Truck will now no longer start without a jump, but all other electronics work
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tluke81, Sep 1, 2021.
  1. Sep 2, 2021 at 5:54 AM
    #41
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    You just said the same thing I did, but said I’m incorrect?
    Skydvrr likes this.
  2. Sep 2, 2021 at 7:31 AM
    #42
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    Bumping to $18.
    FishnTx, ktbell444 and shakerhood like this.
  3. Sep 2, 2021 at 7:33 AM
    #43
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Damn son, we in a tight spot!
    StayinStock[QUOTED] likes this.
  4. Sep 2, 2021 at 7:33 AM
    #44
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    I know!! It's getting real!
    Skydvrr[QUOTED] likes this.
  5. Sep 2, 2021 at 7:54 AM
    #45
    DanoTay
    DanoTay Well-Known Member
    Victoria, B.C.
    2019 Tacoma OR AC MT
    I'm betting on loose battery cables as the culprit.
    We already know there was a "loose ground wire" but we don't know the cause or if it was the battery end that was loose or the other end where the ground attaches to the frame or engine block.
  6. Sep 2, 2021 at 7:56 AM
    #46
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    You said its NOT your alternator...read what you posted
  7. Sep 2, 2021 at 8:19 AM
    #47
    almazan312
    almazan312 Active Member
    OEM Battery is crap. I had mine replaced when the truck had less than 10k miles.
    t0nyvalenzuela likes this.
  8. Sep 2, 2021 at 9:43 AM
    #48
    wj3v
    wj3v Active Member
    2022 TRD Sport
    This is not correct at all. If the diodes go bad you have NO DC voltage. Everything connected to the truck runs on DC. All computer modules are DC. IF the diodes short out you could get a high AC voltage and begin blowing stuff up. But usually the battery will handle the surge temporarily and throw a warning light.
    I have seen a couple battery's explode from a shorted diode and high AC voltage being supplied from the alternator. These were older vehicles. I imagine these newer Tacoma's would shut down before that could happen.
    Skydvrr likes this.
  9. Sep 2, 2021 at 11:32 AM
    #49
    Trail Limo
    Trail Limo Well-Known Member
    You are making the assumption that all of the diodes failed completely, which certainly happens. It's also common that one or two diodes get weak, or fail resulting in an AC signal superimposed on top of the DC. Higher end alternator testers check the alternator waveform for this exact type of failure (too much leakage AC). Batteries will smooth out the ripple substantially, which is what allows the vehicle to still run. This will destroy a battery pretty quickly if the alternator is not replaced.
    When I used to work in a shop, this type of failure was fairly common when customers would come in with no starts and had already tried a new battery.
  10. Sep 2, 2021 at 11:56 AM
    #50
    bmgreene
    bmgreene Well-Known Member
    Brian
    L.A. Westside
    2010 PreRunner V6 SR5/OR
    Alcan Leaf Packs, OME884 Coils, 5100 shocks, U.S. Offroad Winch Mount w/Winch, Trail Gear Rear H/C Bumper, Prinsu Cabrack, DIY custom in-bed storage/sleeping deck, Sway bar delete, hidden "snorkel" intake mod, In-dash CB, Bestop Supertop, Undercover Swingbox, hood lifters, assorted lights and front spotting camera
    A lot of auto parts stores will hook up a load tester to your battery for free.
    If you're unsure about the alternator, hook up a voltmeter to the system; there's any number of gadgets that include one or you can set up a dedicated gauge. I have a clinometer that plugs into the "12V" poser socket that reads out the system voltage as well, or there are a bunch of different options that'll read voltage along with adding USB power ports and fit into OEM switch or power socket knockout holes.
    If you're reading over 13V with the engine running the alternator works fine, if you're reading the same with the engine on vs engine off, then there's an issue with the charging system that could include a bad alternator.
    OBD2 monitors or bluetooth dongles with a phone app can also be used to monitor system voltage as well.
    Trail Limo, shakerhood and 513Mugsy like this.
  11. Sep 2, 2021 at 1:02 PM
    #51
    Sungod
    Sungod Well-Known Member
    St Augustine
    Better tip. He should buy a f'ing boat if he wants to go in water.
  12. Sep 2, 2021 at 2:08 PM
    #52
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Nobody suspecting water in the engine ? It’s submerged no snorkel .
  13. Sep 2, 2021 at 2:19 PM
    #53
    bmgreene
    Brian
    L.A. Westside
    A little bit of water should have cleared out the tailpipe by now. A lot of water would have hydrolocked the engine and caused a much bigger and more permanent problem.
    Probbably not a bad idea to change out the oil in the crankcase and diffs to be safe though.
  14. Sep 2, 2021 at 2:51 PM
    #54
    almazan312
    All it needs is a pro grille
    Sungod[QUOTED] and shakerhood like this.
  15. Sep 2, 2021 at 7:00 PM
    #55
    mutely
    And it isn’t the alternator (if the OP was accurate in his post). If it was the truck wouldn’t run once the jumper cables were removed. Read what you said. If the alternator is NOT producing electricity, the truck dies once the battery is dead. The battery was dead, which it why it needed the jump. So tell me, if the battery is dead how is the truck running if the alternator is not producing electricity?
  16. Sep 2, 2021 at 7:21 PM
    #56
    Skydvrr
    Nick
    YMH
    Black '17 OR
    :popcorn::popcorn:
    tacotoe and shakerhood like this.
  17. Sep 2, 2021 at 7:24 PM
    #57
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Falken Rubitrek AT 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    My 2017 did the same thing without getting wet all the electronics worked but it would not turn over. Replaced battery and good to go. By the way no new Toyota battery for me I bought one from Sam’s club.
  18. Sep 3, 2021 at 10:09 AM
    #58
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    This is prob all a repeat.
    1. Check for loose battery connections
    2. Check for corrosion on the battery terminals and clean
    3. Replace the battery, stock are junk
  19. Sep 5, 2021 at 1:18 PM
    #59
    tluke81
    tluke81 [OP] Active Member
    So the battery was on its last leg, but not the problem. I just took everyone's advice and replaced it regardless. I'm now positive it's the starter after doing more research. A single click after the start with no crank is the starter. The reason I got a few uses out of it is that the starter dies slowly after getting submerged, and if you jump it at the same time you have a better chance of getting it started. This would also explain why in my first post I noticed a slower start. I got a new OEM one for $130 and I'm replacing it later this week.
    tacotoe likes this.
  20. Sep 5, 2021 at 1:18 PM
    #60
    tluke81
    It was the starter
