Truck will randomly honk 4 times while parked
Discussion in '3rd Gen. Tacomas (2016-2023)' started by EveryDayIsTacoDay, Jun 27, 2019.
  1. Jun 27, 2019 at 1:31 PM
    EveryDayIsTacoDay
    EveryDayIsTacoDay [OP] New Member
    I have a 2016 Tacoma SR5 V6 with Guide Point GPS security system and my truck just recently started honking randomly while off and parked four times rapidly. I have no caution or maintenance lights coming on while in the vehicle and i haven't been able to see if its my vehicle or my security system. I've had my truck over a year and it just started happening. Any help would be great before turning it over to the dealership.
  2. Jun 27, 2019 at 1:33 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Disconnect power to the aftermarket security system...problem solved.
    GreyBaldTaco likes this.
  3. Jun 27, 2019 at 1:35 PM
    EveryDayIsTacoDay
    You think that is what it is though?
  4. Jun 27, 2019 at 1:38 PM
    Ronzio
    Pennsylvania
    17 DCSB TRDOR
    Cut the power wire and that will tell you for sure...I doubt it would be a Toyota issue.
  5. Jun 27, 2019 at 1:38 PM
    Taco_Craig
    Taco_Craig Well-Known Member
    Craig
    2016 MGM Tacoma, DCSB TRD-OR
    RCI Sliders/Plates, Icon [Stage 3] Suspension
    Well, if you disconnect the aftermarket alarm and the problem goes away, you've at least diagnosed it pretty well... I can't think of anything else that would have those sort of chirping effects.
  6. Jun 27, 2019 at 1:40 PM
    EveryDayIsTacoDay
    Ill try it, might take a couple weeks to find out if it was the problem or not since it honks randomly, ill post when i know if it worked or not, thanks gents.
  7. Jun 27, 2019 at 1:48 PM
    kpinthebay
    kpinthebay Well-Known Member
    Hawaii ==>>SF Bay Area
    I agree, its probably the aftermarket security.
    I bought a pre-owned Accord last year. A few months ago it started randomly honking. I then went under the dash and noticed a cheap shock sensor spliced into the factory system. I cut its power and bypassed the relay. Problem solved.
    Take it back to the shop that installed the system.
  8. Jun 27, 2019 at 2:34 PM
    Señor
    Señor Well-Known Member
    CA Central Coast
    '18 TRD OR DCSB Magnetic Gray Metallic
    Your truck is just horny....
    I know, weak!
