Truck will not start (not the battery)
Discussion in 'Technical Chat' started by DTCVTC, Sep 7, 2011.
  1. Sep 7, 2011 at 3:44 AM
    DTCVTC
    DTCVTC [OP] Member
    Got up this morning to go to work and the truck wouldnt start. Plenty of battery keeps turning over but feels like its getting no gas? Any ideas?
    Dave
  2. Sep 7, 2011 at 3:48 AM
    DrewH
    DrewH Well-Known Member
    Fuel Pump Maybe... How about some more info on the truck?
  3. Sep 7, 2011 at 4:02 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    18 wrx limited 6MT
    I would think fuel pump or spark plugs. x2 on the more info needed though. What model truck, what engine, how many miles, etc...
  4. Sep 7, 2011 at 5:42 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Check to see if you are getting spark, if not, check the wires, coils, plugs, and crank position sensor. Check your fuel pressure if you have spark.
    Give us as much info as you can. Model, engine, symptoms, sounds, what you have already looked at and found. This will get you better feedback.
  5. Sep 7, 2011 at 5:46 AM
    Namyo
    Namyo -
    rub the dash and whisper sweet nothings :D
    does work :cool:
  6. Sep 7, 2011 at 6:04 AM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    :laughing:
  7. Sep 7, 2011 at 6:04 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    08 Tacoma 4x4 TRD V6 SR5
    Rear Leaf Spring TSB, Front Bilstein 5100's set to 1.75, Goodyear Wrangler DuraTrac 265/75/R16 tires, Black WeatherTech Floor Liners, aFe Pro Dry S air filter, lighted 4x4 switch......
    What we have here is..........failure to communicate. We need more info!
  8. Sep 7, 2011 at 6:07 AM
    Namyo
    Namyo -
    boy...what's that dirt doin in mah hole :cool:
  9. Sep 7, 2011 at 10:34 AM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    Check EFI fuse. FIRST THING.
    Fuck everything else. I've seen so many times when EFI fuses decided to ground out for some reason...and your sitting there cranking and cranking and cranking...but it won't start because no fuel is being fed.
  10. Sep 7, 2011 at 10:53 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    This is usually a good sign the fuel pump isn't far behind from taking a crap.
  11. Sep 7, 2011 at 11:04 AM
    Us3r
    Us3r Reading...
    Socali
    98 Tacoma Std. 2RZ-FE 2WD
    Axle wrap mod (Shackled), 140 Amp Alternator & Wires, HID Headlights, Brush Guard Grille, Hella 550 Driving Lights. |Saving:Total Chaos.|
    ^^ what he said.
    Check your efi fuse. check for spark (insert screw driver into plug and hold it near your frame). If no spark, check coils, if spark, check fuel.
  12. Sep 7, 2011 at 11:13 AM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    Indeed.
  13. Sep 7, 2011 at 12:32 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Any fuse blowing is a good indication that there is a problem. Fuses don't just go bad, something burns them up. A fuel pump drawing more amps due to wear and increased resistance is a good culprit.
    Good call Ddog!
  14. Sep 7, 2011 at 2:06 PM
    DTCVTC
    DTCVTC [OP] Member
    2005 v6 6 spd 119000 miles been running fine. Drove home last night tried turning on this morning and nothing. Thanks for all the help guys ill start with the fuse tonight.
    Dave
  15. Sep 7, 2011 at 2:10 PM
    DTCVTC
    DTCVTC [OP] Member
    4x4 TRD off road. Has been raining up north for about 5 days also
  16. Sep 8, 2011 at 8:33 AM
    DTCVTC
    DTCVTC [OP] Member
    Checked all the fuses last night. No suck luck. Hope to check for spark and if i have fuel going in tonight
  17. Sep 9, 2011 at 7:51 AM
    DTCVTC
    DTCVTC [OP] Member
    Have spark but fuel pump not turning on. Have power to the relay but no idea after that
    Any ideas I really dont want to change the pump if I dont have to
    Dave
  18. Sep 9, 2011 at 12:02 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Check the leads to the pump. If it's getting power, it's shot.
