Truck won’t start after battery disconnect
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dtodd87, Jan 20, 2021.
  1. Jan 20, 2021 at 3:22 PM
    MauiBrian
    MauiBrian Kapalua fun
    Brian
    Maui
    2018 SR lightly modded
    Try this if you don't have a battery tester: Turn ON the headlights. They should hopefully be bright. If the lights are dim at this point then battery needs a charge or replacement. Then try to start the engine. If the headlights go very dim or OFF the battery needs to be charged/replaced. If the lights stay bright then the problem is in the starter circuit.
    If you have a voltmeter, the voltage should never drop below approximately10 volts or so. Hope this helps and good luck.
    Dtodd87[OP] likes this.
  2. Jan 20, 2021 at 3:23 PM
    Dtodd87
    Dtodd87 [OP] Well-Known Member
    Dylan
    06 4.0L TRD OR
    Engine: 1GR-FE stock ARB Safari intake CSF Performace radiator Front Suspension: B8 6112 shocks B8 upper control arms Rear Suspension: B8 5160 shocks Deaver Expedition series 2 Leaf springs (stage 2)
    If this is the case then nothing electronic should be on correct? I’ve got hud lights, radio and head lights working
  3. Jan 20, 2021 at 3:24 PM
    dk_crew
    dk_crew Well-Known Member
    Dave
    Austin, TX
    2005 Tacoma 4x4
    here's my post from a few years ago -- if there's no click ... https://www.tacomaworld.com/threads...in-theft-mode-05-tacoma.664745/#post-23296077
    in my case, the battery had died. I had my own jumper box and then we tried cables -- no click. Voltage was good on the battery after charging, but still no click ... I finally found this and it worked.
    In my case, the 5 times reset the switch and I was able to start. You'll hear the click and it will fire up or the normal failed stutter when your battery is dead. The tell tell sign for me was no audible click when attemping to start. I'm not 100% if the alarm was going off while trying this. I want to say yes but I can't remember.
    TnShooter and Dtodd87[OP] like this.
  4. Jan 20, 2021 at 3:25 PM
    Dtodd87
    Dylan
    06 4.0L TRD OR
    Looks fine, brights as well
  5. Jan 20, 2021 at 3:28 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    They could be
    I sure hope this works.
    And if it does, I’ll need to remember this.
    I honestly can’t say I have ever had my alarm go off?
    I may not have one?
    I do have Immobilizer, and a panic button?
  6. Jan 20, 2021 at 3:32 PM
    dk_crew
    Dave
    Austin, TX
    2005 Tacoma 4x4
    lol everytime I disconnect then reconnect the battery my alarm goes off -- factory 2005 -- I need your mod that disables this. I'd love to get rid of that alarm altogether.
  7. Jan 20, 2021 at 3:40 PM
    TnShooter
    Deogee
    STOCK
    Mine doesn’t beep when I lock the doors either? :confused:
    I don’t really want it too, so I never looked into it.
    Although, there is supposed to be a way to disable it.
    I know I didn’t, maybe the previous owner did?
  8. Jan 20, 2021 at 3:47 PM
    Texas T
    Texas T Well-Known Member
    TX
    '14 T Force
    Still might need a charge though. Try jumping it.
  9. Jan 20, 2021 at 4:02 PM
    Dtodd87
    Dylan
    06 4.0L TRD OR
    Anti theft was on, literally just had to lock and unlock my doors with the key remote.............:confused::annoyed:
    thanks for y’all’s help
  10. Jan 20, 2021 at 4:13 PM
    TnShooter
    Deogee
    STOCK
    Awesome..... I’ll take note of that.
    Good here you are back and running.
    Dtodd87[QUOTED][OP] likes this.
  11. Jan 20, 2021 at 4:14 PM
    dk_crew
    Dave
    Austin, TX
    2005 Tacoma 4x4
    Somebody sticky the process to disable or remove the alarm. Glad to hear you’re rolling again.
  12. Jan 20, 2021 at 8:57 PM
    Texas T
    TX
    '14 T Force
    Glad you got it with an easy fix
  13. Jan 20, 2021 at 9:09 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I bet it has an aftermarket alarm/immobilizer that uses the factory key fob, the factory immobilizer uses the chip in the key for anti theft and doesn't care if the doors are locked or not and also the factory one I believe disables the fuel injectors not the starter.
    dk_crew, Jimmyh and TnShooter like this.
  14. Jan 20, 2021 at 9:11 PM
    Texas T
    TX
    '14 T Force
    Whatever, doesn’t matter if he unlocks Jupiter and locks Mars while simultaneously half unlocking Pluto. He figured it out and no big deal
    racerX969 and Dtodd87[OP] like this.
  15. Jan 20, 2021 at 9:15 PM
    #35
    Dtodd87
    Dylan
    06 4.0L TRD OR
    I could hear the full pump engage and fill the line when I turned the key
  16. Jan 20, 2021 at 9:16 PM
    #36
    12TRDTacoma
    Rob
    Concordia
    Boosted
    If it is clicking you may want to take a look at your connections again. Including connections at the starter.
    If all is tight and good to go then you need to either charge or replace the battery.
    For record, I NEVER disconnect my battery on any repairs minus starter replacement or something involving touching the battery positives or negatives together while the battery is still connected which could cause arcing or fuse blow out. There's no need for it. Seriously.
    Welding is an X factor which in which case you should disconnect the battery, as that is some seriously high voltage stuff. Outside of these items, you are wasting your time.
  17. Jan 20, 2021 at 9:17 PM
    #37
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    It doesn't disable the pump just the injectors, usually when the antitheft is triggered you will get a start/stall.
  18. Jan 20, 2021 at 9:17 PM
    #38
    TnShooter
    Deogee
    STOCK
    Yes, I do believe that is correct.
    Also, If the “Flashing Key” light for the immobilizer stop blink with the key in.
    The truck should at least crank. That why I asked if the truck cranked.
    If so, it wasn’t the key.
  19. Jan 20, 2021 at 9:20 PM
    #39
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    What the.....
  20. Jan 20, 2021 at 9:20 PM
    #40
    12TRDTacoma
    Rob
    Concordia
    Boosted
    We cannot rule out an aftermarket alarm bro. I have seen plenty of vehicles using the OE fob setup while it still has an alarm rigged underneath the dash causing interference problems. He will need to get under there and confirm there isn't any funky wiring under there potentially causing interference.
    TnShooter[QUOTED] likes this.
