM
    Tacoma Mike
    Tacoma Mike 42 Year Toyota Master/ASE Master Tech.
    Southern Maine
    2011 Double Cab V6
    Large Storage Box, 02610 intermittent switch swap, "Hot Wire" Power Outlets, DRL Shut Off, Disable Fob Beep, Disable Seat Belt Buzzers, Parking Light Mod, Battery Tender, 4 Leaf Spring Pack, Rear Headrest Removal, Custom Ultragauge Mount, Factory Tow Package (7 Pin) Rear Diff Mod, Taco Lean Mod
    I would start with cleaning the throttle body..
  3. Jan 6, 2013 at 10:10 AM
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
    Maybe a Mod could also move this to the 1st Gen section, where the OP may get more advice.
    Best of luck.
    Frank
  4. Jan 6, 2013 at 10:20 AM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    Idle air control valve would be my first guess. I would clean throttle body and iac and then try it. Mine 1st gen v6 3.4 and my fathers 3.4 both developed idle issues. Cleaned the throttle body and iac and no more problems.
  5. Jan 6, 2013 at 11:38 AM
    Madjik_Man
    Boulder, CO
    1998 Ext Cab 4x4 TRD 5MT sunfire red pearl
    About 25 pounds of spray paint and vinyl dye
    This. And if it persists after that, maybe the throttle position sensor is bad?
  6. Jan 6, 2013 at 2:57 PM
    Tacomaniacal
    Tacomaniacal luv gettin in the Taco
    South Florida
    '01 double cab 3.4 2WD
    Custom grille, 7" Pioneer touchscreen DVD/iPod player, Dunlop Fierce Attitude 265/75/16 M/T
    Clean the throttle body first. If persists check the idle control valve
  7. Jan 6, 2013 at 3:06 PM
    2000GTacoma
    Snow Hill NC
    In order to throughly clean the tb it should be removed imo. only takes about 10-15mins. I would clean the iac as well since it is easily accessed.
  8. Jan 6, 2013 at 4:11 PM
    BamaToy1997
    BamaToy1997 ASE Master Tech Vendor
    Bill
    Navarre, FL
    Multi-point tow hooks, new bored 2.7L engine, custom paint. 3 inch adjustable Fabtech front coils, 2.5 inch rear AAL. Front Aussie locker. LED bed lights. Full LED conversion interior and exterior. Relentless Fabrication front and rear bumpers. 4X4innovation sliders. BAMF bed rack. CVT rooftop tent.
    I suggest finding the problem before tearing into things. See if you have a friend who has a scan tool or talk to a local parts store. Many have them for rent for cheap or sometimes free. Look at the data and see what is not within range. THEN look at taking something apart. Did this happen suddenly, or is it something that looking back you can see it was getting worse until now?
  9. Jan 13, 2013 at 7:16 PM
    shaggie
    sean
    CA
    01 Tacoma 4WD
    Thank you everybody for all of your suggestions! The idle problem that my truck was experiencing was caused by a dirty IAC valve. I used some CRC throttle body cleamer that I had laying around to clean the IAC; and now, my Tacoma runs perfect! I appreciate the help.
    Shaggie
  10. Jan 13, 2013 at 7:29 PM
    2000GTacoma
    Snow Hill NC
    Not a problem glad you found the problem for cheap.
