Truck will not move while in gear.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pikehk01, Jan 11, 2016.
  1. Jan 11, 2016 at 10:48 AM
    pikehk01
    pikehk01 [OP] Well-Known Member
    Stewart
    Mobile, AL
    '11 SR5 4x4
    My truck will not move while in drive or reverse. I have tried it in all gears and it will not move, it will lurch forward (when in a drive gear) or backwards (when in reverse). I put it in 4x4 (just to try something) and it moved about 10ft. When it was moving it felt like the breaks were engaged. I checked the E break and it was not on, the regular breaks didn't feel like they were engaged either. Mine does not have a dipstick so I cant easily check the trans fluid. Any suggestions would be great. Its a 2011 dbcb 4.0 v6 4x4.
  2. Jan 11, 2016 at 10:50 AM
    Erkon
    Erkon Well-Known Member
    Wisconsin
    2012 Pyrite Mica Tacoma TRD Supercharged
    did you recently use the parking brake? Maybe the bell cranks are stuck?
    EDDO likes this.
  3. Jan 11, 2016 at 10:51 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Sub'd for outcome.
  4. Jan 11, 2016 at 10:51 AM
    tacomatrd22
    tacomatrd22 TRD SuperCharged Tacoma
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    FlowMaster Super 44 2" lift Gray wire Fog light
    So if something breaks its brakes? o_O
  5. Jan 11, 2016 at 11:01 AM
    pikehk01
    Stewart
    Mobile, AL
    '11 SR5 4x4
    tacomatrd22 I know you just screwing with me but, thanks ass. I was quick typing and made a mistake. Yes I meant brakes, not breaks.
  6. Jan 11, 2016 at 11:04 AM
    pikehk01
    Stewart
    Mobile, AL
    '11 SR5 4x4
    I don't use my parking/E brake.
  7. Jan 11, 2016 at 11:04 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I would check it anyway.
    You also normally drive forward and backward, so.. I would rule out the easy things.
  8. Jan 11, 2016 at 11:15 AM
    pikehk01
    Stewart
    Mobile, AL
    '11 SR5 4x4
    I plan on checking it, just stating no dipstick
  9. Jan 11, 2016 at 11:22 AM
    Erkon
    Wisconsin
    I haven't looked into it yet since I just got my truck a couple months ago, but I did notice the lack of a dipstick for the trans fluid, is there a fill plug? like on the diff? Maybe you can check it there?
  10. Jan 11, 2016 at 11:44 AM
    tacomatrd22
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    Just saving English grammar.
  11. Jan 11, 2016 at 12:24 PM
    bosa
    bosa Well-Known Member
    06 4x4 Radiant Red Taco
    Rear Driveshaft still attached?
  12. Jan 11, 2016 at 12:27 PM
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    Did you just wash the truck?
    I have had issues with my rear brakes. When I washed the truck, somehow water got into the brakes and the next morning my brakes would be frozen. SOmetimes it would pop loose, 2 times I had to have it towed to toyota for repair.
  13. Jan 11, 2016 at 12:27 PM
    pikehk01
    Stewart
    Mobile, AL
    '11 SR5 4x4
    I have not been underneath it since it started first thing this morning when I was trying to go to work. I will when I get home.
  14. Jan 11, 2016 at 12:29 PM
    pikehk01
    Stewart
    Mobile, AL
    '11 SR5 4x4
    no, hasn't been washed lately.
  15. Jan 11, 2016 at 4:08 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Sounds like you need a good transmission shop.
  16. Jan 11, 2016 at 4:12 PM
    NewRider
    NewRider Well-Known Member
    Travis
    Charlottesville , Va
    '87 4runner
    There's a check plug on the bottom (might be passenger side I can't remember) of the transmission. Takes and Allen wrench and the plug has "check" stamped on it
  17. Jan 11, 2016 at 4:12 PM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    cut a hole in the floor and push it like the Flintstones
  18. Jan 11, 2016 at 4:19 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Can you move it when it's in neutral?
  19. Jan 11, 2016 at 4:20 PM
    pikehk01
    Stewart
    Mobile, AL
    '11 SR5 4x4
    Update.
    Got home and got underneath the truck and couldn't see anything out of the norm. I disconnected the battery for about 10 mins, reconnected, cranked it and put it in 4h (cause that's how it moved before) I heard everything engage so I dropped it into 4l heard change gears. It rolled forward a few feet, I tried reverse and it rolled back a few feet. Took it out of 4x4 and it was back to normal. I'm not sure if it was from disconnecting the battery or from putting it into 4l or both. It always felt as if the brakes were engaged and holding it in place. While driving around it didn't feel any different.
    Thanks for all the input guys
  20. Jan 11, 2016 at 4:20 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    There is a little more to it than that... Search the forum. It has to be at the correct temperature first. And the check plug is not on the bottom ( or all the fluid would drain out). It is on the side.
