truck wobbling
Discussion in '2nd Gen. Tacomas (2005-2015)' started by streetcustoms, Jan 31, 2010.
  1. Jan 31, 2010 at 4:15 PM
    streetcustoms
    streetcustoms [OP] Well-Known Member
    tujunga , ca
    prerunner sr5 trd off road
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/74196-my-build-so-far.html
    atfer geting 33 inch mudd terrains aiwth pidertrax spacers my car seems to wobble kind of go side to side somewhat and the steering wheel also when you drive over 50 i also have 3 inch lift
    is that from alignment or do i need ucas for that i have lr ucas coming in this week will that help
  2. Jan 31, 2010 at 4:17 PM
    streetcustoms
    tujunga , ca
    the n=heb centric ones their spidertrax it would wobble somewhat before them to
    hopefully uca helps
    anyone had this problem
  3. Jan 31, 2010 at 4:21 PM
    streetcustoms
    tujunga , ca
    its hub centric
  4. Jan 31, 2010 at 4:21 PM
    streetcustoms
    tujunga , ca
    stock but it would wobble ebfroe having the tires or spacers on to
  5. Jan 31, 2010 at 4:28 PM
    FARNORCAL
    FARNORCAL Well-Known Member
    06 Tacoma4x4 DC LB Silver TRD Sport
    SEE BUILD
    Have the basics check like alignment and ensure the tires are balanced. You never know
  6. Jan 31, 2010 at 4:30 PM
    streetcustoms
    tujunga , ca
    no noise its like if i even eave the steering wheel lose you can see it just wobbling and moving around
    ive heard it can be from ucas but not sure
  7. Jan 31, 2010 at 4:34 PM
    streetcustoms
    tujunga , ca
    what do you mean by wandering?
  8. Jan 31, 2010 at 4:34 PM
    FARNORCAL
    SEE BUILD
    not too sure how much the UCA's will help but ive heard if you go more then 2.5 inchs you need the Aftermarket ucas
  9. Jan 31, 2010 at 4:37 PM
    streetcustoms
    tujunga , ca
    sould be getting ucas in this week
    wandering do you mean somewhat moveing around in the lane
  10. Jan 31, 2010 at 4:38 PM
    streetcustoms
    tujunga , ca
    actually yes then its wandering not wobbleing sorry bout that
    if its wandering around would ucas fix it
  11. Jan 31, 2010 at 4:39 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    They should make it possible to get your alignment in spec.
  12. Jan 31, 2010 at 4:40 PM
    streetcustoms
    tujunga , ca
    thanks a lot guys
    would i be able to install myself or sould i get them installed
  13. Jan 31, 2010 at 4:43 PM
    Jason'sLawnCare
  14. Jan 31, 2010 at 4:44 PM
    DTacoms
    DTacoms Well-Known Member
    Frisco, Texas
    05 4x4 DC LB BSP
    Sorry, I was supposed to edit my post but hit the delete instead. I'm glad someone helped with the answer.
  15. Jan 31, 2010 at 4:47 PM
    streetcustoms
    tujunga , ca
    thanks a lot guys
  16. Mar 28, 2010 at 12:59 PM
    b168
    b168 Well-Known Member
    South Bay, CA
    09 Tacoma DC TRD Off Road
    6" Pro Comp Lift 35" Xtreme A/T Pro Comp Tires 4.56 Gears
    mine doesnt wobble with 35's but it steering shakes when doin 50-55.
    does type of rims has effect on this? already had the alignment checks numerous times but still wont go away. or is it the 35's that makes it wobble?
    any tips would be of great help
    thanks
  17. Mar 28, 2010 at 1:20 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    I had a similar problem with shakes. Went to discount numerous times for re balance they couldn't do it right. Last time I said either you do it right this time or buy my tires and ill go elsewhere....they fixed the balancing issue on that visit
